Reply 2740 of 3552, by sharangad
Canadair wrote on 2025-04-19, 23:53:
hopefully more mods possible on icr2 😀?
thank you
With this build no, it just has a fix for Scorched Planet. It's a pretty minor update, other than forcing 512 MB of RAM Dosbox-Staging-Rendition. Dosbox-Rendition already supported this. To allow ICR2 to run at full speed with 32 cars drawn ahead and 32 behind with custom carsets and tracks I *think* QEMU might be needed, which is what I'm trying to get going. This should allow the CPU side of Dosbox to run at full speed, using a virtual machine.
https://patreon.com/Rready
Reply 2741 of 3552, by robertmo3
working configuration:
this is enabled in windows features:
Hyper-V Hypervisor enabled
this is disabled:
Hyper-V gui management tools
hyber-v module for windows powershell
hyper-v services
windows hypervisor platform
Reply 2742 of 3552, by robertmo3
above is enough to have qemu working with whpx
but configure detects whpx with whatever setting i have (can be all whpx related disabled in windows features, but configure still detects whpx even if i have everything whpx related turned off in windows features)
so maybe turn on everything whpx related in windows features
maybe you have to install all packages with everything whpx related in windows features turned on
just uninstall msys2 completely, remove all leftover folders
turn on everything whpx related in windows features (reboot is always needed even if windows doesn't ask for it)
and install latest version again from here
https://www.msys2.org/
https://github.com/msys2/msys2-installer/rele … 64-20250221.exe
Reply 2743 of 3552, by robertmo3
also check if qemu compiles with:
./configure --target-list=i386-softmmu --enable-sdl --disable-whpx --audio-drv-list=sdl,dsound
Reply 2744 of 3552, by robertmo3
you install all packages in MSYS2 MSYS
but you do all qemu stuff in MSYS2 UCRT64
Edit: you do everything in MSYS2 UCRT64
Reply 2746 of 3552, by robertmo3
you have to run MSYS2 UCRT64 as admin
Reply 2747 of 3552, by sharangad
robertmo3 wrote on 2025-04-20, 03:39:
This produces an SDL2 error. But I did install sdl2. It does go a lot further.
[EDIT] Removing sdl from the sound options still produces the sdl2 error.
Reply 2749 of 3552, by sharangad
robertmo3 wrote on 2025-04-20, 03:28:
... maybe you have to install all packages with everything whpx related in windows features turned on […]
The uninstaller fails with an invalid path error. I'm just going to zap the folder.
Reply 2750 of 3552, by robertmo3
have you installed to default folder?
Reply 2751 of 3552, by robertmo3
robertmo3 wrote on 2025-04-20, 03:44:
this is not truth
Reply 2752 of 3552, by robertmo3
btw from your last picture i see you are running msys not ucrt64
Reply 2753 of 3552, by sharangad
sharangad wrote on 2025-04-20, 04:30:
Ok I had a full installation of MSYS2 left over from an earlier project, which is why the installer had issues. Also, the runtime libraries go in another folder. I've zapped both of those and reinstalled from scratch.
Previously I've tried building against a direct download of the last stable build of qemu and not rc4.
On this fresh install I followed your steps to the letter and got this:
sharanga@ged MSYS ~/qemu-10.0.0-rc4
$ ./configure --target-list=i386-softmmu --enable-sdl --enable-whpx --audio-drv-list=sdl,dsound
Using './build' as the directory for build output
ERROR: C compiler "cc" either does not exist or does not work.
[EDIT] I think I need to alias gcc as cc or create a symlink. I got a lot further with the previous messed up installation.
Reply 2755 of 3552, by robertmo3
not MSYS2 MSYS
Reply 2756 of 3552, by sharangad
robertmo3 wrote on 2025-04-20, 05:21:
not MSYS2 MSYS
Yup you're right! My bad.
Does it need /UCRT64 or just vanilla UCRT?
I'll try it after lunch. Got some stuff to do.
Reply 2757 of 3552, by robertmo3
all available shortcuts in
C:\Users\User\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MSYS2\
are:
MSYS2 CLANG64
MSYS2 CLANGARM64
MSYS2 MINGW64
MSYS2 MSYS
MSYS2 UCRT64
all available executables in
c:\msys64\
are:
clang64.exe
clangarm64.exe
mingw32.exe
mingw64.exe
msys2.exe
ucrt64.exe
we are using MSYS2 UCRT64 (ucrt64.exe)
Reply 2758 of 3552, by sharangad
robertmo3 wrote on 2025-04-20, 05:30:
all available shortcuts in C:\Users\User\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MSYS2\ are: MSYS2 CLANG64 MSYS2 […]
are:
MSYS2 CLANG64
MSYS2 CLANGARM64
MSYS2 MINGW64
MSYS2 MSYS
MSYS2 UCRT64
c:\msys64\
are:
clang64.exe
clangarm64.exe
mingw32.exe
mingw64.exe
msys2.exe
ucrt64.exe
After I reinstalled MSYS the shortcuts in that folder disappeared. I do still have them in the msys folder.
Reply 2759 of 3552, by robertmo3
.exe is ok too
