Reply 28900 of 31007, by dr_st
- l33t
Decided to update the ancient maps on the navigation system built into my 2012 Corolla. Don't ask me why, since I never use it anyways (the navigation that is, the Corolla is OK). The multimedia is some FlyAudio crap (cool stuff, BTW, let's you watch videos while driving). It's running WinCE. I actually had no idea where it even keeps the maps.
Eventually I discovered that these device ship with a microSD card, which has the iGo app + maps. I thought it would be a matter of popping the card into a PC and getting updated maps... somewhere. Well, the thing got stuck in the slot, I had to use pliers to pull it out. Can you imagine a microSD card being damaged when you try to pull it out from the slot? Neither could I, but somehow it happened. It got a tiny bend which apparently broke the contacts inside, since no system recognized it ever again. OK, well, so now I have to also redownload the app itself... somewhere.
It was not really difficult finding iGo Primo (the WinCE version), but the first one I tried never picked up any GPS satellites. Turns out it's best to get the one customized for your country, unless you want to try some settings voodoo with sys.txt. Anyhow, on the second or third try I found a version that worked, so now I have a bunch of maps that are probably 2-3 years old (and not 10-12 years old), on a slow and clumsy navigation system which I will probably only use out of boredom.
