Reply 29240 of 31211, by Trashbytes
yourepicfailure wrote on 2025-02-15, 08:50:
gerry wrote on 2025-02-14, 10:26:
yourepicfailure wrote on 2025-02-14, 06:38:
Someone gave me this scope the other day. […]
The attachment scope-1.jpg is no longer available
The attachment scope-2.jpg is no longer available
But it's got some issues. Learning how to disassemble it so I can test caps.
Will probably have to wait a little to open the CRT driver side.
Either way, this bohemoth is perfect for what I like to play with: old video equipment and old computers.
what a wonderful thing! Sure it will need some attention but hopefully you'll soon have it up and running, good as new
What I love is that everything is BNC, which 90% of the stuff I work with (old video equipment) uses by default. Makes connections so easy with BNC patch cables.
Otherwise, any recommendations when disassembling and troubleshooting it?
Take great care, I doubt itll be easy to replace the more delicate internal parts and components, the screen might be the hardest part to replace so its good you are leaving that part alone. I would recommend finding someone with old CRT knowledge they can be tricky to work with blind.
Reply 29241 of 31211, by OVERK|LL
I scored this (functional) old unit for free from a client:
Pentium 75 w/8MB of RAM.
However, the RTC battery is dead and it's a soldered-on one, so this might be fun. Has anyone had any success just wiring in a CR in parallel (there are the pads for it on the board) to power the RTC rather than desoldering or cutting open the ODIN unit?
DD: Mac Pro 5,1 - X5690, 64GB, RX 580 - OCLP w/Sequoia
Projects:
- Hewitt-Rand 8088 - 640KB, 20MB, Hercules mono
- IBM PS/1 2133 w/Thermalwrong solder mod - ODP 486DX4-100, 32MB
- PCPartner VIB806DS w/233MMX, 128MB, G450
- Jetway J-TX98B w/P75, 256MB
Reply 29242 of 31211, by dominusprog
OVERK|LL wrote on 2025-02-15, 15:25:
These RTC modules doesn't have the legs for the battery, you have to remove the cover. Nice case, by the way 🙂.
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 29243 of 31211, by PD2JK
Yes you should get that Odin out first. But do my eyes deceive me like an optical illusion, or are those 3,5" diskette drives fake. 🫢
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 29244 of 31211, by OVERK|LL
dominusprog wrote on 2025-02-15, 15:30:
OK, so there's no way for a CR battery soldered to the pads adjacent to the ODIN to get power to the RTC is what you are saying? I have to either remove or mod the ODIN?
Thanks on the case, it needs some retrobright for sure, but it's in great shape!!!
Projects:
Reply 29245 of 31211, by OVERK|LL
PD2JK wrote on 2025-02-15, 15:35:
They are totally fake. I already pulled one because I have a functional Panasonic that's going in. I have no need for the 5.25", so I'm going to remove that and try to find a period-correct ODD for it.
System was used as a "server", so had ISA video and no sound card. I have an SB16 here, a few SB Live's and some other options, so I'll fart around with that stuff once I've got the battery/RTC situation sorted. I've already swapped out the video card for an S3 Virge I had kicking around.
Projects:
Reply 29246 of 31211, by dominusprog
OVERK|LL wrote on 2025-02-15, 15:42:
Yes. Necroware has made a very good video on this.
https://www.youtube.com/watch?v=xBvw1TLHyqM&p … XJlIHJ0Yw%3D%3D
https://www.ebay.com/itm/205164925449?_skw=ne … ABk9SR_6wwaWhZQ
Reply 29247 of 31211, by xelizor
amadeus777999 wrote on 2025-02-14, 17:49:
After a LONG time I finally got to buy an OSSC and try it with some of my old PCs... I have to admit it's pretty nice!(It would be prefect if more monitors had a vertical resolution of 1200 pixels)
Only drawback one needs a monitor/TV able to display refresh rates higher than 60hz.
I have some CRTs but I do not like to "use them up" for things that take long work hours.
Nice one, does it pass-through the refresh rate? Like 1600x1200 144hz? There's any refresh rate (hz) limit imposed by ossc itseld?
Best regards
Reply 29248 of 31211, by OVERK|LL
dominusprog wrote on 2025-02-15, 16:02:
Yes. Necroware has made a very good video on this. […]
Thanks, will give that a watch.
Projects:
Reply 29249 of 31211, by AGP4LIfe?
Got the K7-900 Orion apart for factory TIM replacement. Unfortunately no free core upgrade on this one 😞. Still, feels good to get it repasted.
The attachment PXL_20250215_180656236~2.jpg is no longer available
The attachment PXL_20250215_181059960.jpg is no longer available
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 29250 of 31211, by amadeus777999
xelizor wrote on 2025-02-15, 16:08:
Best regards
As far as I can tell - yes, the refresh rate is untouched which can be an unpleasant surprise if you're on a television not supporting rates in excess of 60hz(->black screen).
Since I'm only using the OSSC for old PCs I can't tell the upper limits of its capabilities from experience.
But... I read the "absolute threshold rate" of the unit is 2560x1440x70hz - maybe 60hz at most, but no guarantees.
Reply 29251 of 31211, by PcBytes
Received two new Gigabyte GA-5AX rev 1.4 w/o BIOS, and a few broken ram clips.
Fixed the missing BIOS with 4.51PG (F4) and 6.00PG (4.1, the eSupport version), on my way to fix the clips too.
AGP4LIfe? wrote on 2025-02-15, 18:15:
Been meaning to ask, what about Pluto? I have both a 600 and a 700 here.
Reply 29252 of 31211, by AGP4LIfe?
There is definitely a chance for a having a faster core than what's on the box with pluto's.
The first one I did was. 600Mhz unit with a 700 core. Then my 750 Pluto ended up being an Orion 900!
There Is only one way to find out tho 😉
Reply 29253 of 31211, by Kahenraz
What do you do to take advantage of the better cores? Move some resistors around on the PCB?
Reply 29254 of 31211, by Trashbytes
Kahenraz wrote on 2025-02-16, 06:57:
Well I have a goldfinger which works handily.
Reply 29255 of 31211, by PcBytes
Ah, so no BIOS fiddling, it's all thru Goldfinger.
Figured so given my recent DFI AK70 (a nice board even if no ISA slot) has ZERO overclocking options. Surprising, knowing DFI's habits, but then they're probably the basis for their Infinity branded boards - which are fairly spartan.
Reply 29256 of 31211, by AGP4LIfe?
Just first and foremost it just means your cpu has good head room to OC it you want. If you don't own a GF device and your board has no overclocking options, you can move 3 or 4 resistors around to create a permanent multiplier and identifier change.
Having a higher rated core means you can easily reach it's rated speed or more.
Reply 29257 of 31211, by AGP4LIfe?
Trashbytes wrote on 2025-02-16, 07:26:
I wonder if anyone is still making them. I really want one! 😀
Reply 29258 of 31211, by Trashbytes
AGP4LIfe? wrote on 2025-02-16, 08:03:
Yup I got mine off eBay, technically its a reproduction of the goldfinger but it works just the same.
Reply 29259 of 31211, by Kahenraz
What's a goldfinger? Can you share a photo?
