Reply 300 of 535, by H3nrik V!
- l33t
paradigital wrote on 2023-12-01, 20:26:H3nrik V! wrote on 2023-12-01, 20:24:paradigital wrote on 2023-12-01, 20:18:I’m pretty confident I can get this CPU to 266+ FSB, even if that involves a lower multiplier. It’ll POST at 266x17 with 1.425v core.
Will the RAM run faster or would it be necessary to set the memory multiplier even lower? Because in that case I wouldn't expect much effect of av higher fsb?
The RAM would be faster yes. I’ve got PC2-8500 that at the moment is only doing 833MHz and is rated for 1066!
So, you'd be able to run it at a higher ratio now than you do? That might also bump it a few marks?
