Reply 30240 of 31545, by Nexxen
aspiringnobody wrote on 2025-10-07, 04:18:
My upgraded V2 found its forever home today!
The attachment IMG_7765.jpeg is no longer available
This is lovely 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 30241 of 31545, by H3nrik V!
Nice! What are the specs?
Reply 30242 of 31545, by bakemono
I was going to try fixing up some 40 year old PCB from a car, but there is something weird about it. Unsoldering a component released some unusually unpleasant fumes, and I found that the old solder joints repelled any attempt to add new solder which would just ball up and roll away. Can't remember having this problem before.
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 30243 of 31545, by dominusprog
Recapped this VIBRA16 sound card.
The attachment IMG_20251007_125024.jpg is no longer available
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 30244 of 31545, by DarthSun
Asus A6R: I didn't think it would be such a great retro, I liked it, it's good that my friend called to ask if it was necessary, or he would throw it away.
I plugged it into the test bench monitor via DSub, so it fits FHD as needed, and now fulltrack/3DM99:
The attachment AsusA6R_99_Full.jpg is no longer available
The attachment AsusA6R_Sum_FHD.jpg is no longer available
The attachment 1SBK_CL.jpg is no longer available
The attachment 1A6R_FR.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 30245 of 31545, by DarthSun
Under DOS I knew it would bite:
The attachment 1_LM2_A6R.jpg is no longer available
The attachment 1_Shiny_A6R.jpg is no longer available
The attachment 1_3DB_A6R.jpg is no longer available
The attachment SSTIMG07.jpg is no longer available
SBEmu - sound is also ok:
The attachment 1_SBEmu_A6R.jpg is no longer available
I haven't tried the LPT and PCMCIA ports. SD reader ok. DVDRW ok - IDE interface.
Perfect working and nice condition, good thing it didn't end up in the trash.
Reply 30246 of 31545, by BitWrangler
bakemono wrote on 2025-10-07, 07:51:
I am gonna guess the board is maybe a phenolic type which when overheated gets a bit formaldehyde-y. Then the solder might be a low tin, maybe even silver solder which is higher temperature and doesn't form tin whiskers in low temperatures. Might have to look out SAE or military specs for solder from that era. I remember also that GM somehow managed to make some PCBs in the late 80s that had steel leads on some components and steel bus bars, some of which were rivetted and welded to each other rather than soldered. So test with magnet that you're not trying to desolder a weld, and if it's broke, you may need a different flux to put solder on it, cooking oil may work.
Reply 30247 of 31545, by andrea
DarthSun wrote on 2025-10-07, 10:47:
You should be able to upgrade the cpu to a T7200 or some sort of Merom-2M of for less than 5€, it may be worth it especially considering the notebook looks practically brand new.
Don't bother with high end stuff (T7400 or higher) as they cost way too much for what they are and the single channel memory controller would hold it back somewhat.
Even if you use it only for single threaded programs, you get more cache, speedstep and better IPC. Just upgrade the bios first.
Reply 30248 of 31545, by DarthSun
andrea wrote on 2025-10-07, 18:35:
You should be able to upgrade the cpu to a T7200 or some sort of Merom-2M of for less than 5€, it may be worth it especially con […]
Thanks for the info! I think I have all kinds of models in my CPU collection. There are 1000 of them at the moment. I don't even have to spend money on expansion 😀
Reply 30249 of 31545, by BitWrangler
The ones I've tried the 400fsb ones pin to 533 real easy and don't seem to overheat as long as the cooling system kept clean, maybe copper shimmed instead of pads too.
Reply 30250 of 31545, by Thermalwrong
Locutus wrote on 2025-10-06, 23:31:
aspiringnobody wrote on 2025-10-04, 05:22:
Today I upgraded an 8MB Voodoo 2 to a 12MB Voodoo 2. Always a challenge with the tight spaces between chips but usually worth it!
The attachment IMG_7762.jpeg is no longer available
Were did you buy RAM chips ?
I'm planning to the same with my card.
I've done the same modification a few years ago, you can still easily source these chips online, both on ebay and on aliexpress: M11B416256A
My post on upgrading the card from a long time ago: Re: Voodoo2 8 to 12MB RAM upgrade - is it really that straightforward?
DarthSun wrote on 2025-10-07, 10:57:
Under DOS I knew it would bite: […]
Very lucky that it's behaving well with SBEMU, that makes this a pretty good one for retro gaming now 😀
Compatibility with SBEMU on various AC97 laptops seems to have worse odds than roulette for me.
Reply 30252 of 31545, by dr_st
TheChexWarrior wrote on 2025-10-08, 04:58:
The Apogee Voxel Pack. All the heroes and villains of the company universe are represented as a voxel pack, from BJ to Snake Logan and even Talon Brave from the 90s Prey game.
I recognize most of them, but not all. 😀
Reply 30254 of 31545, by Locutus
The most useless activity - stripping off DALLAS :]
Reply 30255 of 31545, by DarthSun
Locutus wrote on 2025-10-08, 12:37:
I would rather drill it.
The attachment Dallas.jpg is no longer available
Reply 30256 of 31545, by Tiido
That is a really clean result ~
Such a simple solution inside 🤣
Reply 30257 of 31545, by RetroBus
I found a great bargain very close by on Facebook Marketplace 4 boxes for $20, and I noticed one had the Soundblaster front panel, wanted one of these for ages! turned out to be an Audigy 2 ZS!
So what do you, make a video about it!
https://www.youtube.com/watch?v=GcI2DKo2hYI
https://www.youtube.com/@ComputerRetroBus Computer Retro Bus - My Youtube Chanel
Reply 30258 of 31545, by DarthSun
RetroBus wrote on 2025-10-08, 23:15:
No video, just photos, two with Audigy 2 ZS Pro external drive.
The attachment 1- aud2ZSDuo.jpg is no longer available
Reply 30259 of 31545, by RetroBus
Oh Wow! Thats awesome! puts my find to shame 🤣. Those bigger external ones must be even rarer these days, I think I have only ever seen one on marketplace
