Reply 30280 of 31943, by tehsiggi
- Oldbie
ubiq wrote on 2025-10-11, 16:44:I ultimately ruled out the 9700 Pro as the issue and considered the PSU itself to be the problem. I also ruled out CPU thermals as well as the mainboard caps (I recapped the mobo when I got it - yes, it needed it). The powering off issue required physically toggling the physical power switch on the PSU to get it started again. It's a brand new PSU, but of course that doesn't mean it's good. For now, putting the 9700 on its own rail instead of the one driving the HDs seems to have fixed things.
In terms of 9700 Pro care - should I put heat sinks on the ram? If it came to it, I'm probably up to replacing the caps on the card, but the ram would be another story.
I'd always grant the memory on 9700s and 9800s memory heatsinks. The memory gets quite warm and the stock cooler already has bad airflow over the memory. Given that you are cooling it passively, I'd highly recommend additional heatsinks on the memory.
I'd leave the caps as is. Of all 9500s, 9700s and 9800s I had, none of them died / failed due to bad caps.
The 5V rail of your PSU is rated at 20A, which nowadays is sufficient, however that's only 100W. The 9700 will take around 20W of it's 60W from the 5V rail. That leaves you with 80W for the rest of the system. Given that socket 462 boards often rely on the 5V rail for CPU power, you might be a bit in a tight spot here under load. Not sure about your a7v8x-mx.
