Reply 320 of 3533, by sharangad
BEEN_Nath_58 wrote on 2023-11-10, 13:19:
sharangad wrote on 2023-11-10, 13:12:
Why is Speedy3D faster in restart to dos mode? Seems a little weird.
1MHz difference?
Sorry, reading comprehension failure 😀
https://patreon.com/Rready
Reply 321 of 3533, by RaVeN-05
Nominal FIFO performance = 10.6 Mb/sec. ( Equal to DOS , higher than windows)
Nominal DMA performance = 28.1 Mb/sec. (Higher than DOS and WIN)
is raised in RTD against other modes, i didn't find any PCI delay settings in bios, its overclocing.
(some users i saw here , have FIFO performance faster than DMA), so they can start "vquake.exe -nodma" and vquake will uses FIFO instead of DMA access, and vquake will work faster)
Without any overclocks RestartToDOS performs faster, dmatest and vquake timedemos confirm it.
Its common practice of RTD is performing faster than DOS and WIN, RestartToDos get enhanced by Windows . Its hard to find any exact answers now. i somewhere reads about it, very long ago, and used a long time at practice, but its also amazed me on speedy3d performance , i used to think hardware accelerated games unaffected . =0
i believe if someone will have more CPU RAW power they can get better results.
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 322 of 3533, by asdf53
sharangad wrote on 2023-11-08, 06:36:
Would it be possible for someone with a V1000 board to run this:
https://nirvtek.com/downloads/RTest.7z
and post the results?
Here you go, this is my result (Miro Crystal VRX):
Board # 1
Verite ID 0x1
IoBase 0x6f00
MemBase 0xf7000000
MemMappedIoBase 0x0
memSize 4194304
IOBase 0x6f00
BusMaster 0x1
VGA Device 0x1
I noticed that it says BusMaster 1, does that mean it reports bus mastering as enabled? I think the motherboard I'm using does not have bus mastering support. I remember there was some tool from Rendition to test it, and it said bus mastering disabled. I did not try putting it into another PCI slot yet, maybe that will solve it.
Reply 323 of 3533, by sharangad
asdf53 wrote on 2023-11-10, 18:54:
Here you go, this is my result (Miro Crystal VRX): […]
Board # 1
Verite ID 0x1
IoBase 0x6f00
MemBase 0xf7000000
MemMappedIoBase 0x0
memSize 4194304
IOBase 0x6f00
BusMaster 0x1
VGA Device 0x1
Thanks for that. Rredline is supposed to return the bus mastering status. It could be wrong.
I think the tool is "rendition dma test". You could run it again just to be sure. You can grab it from here
https://www.vogonsdrivers.com/getfile.php?fileid=79.
It's the same tool which reports higher figures in reboot to dos mode., as raven-05 points out.
One weird thing that I see is your mem Mapped io base is 0. It should have an address somewhere in vram., at least the v2000s do.
If bus mastering isn't available, then rredline is lying, possibly to maintain app compatibility.
Reply 324 of 3533, by sharangad
RaVeN-05 wrote on 2023-11-10, 16:31:
Nominal FIFO performance = 10.6 Mb/sec. ( Equal to DOS , higher than windows) Nominal DMA performance = 28.1 Mb/sec. (Higher tha […]
Vquake is mostly cpu bound. I think Stefan Podell had something to say about that on usenet. I didn't know about restart to dos being faster. More than 20 years after switching from w98, there's more to learn.
Reply 325 of 3533, by asdf53
sharangad wrote on 2023-11-10, 19:36:
Thanks for that. Rredline is supposed to return the bus mastering status. It could be wrong. […]
Board # 1
Verite ID 0x1
IoBase 0x6f00
MemBase 0xf7000000
MemMappedIoBase 0x0
memSize 4194304
IOBase 0x6f00
BusMaster 0x1
VGA Device 0x1
Thank you for the link, I'll try the tool again next week with some different configurations. The 0 address could be due the Socket 4 motherboard I'm using. It has lots of problems with newer graphics cards, some will not boot or Windows cannot assign resources to it. It wouldn't surprise me if some of these values are abnormal. Next time I will put the card in my newer Socket 7 machine.
Reply 326 of 3533, by sharangad
I don't know whether the null memory mapped port address is an error. Yours is the first v1k board I've seen rtest's output from.
It could very well be normal for that board.
Reply 327 of 3533, by asdf53
I just noticed something interesting. Someone in this thread mentioned that performance improves when rebooting from Windows into DOS mode. I have tested it:
Vquake, booted straight into DOS: 20.3 fps
Vquake, rebooted into DOS mode: 22.0 fps
I then found out that the "dmatest.exe" tool ran from normal DOS says that bus mastering is disabled and DMA mode will not work. But when rebooted into DOS mode, it suddenly says DMA is enabled. I then benchmarked vquake with the "-nodma" switch, and performance drops again from 22.0 to 20.3 fps.
I had noticed this before when I booted into DOS mode and some games felt a bit smoother, but I thought it was just placebo. Turns out that it really does improve performance, in this case by working around a bug that seems to prevent enabling DMA mode.
And what's weird is that the dmatest benchmark gives me:
"FIFO performance 11.4 MB/s"
"DMA performance 10.4 MB/s"
Shouldn't that mean "vquake -nodma" is faster? But according to the timedemo benchmark, DMA mode wins.
And finally, when I run vquake or dmatest from a Windows 95 dos box, they both crash with a page fault exception, and a few seconds later, the computer freezes with a black screen.
Reply 328 of 3533, by sharangad
No fifo performance there I think is speed of executing command buffers; like rendering commands.
Dma transfers is about texture load speeds/memory writes.
Reply 329 of 3533, by sharangad
I'm drilling through the disassembley of dma test and I noticed the app behaves differently depending on the dos version number. It compares int21h func 0x30's return values ax al to 0x4565 or something like that. I'm trying to figure out which version of dos release that and what dosbox returns.
[EDIT] DOSBox staging appears to return 0.0 as the version number (AH=0/minor, AL=0/major, bh =0xFF, bl=0, cx=8)
Oh I also patched r launcher to allow modding the full screen underwater resolution using Raven-5's hack., for a future release. If anyone's interested I can upload it.
[EDIT]
https://1drv.ms/u/s!As-dKk-N73dSlmgkUWeR7nfxbsxE?e=DqUgoC
MD5: 4ffdf997dc1ba2158559cd4673dc21e5
Resolutions up to 800x600 can be selected underwater for vQuake 2 and vHexen 2 for fullscreen mode only (from app specific settings for quake2 and vh2). The game resolution should be at least as high as the underwater res.
The default res for vQuake 2 is 320x240 and vHexen 2 is 320x200.
Reply 330 of 3533, by asdf53
Oh, okay. I somehow assumed that FIFO is a slower, alternative mode that is used when DMA mode is not available.
Reply 331 of 3533, by sharangad
asdf53 wrote on 2023-11-11, 10:51:
It is.
FIFO, first-in first-out. It's how regular commands are transferred I think. In the absence of DMA, fifo will also be used for textures. You're right . This is most probably how fast rendering instructions from a command queue can be transferred to the card and not how quickly it renderers..
For rendering commands, fifo's used always (I think). Someone could probably correct me. I think that's what happens because textures can be copied to vram, rendering commands cannot. Each rendering command gets moved for execution a few at a time.
Could you run this from DOS and tell me what it reports:
https://1drv.ms/u/s!As-dKk-N73dSlmnrUwVfHZMf4Q5s?e=5ImAeR
MD5: b2e417f0637d44b953d93c5e46ffc960
The exe's INT21.exe.
Reply 332 of 3533, by asdf53
sharangad wrote on 2023-11-11, 11:07:
Could you run this from DOS and tell me what it reports: https://1drv.ms/u/s!As-dKk-N73dSlmnrUwVfHZMf4Q5s?e=5ImAeR MD5: b2e417f […]
Sure, here's the result:
return value 10.10
bh 255 bl 0 cx 8
SHR 10h = 0
Reply 333 of 3533, by sharangad
Thanks. I think I can safely assume that dosbox and win98 dos run along the same codepath.
Dosbox returns 0.0 for the version number, like dos 2.0. But "ver" reports version 5.
Neither match the comparand.
Reply 334 of 3533, by Gona
Board # 1
Verite ID 0x1
IoBase 0x6f00
MemBase 0xf7000000
MemMappedIoBase 0x0
memSize 4194304
IOBase 0x6f00
BusMaster 0x1
VGA Device 0x1
Here are Creative 3D Blaster PCI. Both the V1000-E and V1000L-P gives the same resault:
Board # 1
Verite ID 0x1
IoBase 0xfc00
MemBase 0xfb000000
MemMappedIoBase 0x0
memSize 4194304
IOBase 0xfc00
BusMaster 0x1
VGA Device 0x1
Press [ENTER] to close
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 336 of 3533, by sharangad
Quake 2 Res Unlock (Currently capped at 1152x864)
https://1drv.ms/u/s!As-dKk-N73dSlmpZlSqIflqPljGS?e=d2gjvn
MD5: a58a6ba01437899f75adb2db401e7685
Corrects bug with setting vQuake 2 underwate res and unlocks higher native resolutions (but only for vQuake2).
I should really stop pfaffing about with this and stick only to DOS.
Reply 337 of 3533, by Agent of the BSoD
Here's results from my Canopus Total3D V1000L-P.
Board # 1
Verite ID 0x1
IoBase 0xe800
MemBase 0xe1000000
MemMappedIoBase 0x0
memSize 4194304
IOBase 0xe800
BusMaster 0x1
VGA Device 0x1
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | ESS 1688 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 338 of 3533, by sharangad
Yup once again the null MemMappedIoBase.
The other thing is there's only one card. If you run RTest on a v2k, there's a phantom second board with duff values.
[EDIT] I think I have enough samples for the v1k. Thanks guys. It's very consistent.
Reply 339 of 3533, by sharangad
Does anyone know what INT 2Fh, function 0x1686 does?
Dosbox ignores the parameters and returns disk params.
And something similar with IN31h.
It's supposed to be used for communicating with a TSR. But there's no TSR involved here.
is there a TSR which needs to be installed for Speedy3D? If you create a fresh Win98 install on a Rendition system and try to run a game does it run or is there a config.sys element to it?
