Reply 340 of 380, by Joseph_Joestar
mockingbird wrote on 2024-01-28, 18:16:
Now if only I can get WSS to work in KQ6... Heck, I bet KQ6 won't work with a real WSS.
King's Quest VI works fine with an OPTi 82C930 in WSS mode.
Try setting WSS IRQ to 7 and WSS DMA to 1. You may need to reassign some Sound Blaster resources on the CMI8330 for that to work, since those cannot be shared on that chip.
My retro builds
Reply 341 of 380, by mockingbird
Joseph_Joestar wrote on 2024-01-28, 18:26:
Thanks, will give that a shot (will take time to report back, got to switch motherboards -- long story).
(Decommissioned:)
Reply 342 of 380, by appiah4
Marmes wrote on 2024-01-27, 21:51:
Gus pnp + mk8330 with pc midi addon and mccake, you need nothing else!
Thanks for the kind comments!
I have PicoGUS, MK8330+PCMIDI+McCake. And I approve 😀
Reply 343 of 380, by crusher
Absolutely aggree!
With that combination you always have the best sound option a game offers.
Some games sound better with GUS, some with General Midi, some with MT32.
It's also a personal flavour thing. You can vary so much.
Not at last because you can load soundfonts with McCake and that gives you also a different sound.
I love that combi! 😀
I'm using nearly the same setup:
GUS PnP, MK8330 + McCake attached to WT header of MK8330.
I wonder what for you are needing the pc midi addon?
@Marmes
Great work from you and Keropi on the MK8330! I love it 😀
Reply 344 of 380, by appiah4
crusher wrote on 2024-02-06, 13:50:
8330.
You can't use the McCake with MT-32 games that need intelligent move without the PC MIDI addon (or SoftMPU).
Reply 345 of 380, by crusher
appiah4 wrote on 2024-02-07, 07:50:
Ah, I see.
Thanks for the info, appiah4.
I have not yet tested a MT32 game which needs intelligent mode.
I think I will go the software route with SoftMPU then.
Reply 346 of 380, by Joseph_Joestar
So I took my PC Chips M571 motherboard out of storage to test its integrated CMI8330 once again. I encountered a minor issue with the drivers, and decided to document it here, since it might also affect the MK8330. By default, the DOS drivers mute digital CD audio input (SPDIF). There doesn't seem to be any way to change that from the graphical portion of CMMIX.COM.
However, as PARUS discovered here you can type in CMMIX /DIG:M at the command prompt to unmute this input. Once that is done, it seems to persist even after a reboot/shutdown. I'm not sure if the volume of that input can be adjusted, but simply unmuting it was enough to make digital CD audio work, at least in my case.
I've tested this with Tomb Raider and Quake, and it worked great, with both games properly playing their respective CD audio tracks. However, attempting to play a standard music CD using the supplied CDPLYR.EXE utility didn't produce any sound for some reason.
My retro builds
Reply 347 of 380, by Aladim
My MK8330 was shipped mid Dec 2023 to me. It took 2 weeks from Greece to Brazil... and 2 months within the efficient public mail service.
After 2.5 months my MK8330 it finally arrived, and most important, intact!
I just plugged on my Slot 1 test bench (where the Orpheus 2LT was), modified autoexec.bat to run Unisound - and it works on first run, together with the X2GS wavetable. Very happy!
Quick question: on the Orpheus 2LT I am able to have midi out on 330 and the X2GS on 300: I could choose from the game setup which midi device without having to touch the computer.
With the MK8330 and Unisound, is there an option to have both at the same time? Or are we limited because there is just one device to manage midi? If that is possible, how do I setup Unisound?
Kind regards,
Reply 348 of 380, by keropi
wow
at least it arrived safely, so it's something!
on the stock MK8330 there is only one mpu device: the CMI8330 one
on the LT you can have a dual-mpu setup because there are 2 devices: CS4237 + PCMIDI
the only way to have this on the MK8330 is by having the extra pcmidi addon board installed
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 349 of 380, by Aladim
Thanks! That’s what I thought, just wanted to be sure.
I really liked the black board. I know green is the retro way, but the black ones are really cool and slick! Tonight I will play with it a little bit more. Yesterday was just a quick run to chec.
Really glad I got this o e. Very happy owner of the LT and MK8330. Looking forward for you next cool gadget 😎
Reply 350 of 380, by JustJulião
Hi,
I have issues with my MK8330 under Windows. The sound shutters a lot in QII and sound effects keep repeating in Windows in SB16 mode.
I tested with another Win9X installation, the same things happen.
It has the latest drivers (got on PCmidi website).
The problem isn't there with an Audician32 in the same machine.
The system is :
K6-III 400MHz (4x100, stock FSB)
Epox EP-MVP3C2
128 mb of SD-RAM
ATi Mach64 PCI
PowerVR PCX2
Video : https://www.youtube.com/watch?v=4b5ZMuGzbpE
Reply 351 of 380, by Joseph_Joestar
JustJulião wrote on 2024-03-03, 12:19:
What happens if you set WSS as the preferred device for audio playback instead of SB16?
I encountered a similar issue with Quake 2 on my integrated CMI8330 (not an MK8330, just the same chip) but not as severe as what's shown in your video. For me, setting the Quake 2 sound options to "max compatibility" solved the problem.
My retro builds
Reply 352 of 380, by keropi
Hi,
you are having resource conflict(s) - at least from what is shown on the video
this is why the volume ding sample keeps looping
also why is your SB16 address set to 240 ? what exists in 220 and windows allocates 240 to the card?
if you resolve the resource conflicts sound will be good again
Reply 353 of 380, by JustJulião
It seems you were both right.
- I resolved the conflict, thanks for pointing that. I didn't know that a resource conflict could happen without a notification in the device manager. It resolved the sound looping under Windows but not the issue in QII (whether I used SB16 or WSS).
- I don't have the "max compatibility" setting in QII, it's a demo version. So I did what Leileilol suggests here and it did the trick.
Still, that's more bypassing the issue than resolving it and I tested only an handful of games in Windows for now, suggesting that the issue would eventually manifest itself again.
It seems to be quite common with QII on a CMI8330, I hope that little troubleshooting to be helpful to someone in the future. I'll keep the video online with a proper description for that reason.
I'd be curious to see if someone can tell that he played Quake 2 without any issue with that chip. It probably occurs in specific contexts.
Thank you for your help and please let me know if you have any suggestion to resolve the issue.
Reply 354 of 380, by Shponglefan
I was recently trying to use the MK8330 with a DFI ITOX G7S620-N-G motherboard (Intel 865G chipset). Unfortunately the card fails to be recognized by system.
I confirmed the card works by testing with a Pentium MMX 200 system (Intel 430TX chipset). But it won't work with the DFI / 865G motherboard.
I tried disabling a bunch of I/O devices in the BIOS and reserving a handful of IRQ and DMA channels, but to no avail. The test program included with the drivers fails even with just the I/O address.
I have used other ISA sound cards with this motherboard including Orpheus I / Orpheus II, AWE64, GUS Extreme, Yamaha Audician 32 and the PicoGUS. No issues with those cards.
Not sure if this card is just incompatible with this board and/or chipset. Or if there is potentially something else I could try to get it to work.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 355 of 380, by keropi
weird , CMI8330 was used in value-oriented mobos up to pentium3 era
must be a chipset/bios combo incompatibility for some reason or the CMI drivers crapping out?
is the card listed on boot?
what does unisound say?
Reply 356 of 380, by Shponglefan
Tested the MK8330 again tonight.
The card isn't listed on boot, although I don't think any ISA card gets listed by this BIOS on this motherboard.
I tried it with Unisound and the card was detected and initialized. Tested it with a few games including Duke 3D, Dynablaster, Ultima 7, and Crusader: No Remorse and they all worked. Crusader in particular worked with the SB16 option.
The attachment MK8330 Unisound Init.jpg is no longer available
However, trying it again with official drivers and those once again failed to detect and initialize the card. 😒
The attachment MK8330 Mixer Error.jpg is no longer available
Reply 357 of 380, by keropi
so it's the CMI driver that fails for some reason... better than a hardware incompatibility! 😁
Reply 358 of 380, by Shponglefan
I did some more testing, but unfortunately there are still some issues.
First is that Crusader: No Remorse exhibits the same distorted audio during the FMV sequences that I reported for the Orpheus II. The difference is the distorted audio doesn't occur as frequently, which is why I didn't notice it the first time. But it does occur.
The second issue is stereo appears to be reversed. I noticed someone had reported the issue with Duke Nukem 3D using SB16 audio. I have the same issue, plus I also tested Wolfenstein 3D and Doom and stereo is reversed in those games as well.
Reply 359 of 380, by keropi
OK but these are all caused because of how the chip is designed , there is no real cure for these incompatibilities other than patches that "fix" the game drivers
it is interesting though that crusader engine does the same with 2 different chips on different standards
at least duke/doom offer option to reverse stereo when needed
