Reply 37651 of 59858, by pan069
gex85 wrote on 2021-01-15, 10:14:
It probably has, but since this is the only photo that I have of the card, it was hard to find out. But on the upper edge of the […]
debs3759 wrote on 2021-01-14, 23:15:
Has that Tseng card got an FCC ID on it?
But on the upper edge of the PCB there's a model number: 3081. In combination with the "Ara" VGA BIOS chip, it's more than likely to be this FCC ID: https://fccid.io/H3Z3081
However, there's literally nothing to be found on the internet about this card except for the FCC page.
The closest match is the "Optima 1024" card (Ara 3071 with Tseng ET3000), probably the predecessor of the 3081: http://www.amoretro.de/2013/01/optima-1024-mo … -512kb-isa.html
However, it should play along nicely with the 386 board - if it still works at all.
EDIT:
After digging a bit more, I found two eBay auctions for the 3081 and the 3091 card, the latter being almost identical to the 3081.
So there's the 3071 (Photo by Amoretro):
The 3081 (photo found on eBay):
The 3091 (photo found on eBay):
In case this is interesting to anyone. I seem to have, what appears to be, a newer revision of these cards.
The attachment IMG_20190623_154902.jpg is no longer available
Reply 37652 of 59858, by Horun
Nice ! weird it has only one clock crytal.
Reply 37653 of 59858, by bjwil1991
Probably in case the card's inserted into an EISA slot, it'll down clock the GPU to prevent it from overclocking and burst into flames.
But, that's just my guess.
Won this cool looking video card: Intergraph Intense 3D VooDoo
The attachment Screenshot_20210115-201151-061.png is no longer available
Seller's photos:
The attachment Screenshot_20210115-201208-581.png is no longer available
The attachment Screenshot_20210115-201235-303.png is no longer available
The attachment Screenshot_20210115-201250-367.png is no longer available
Reply 37654 of 59858, by canthearu
ok, quick update on the nforce 2 motherboard.
it got through 50h of memtest86, just fine:
The attachment nforce2 - 50h.jpg is no longer available
So onto prime95. Unfortunately, at first it was unstable, with prime95 reporting hardware errors.
Since I am actually overclocking the CPU, that isn't too unexpected. So I've bumped up core voltage to 1.75V (vs 1.65V stock) and it now run for 10 hours no crashes so far.
The attachment nforce2 - prime95.jpg is no longer available
Now, I will leave it for the rest of the weekend, hopefully no more crashes. Then one more update and I'll stop dragging this topic off-topic.
Reply 37655 of 59858, by pete8475
canthearu wrote on 2021-01-16, 01:57:
ok, quick update on the nforce 2 motherboard. […]
Awesome!
Maybe I'm a glutton for punishment but I've been looking at some nforce2 boards on ebay... I just might pick up a brand I've never had before to see if I can actually have a stable nforce2 board for the first time ever.
But then I remember throwing out and smashing so many of those old ones and I end up closing the tab.
aka pete4237.5
Reply 37656 of 59858, by canthearu
pete8475 wrote on 2021-01-16, 02:49:
This particular board was stripped out of an old computer grabbed off the classified (gumtree).
Its a way to get stuff that hasn't been excessively fondled with ... but with the provision that some of it will be broken trash!
Reply 37657 of 59858, by pete8475
canthearu wrote on 2021-01-16, 02:58:
Looks like a great website but unfortunately not much use here in Canada.
aka pete4237.5
Reply 37658 of 59858, by Ozzuneoj
I'm so glad you did this, because I was very tempted to do it myself. Mostly because I love my NF7-S 2.0 system and it has been rock solid for nearly 18 years... I felt like I had to defend its honor or something. 🤣
In all seriousness, I can't explain why some have had such reliability issues with nforce 2 boards while others have not. Lets all just be glad current PCs aren't like they were back in the early 2000s, at least stability wise.
I will say though, this board was a replacement. The first one had a temperature alarm issue out of the box where it would shut down with a "beedoo beedoo beedoo" at startup. I recall reading that it was a known problem with the early boards, and may have been related to overly sensitive voltage or heat protection features when overclocking (which I definitely was... and boy was I a noob). After RMAing it though (maybe twice???) they sent me one that never did that a single time, and has been perfect ever since, even with a heavily overclocked CPU.
Reply 37659 of 59858, by Shreddoc
Ozzuneoj wrote on 2021-01-16, 04:20:
I can explain why my nforce2 board has a reliability issue. 😀
The attachment 20210116_181613.jpg is no longer available
Reply 37660 of 59858, by Ozzuneoj
Shreddoc wrote on 2021-01-16, 05:21:
Mystery solved! 🤣
Reply 37661 of 59858, by mwdmeyer
I did a very expensive thing. Looking forward to it!
Reply 37662 of 59858, by Pierre32
mwdmeyer wrote on 2021-01-16, 06:44:
Oh my. I spent too much time finding a low profile PCI video card for an Aptiva system last year. This has me all sweaty. What kind of system is it going into?
Reply 37663 of 59858, by mwdmeyer
Pierre32 wrote on 2021-01-16, 06:56:
Probably a small form factor compaq P3. I'm very happy about the HDMI port as I don't have space for a CRT monitor and my LCD doesn't do VGA and the adapter I have adds a lot of interference.
Reply 37664 of 59858, by Pierre32
Sweet. I didn't even notice the HDMI. Enjoy!
Reply 37665 of 59858, by Tali
Hi!
Normally I do not post in this thread (that's something I should probably change), but over the last couple years I've acquired quite a few interesting examples. This one isn't particularly special in itself, just a motherboard I need for a project.
But there is a longer story to it. What I wanted to build was a Cyrix/IBM 6x86 PR300, and originally I tried with an OEM board by Asus, the SPAX (pretty much SP-97XV, but one PCI slot less, and with onboard video and audio). It also doesn't cost an arm and a leg, unlike the SP-97. Trouble is, the plan was to use GUS in this build, and not just any kind of GUS, but Extreme. And the board just doesn't allow to disable the inbuilt audio. So what I needed was a similar chipset board (I know it worked with a Cyrix), but with no extras. This one is it. Being extremely yellow is a bonus.
Now waiting for it to arrive and holding my breath it is intact.
Reply 37666 of 59858, by PD2JK
Nice board with a clean lay-out, thanks to the integrated south bridge. No need for a heatsink I presume?
Congrats. 😀
has all kinds of stuff
Reply 37667 of 59858, by PTherapist
Just to add to the nForce 2 debate, I've recently been putting together old gaming builds and the nForce 2 based build was my most troublesome.
Using an MSI K7N2 motherboard, it absolutely didn't like an overclocked CPU, with freezes in games. This board also did not like any AGP Radeon graphics cards, with constant crashes and weird behaviour even just trying to run 3DMark. So I had to put in an AGP GeForce FX instead.
The build now at least runs games, but a couple of specific games cause a BSOD in Windows XP after a few minutes of running, for example - Battlefield 1942 is unplayable and Halo at least caused a BSOD once. CPU doesn't seem to be overheating, everything is clean and no visible bad capacitors on the motherboard either.
I really must try running memtest for an extended period as others have been doing, as I am using dual channel. Running memtest for a short while back when I was having problems did not show up any memory errors.
Reply 37668 of 59858, by Murugan
Got this tank:
Reply 37669 of 59858, by Tali
Murugan wrote on 2021-01-16, 12:09:
Got this tank:
Now that's a sexy case if there ever was one
PD2JK wrote on 2021-01-16, 10:36:
Congrats. 😀
No idea yet, I'm still waiting for the board to arrive. Guess, we'll see when it does. But the SPAX didn't have a heatsink either, so... still no idea 😀
Reply 37670 of 59858, by Murugan
If this drops on you...
Never saw one like this.
I call it Blade Runner :p
