Vogons Video Announcement Thread
Reply 380 of 398, by appiah4
root42 wrote on 2023-11-19, 18:40:
I Broke A Vintage Floppy Drive Motor
My Commodore 8050 drive died two months ago, while being attached to a IEEE-USB interface. It seems the read-head of drive 0 was driven too far. After fixing that issue, I noticed that drive 1 wasn’t formatting disks — again. Suspecting that the DC motor for the drive might have an issue, I wanted to open it up to do maintenance. A bad decision…
https://youtu.be/cC9CUfoK_Go
I read the description of this video and it made me sad enough to not want to watch it.. 🤣! I'll watch it tonight on the way home I think. Cheers!
Reply 381 of 398, by adalbert
How to create Windows 3.11 C++ applications in a relatively easy way (while retaining cross-platform capabilities): https://www.youtube.com/watch?v=d6L272OApVg
Reply 382 of 398, by root42
adalbert wrote on 2023-11-20, 13:03:
It has a happy end. 😁 But I learned what NOT to do, without really proper equipment like mechanical tools...
YouTube and Bonus
Reply 383 of 398, by root42
ZoomFloppy+OpenCBM+8050
The main issue with the Commodore 8050 and 8250 drives is: How do you get data onto them? The units use 100tpi floppy drives that are incompatible to the regular 48tpi and 96tpi disk drives used in the 1541 and in PC DD and HD drives. So there is no chance using those. However there is the ZoomFloppy, which is an implementation of the XUM1541 interface and it comes with an optional IEE488 plug! We can attach the 8050 to that, and use the OpenCBM tools to read and write data to and from the floppies.
https://youtu.be/GhEqdP73-cc
YouTube and Bonus
Reply 385 of 398, by root42
The PicoGUS 2 0
Ian Scott, also known as polpo, has upgraded his Raspberry Pico based Gravis Ultrasound clone to version 2.0. It can now be fully factory assembled, and has WaveBlaster support as well as a new design. Let’s test drive the card and see what it can do!
https://youtu.be/aeejxbaAQ4g
YouTube and Bonus
Reply 386 of 398, by appiah4
I was expecting this B) Bookmarked to watch tonight!
Reply 387 of 398, by RetroGC
HI,
here's my channel, until now all about videogames music . I'm try ing (as this is an hobby for me) to remaster and enhance videogame's soundtrack . Whenever possible, recording process has been done using real (ane sometime modded) hardware instead of emulators.
https://www.youtube.com/@RetroGamesClub
Aldo
My Videogames Music Channel
My Videogames Music Channel Thread
Reply 388 of 398, by root42
Let's Code MS DOS 0x26: AdLib Drum Machine
Programming the OPL2 FM chip on the original AdLib card can be a bit tedious. Join me in this episode to learn how to program the drums on the AdLib card to create a simple sequencer or drum machine. In the future we will also look at the melodic instruments, but for now we try to create some nice percussion!
https://youtu.be/kP2B9a7Btpk
YouTube and Bonus
Reply 389 of 398, by root42
And the second installment is here:
Let's Code MS DOS 0x27: AdLib OPL2 Melodic Programming
We continue our quest to learn the secrets of the AdLib sound card and its Yamaha OPL2 FM synthesizer. Last time we did the drum programming, but this time we learn how to code melodic instruments and how to play notes.
https://youtu.be/y3aihO0pw8A
YouTube and Bonus
Reply 390 of 398, by appiah4
I really appreciate your Assembly videos. I really ought to download and archive them.. They will make a fun retirement project 😀
Reply 391 of 398, by root42
Let's Code MS DOS 0x28: Expanded Memory (EMS)
The original IBM PC and MS DOS could — for the most part — only access 640KB of memory. The LIM EMS standard was at first a standard for RAM expansion cards to overcome this limit. On later machines like the 286 and 386 there was either support built into the chipsets or EMS memory was emulated via drivers like EMM386. Today we learn how to utilize EMS memory to play back an animation that is too large for conventional memory.
https://youtu.be/QS060vSzWLY
YouTube and Bonus
Reply 392 of 398, by Beegle
Following the success of my "additive soundtrack" of Dune (Cryo) in 2015, I follow it up with a 5-device combined version of Westwood's Dune 2 for your listening pleasure.
It's an additive version combining the sounds of PC Speaker, Tandy 3-voice, AdLib, Roland MT-32 and SC-55 all in one, so you get the best of all the versions, and some kind of "orchestra" rendition that makes the music really pop.
https://www.youtube.com/watch?v=k_Mlozm6fZY
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Reply 393 of 398, by darkenedroom
Hi,
This is my retro flight sim channel https://www.youtube.com/@darkenedroom
There are some showcase playlists to show off optimised emulation settings for particular games (very subjective I know) and links on the vids to various blog posts which can be found on my website here: https://www.tales-from-darkenedroom.com/
https://www.tales-from-darkenedroom.com/ - Retro PC gaming on Windows 10, technical aspects, flight sims and space sims a speciality
Reply 394 of 398, by root42
Let's Code MS DOS 0x29: Extended Memory XMS
In the previous episode we learned how to use Expanded Memory even down to the original IBM PC. From the IBM AT and other 286 machines onwards we can use Extended Memory instead. It doesn't require any additional hardware and allows you to use more than 640K of memory in real mode MS DOS programs.
https://youtu.be/EfszIBo7W2g
YouTube and Bonus
Reply 395 of 398, by root42
Let's Code MS DOS 0x2A: Background Adlib Music
We already learned how to program the Adlib sound card to produce percussion and melodic instruments. Now we tackle the problem of getting real music out of it. By utilizing the Reality Adlib Tracker's playback routine we learn how to program the Programmable Interrupt Timer (PIT) in the PC to get a steady playback of background music.
https://youtu.be/9xzwVrOvGuQ
YouTube and Bonus
Reply 396 of 398, by khyypio
I made an an adapter that let´s you install a 60 mm fan to a stock Intel Pentium 4 socket 478 cooler. Link for the 3D model will be provided as soon as Thingiverse let´s me publish it, hopefully tomorrow.
https://youtu.be/xkzoRT0c4uE
Reply 397 of 398, by khyypio
I turned a retro computer speaker set into a pair of nice passive speakers: https://youtu.be/zfZRFzL2uIk
Reply 398 of 398, by khyypio
Glyde: My Voodoo 3 / Voodoo 1 / Orpheus II LT / Sound Blaster Live! build:
https://youtu.be/jsPLQ0QkgfA
