Reply 40 of 62, by RetroSonicHero
wierd_w wrote on 2024-07-03, 01:46:While it is true that NT4 is not plug and play aware (and requires you to have a bios that can allocate resources/init cards for […]
While it is true that NT4 is not plug and play aware (and requires you to have a bios that can allocate resources/init cards for you), and needs old crusty drivers, it is a VERY lightweight version of windows.
With the DX5 pack installed, quite a few early 9x games install and run fine.Most of the complaints about NT4 are about it being "Different" from more modern Plug&Play experiences on say, win9x and win2k. It's important to remember that NT4 predates those OSes, and so such mental models need to be discarded as anachronisms. You wont find a 5 speed transmission on a Model T.
As a general rule, NT4 "Feels Like" Win95A, up until you want to install drivers. Then it "Feels like NT3.5"
If you need DX6 or newer, then yes, go ahead and bite the much higher RAM and CPU needs for win2k. Very solid performer in that era.
It's definitely a case of needing to understand and respect the limitations of the software. NT 4 is great, but it is unfair to compare it to much later NT (and to some extent 9x) Windows versions that solve its biggest problems. Even so, it is very interesting to see what level of hardware you can get away with running on it. The simplistic 95-based shell means it doesn't struggle nearly as much on a lower clocked Pentium as it would in 2000. And if you're using something like a Pentium Pro with a true 32-bit architecture, you'll be in very good shape. I imagine its relatively low system requirements meant that many people ended up using NT4 as a workstation well past the release of 2000, as it was a large boost in hardware requirements.
It honestly is the most stable version of Windows for how lightweight it is. The only thing that would compare is terms of very modest hardware requirements is Windows 9x, which is significantly worse for stability and security .
