EEPROM corruption on Creative cards
Reply 40 of 47, by shevalier
myne wrote on 2025-12-30, 14:32:
shevalier wrote on 2025-12-30, 06:36:
I have never been able to find the datasheet for the 24FС32 from Catalyst Semiconductor (CSI).
As a result of the acquisition of Catalyst Semiconductor by ON Semiconductor, www.catsemi.com has been integrated into www.onsemi.com.
https://www.alldatasheet.com/datasheet-pdf/pd … /CAT24FC32.html
No?
Thanks, you're a genius. 🍻
I also remembered that there were ‘CAT’ microchips, but something didn't click in my head that it was short for ‘Catalyst Semiconductor, Inc.’
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 41 of 47, by myne
🤣 hardly a genius. I literally highlighted "datasheet for the 24FС32 from Catalyst Semiconductor", rightclick,search
I built:
Reply 42 of 47, by Volfer
Hi , don't know if it is correct thread but TL;DR version
After installing WinME via Win98 Quick Install, and putting drivers (yesterday) the card refuses to be recognized.
By the SN it appears to be a non-OEM Audigy 2ZS - currently on initial deployment it is with the expected yellow question marks, but after getting to a driver and control panel install yesterday, today I only get red X or outright the card vanishing from Device Manager/list
Not that it had any audio on the semi-successful install either.
What are the chances the EEPROM has bit the dust.
Attached is the single sticker on the back of the card
The attachment SB0350.jpg is no longer available
Reply 44 of 47, by Volfer
ott wrote on 2026-02-18, 17:31:
Volfer wrote on 2026-02-18, 16:56:
Check the Subsystem ID in WPCREDIT utility - "00FF" value means the EEPROM is corrupted.
Re: EEPROM corruption on Creative cards
Thanks, will check, but had some development that was not expected.
I have a known working Live! SB0060 card that I pulled from a machine on which I literally played Diablo 2 LOD in 2017-2018
It also fumbled around in similar fashion.
The board is Asrock 775i65GV 2.03.
What I did is flash the latest BIOS (3.30) and replaced the CPU that the board came in (P4 631) with a Conroe-L Celeron 450.
After this , the SB0060 is showing (with ? of course cos I wiped the drivers) but seems to not be vanishing, and the game port was properly detected, which was not happening before, nor the FireWire on the 2 ZS
Also I replaced the CMOS battery before the BIOS update just to be on the safe side.
Now I will try with the 2 ZS modified drivers, which seems to be recommended here and by Phil from Philscomputer lab and see how it goes.
Well at least by replacing the Presshot I got silent-er system (its a box 775, and not even from the copper core variant, at least its not the 45nm C2D paper-thin slice of bread)
Reply 45 of 47, by Volfer
775i65G no V
Reply 46 of 47, by songoffall
ott wrote on 2025-06-13, 15:41:
songoffall wrote on 2025-01-12, 07:20:
I'll do some investigating and try things out on my own card, and document the process here.
Any updates?
I want to backup EEPROM of Audigy 2ZS card using CH341A clip, but not sure about success.
I don't think it is doable without removing the EEPROM chip off the board, sadly.
As for updates, I have managed to fix my Audigy2 card, but apparently the issue wasn't EEPROM corruption but damaged solder joints, so I didn't get the opportunity to try EEPROM programing on the card.
Pentium 2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 2.0GHz/GeForce4 Ti4200/Sound Blaster Live!
Core2Duo Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
Reply 47 of 47, by XodiumLabs
So I encountered this thread while trying to troubleshoot a dead Audigy 2 (and used the ROM dump earlier in the thread, sadly, it didn't seem to fix it so I think something more significant is wrong with it.
However learning about this problem with sound card EEPROMs prompted me to get my working Audigy 2 ZS (SB0350) out and get a dump from it. I haven't tested it because I was kinda having a losing streak that night and didn't want to chance wrecking the card, but...here it is. Captured it with my T48/Xgpro 13.16.
Shuttle SB61G2: 3.2GHz P4 Northwood | GeForce 6600GT | Audigy 2 ZS | Windows 98 SE
Big 98 Box: 3.2GHz P4 Northwood | FX 5950 Ultra | no sound card (it's in the Shuttle) | Win98 SE
WinXP Shuttle: -work in progress-
