First post, by songoffall
- Member
So apparently Creative cards using the 93C46 EEPROM have a bug that causes the EEPROM chip to blank itself. I have observed it on a Creative Audigy 2 card, and can only theorize why it happens.
Looking at the documentation for ATMEL 93C46, the chip has self-timed write functionality, so once it gets a write command, it runs an erase cycle. Maybe the card by mistake sends something to the chip that is interpreted as a write command.
Here's the documentation I'm referencing:
https://ww1.microchip.com/downloads/en/devicedoc/doc5140.pdf
In my case, the card is mostly functional, and while the setup program claims no Creative card has been discovered on the system, the driver installer successfully installs the VXD drivers.
I may have also discovered the solution, on a Russian website with an unsecured connection. Proceed at your own risk.
https://www.sblive.narod.ru/BAD_MEM_RETURNS/B … MEM_RETURNS.htm
I'm planning to translate the text on the Russian site, full credit goes to its authors, archive the ROM files on the page, in case it goes down, and I wonder if I could attempt the repairs described there.
P2 300MHz/Matrox Mystique/Sound Blaster AWE 32 Value
Pentium 3 733MHz/3dfx Voodoo 3 3000/Aureal Vortex 2 (Diamond Monster Sound)
Pentium 4 HT 3.0GHz/GeForce FX 5500/Creative Audigy 2
Core2 Quad Q9400/GeForce 8800GT/Creative X-Fi Titanium Fatal1ty
