Getting a MFM drive to run
Reply 40 of 69, by Grzyb
Half-Saint wrote on 2025-09-17, 10:44:
The difference between type 17 and stason is just landing zone 977 vs. nothing. I switched to using type 17.
It doesn't matter - MR535 uses voice-coil = auto-park.
I did as you guys suggested and managed to boot from a floppy into DOS. Was surprised to see that I can access C: fine. I don't know why the system won't boot. I tried running sys a: c: and despite DOS saying "System transferred", it still says "Non-system disk or disk error replace and strike any key when ready" at boot.
"SYS A: C:" only affects the C: partition.
There may still be some garbage in the MBR - you can try "FDISK /MBR", and make sure the partition is set Active.
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
Reply 41 of 69, by Half-Saint
I tried "fdisk /mbr" but that didn't help so I tried to format the hard drive via "format c: /s" but got an error "Invalid media or Track 0 bad - disk unusable".
So something is obviously wrong with the hard drive. Hopefully LLF will help.
Reply 42 of 69, by Half-Saint
Success! I low-level formatted the drive, ran FDISK from a DOS floppy, created a FAT32 partition, formatted the drive with /s parameter and was able to boot into DOS successfully afterwards 😀
Thanks to everyone that helped!
Reply 43 of 69, by chrismeyer6
Run a scan disk and see if there are any bad sectors. But awesome work getting the drive working again.
Reply 44 of 69, by Grzyb
Half-Saint wrote on 2025-09-17, 15:05:
I think it's FAT16.
Is it even possible to create FAT32 on such a small disk?
Anyway, now you can experiment a bit, and find the optimal interleave factor for that system...
Reply 45 of 69, by Grzyb
chrismeyer6 wrote on 2025-09-17, 16:57:
First and foremost, during LLF, it's a good idea to enter the bad sectors listed on the sticker.
Some sectors were weak already at the factory, and they will cause random errors - even if tools like SCANDISK may sometimes fail to detect them.
Reply 46 of 69, by Half-Saint
Grzyb wrote on 2025-09-17, 18:27:
Yes, it's FAT32. FAT16 wouldn't let me create a partition bigger than 32MB.
BIOS LLF tool won't let me enter bad sectors, I can only mark the whole track which is a bit of a waste. I also found recommendations online NOT to mark bad sectors during LLF as they will show pu during FORMAT or SCANDISK will find them.
Anyway, according to the factory sticker there are two bad sectors.
Reply 47 of 69, by Grzyb
Half-Saint wrote on 2025-09-17, 21:56:
FAT16 supports up to 2 GB.
What DOS version are you using?
Reply 48 of 69, by mkarcher
No, it's not FAT32. FAT32 is FAT with 32-bit cluster numbers, a format introduced with an OEM service release of Windows 95.
You are using FAT16 with 32-bit sector numbers. This is partition type 6 (called "BIGDOS" by the classic Norton Utilities). This type has been introduced with the enhanced Compaq OEM version of MS-DOS 3.3 called Compaq MS-DOS 3.31, and also exists in vanilla MS-DOS since MS-DOS 4.0. There is no need to use 32-bit cluster numbers on your partition, as the CHKDSK output clearly shows that you only have around 20.000 clusters, which perfectly fits into 16 bits.
Reply 49 of 69, by Half-Saint
mkarcher wrote on 2025-09-17, 22:07:
Pardon my ignorance, haven't had to deal with FAT16 for about 30 years. I should have worded my reply differently - I remember not being able to make bigger partitions in DOS 3.3 that my parents PC used back in the 80s (I know DOS version because I still have those 5,25" boot disks somewhere). All I had at hand was one DOS 6.22 boot disk so I used its FDISK utility to partition the HDD etc.
Reply 50 of 69, by mkarcher
Half-Saint wrote on 2025-09-17, 22:25:
This makes perfect sense. There are two variants of FAT16 partitions: FAT16 with 16-bit sector numbers, which are supported since MS-DOS 3.0, and FAT16 with 32-bit sector numbers, is supported in MS-DOS 3.31, but not yet in DOS 3.3. Actually, there is absolutely no difference in how the FAT16 file system works, but MS-DOS 3.3 does not support partition sizes above 32MB at all (becuase that's the maximum size you can address with 16-bit sector numbers in a partition, and DOS 3.3 internally uses 16-bit numbers to identify sectors in a partition), so MS-DOS 3.31 introduced a new partition type for bigger partitions to prevent MS-DOS 3.3 to damage partitions that are too big to be handled by that system.
EDIT: Removed the wrong claim that FAT16 was introduced at the same time as hard disk support.
Reply 51 of 69, by weedeewee
mkarcher wrote on 2025-09-17, 22:49:
This makes perfect sense. There are two variants of FAT16 partitions: FAT16 with 16-bit sector numbers, which are supported since MS-DOS support hard drives, that is MS-DOS 2.0, and FAT16 with 32-bit sector numbers, is supported in MS-DOS 3.31, but not yet in DOS 3.3. Actually, there is absolutely no difference in how the FAT16 file system works, but MS-DOS 3.3 does not support partition sizes above 32MB at all (becuase that's the maximum size you can address with 16-bit sector numbers in a partition, and DOS 3.3 internally uses 16-bit numbers to identify sectors in a partition), so MS-DOS 3.31 introduced a new partition type for bigger partitions to prevent MS-DOS 3.3 to damage partitions that are too big to be handled by that system.
FAT uses cluster id, not sector id, right ?
Do not ask Why !
Reply 52 of 69, by Grzyb
FAT16 was introduced in DOS 3.0.
DOS 2.x only supports FAT12, for both floppies and HDDs.
See also: DOS 3.00-3.30 limits, with a riddle
Reply 53 of 69, by mkarcher
weedeewee wrote on 2025-09-17, 22:59:
It's true that the FAT filesystem internally uses cluster numbers for managing its data. But the FAT filesystem driver reads and writes sectors by passing sector numbers to the partition driver (INT 25/INT 26), and this interface is limited to 16-bit sector numbers in MS-DOS before 3.31.
Reply 54 of 69, by jakethompson1
mkarcher wrote on 2025-09-17, 23:11:
So is the on-disk format exactly the same, and the new partition type is to just to stop truncation of sector numbers on pre-DOS 3.31 attempting to access it, from massively corrupting the filesystem?
Reply 55 of 69, by mkarcher
jakethompson1 wrote on 2025-09-17, 23:15:
Nearly the same. I omitted one detail for brevety. The classic FAT parameter block, which is part of the boot sector, includes a field called "total sector count", which is a 16-bit field. If a FAT paratition contains more than 65535 sectors, this field is zero, indicating that a new field (at an offset that was previously not part of the parameter block) contains a 32-bit sector count. Apart from the different field for the sector count, the on-disk format is exactly the same.
Reply 56 of 69, by Half-Saint
Well, if I can't mark individual sectors, what do I do? Is there some other software I can use?
Reply 57 of 69, by Grzyb
The official way was to mark everything listed on the sticker during LLF.
But if you insist that it's wasteful, you can simply run SCANDISK several times - hopefully it finds all the weak spots, and marks bad clusters.
There's also plenty of third-party software for that, eg. Norton Disk Doctor from the Norton Utilities - but I doubt if they are any better than SCANDISK.
Reply 58 of 69, by Deunan
NDD and SCANDISK are good but for an unknown drive that old I would run a full pass of SpinRite. For MFM I'd suggest SpinRite II v2.0, newer ones are more tailored for early IDE and even SCSI and might miss some weak sectors.
Note that takes time, if you can transplant the controller and HDD to a fast 486 or better mobo for that. If you can't it might take half a day to run a full Level 4/5 pass.
Reply 59 of 69, by Half-Saint
So I checked and the partition is indeed FAT16.
I'm not sure I fully understand the sticker on the label. What does HD stand for? Platter? Track?
As I said, BIOS LLF utility only gives me the option of marking the whole track as bad. How would that translate to the data on the sticker? First column but that would mean Track 0 is bad out of factory which sounds like nonsense.
Deunan wrote on 2025-09-18, 09:47:
I don't particularly care about data integrity on a drive from 1989. It's not like I'll be saving important files there. Do you reckon it will be stable enough, if I just run it through SCANDISK? Getting the drive to work was the fun part. I'm not yet sure what I want to do with it as I have plenty of bigger and faster IDE drives in storage.
Would this be good enough: REMOVED LINK TO COMMERCIAL SOFTWARE AT SO CALLED "ABANDONWARE site" ?
