cant coppy onto floppy drive
Reply 40 of 47, by DaveDDS
Ok, I just fired up XP (SP3) in a virtual machine, went to where DOSBOOT.ZIP is located:
- Double click DOSBOOT.ZIP (open display of files in DOSBOOT.ZIP)
- Right-click DSKWRITE.EXE -> Copy
- Go up a level (back to where I can see DOSBOOT.ZIP)
- Right-CLick where no file gets selected -> Paste (DSKWRITE.EXE appears in this directory)
- Double-click DSKWRITE.EXE (DSKWRITE runs and prompts you to select an image)
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filecopy(w/o netSW)via Lan/Lpt/Com
Reply 41 of 47, by Im from Windows
NeoG_ wrote on Today, 13:55:
Im from Windows wrote on Today, 13:52:
There are 4 options showing a disk. again please see attachment
The word "Disk", in the top menu
OK I selected the write to disk at the bottom of the drop down menu of Disk
Am I good to go then?
Thanks
Reply 42 of 47, by Im from Windows
DaveDDS wrote on Today, 13:55:
When posting screenshots of files like this when seeking help with them, it's worth turning on the display of extensions and sizes (things I always keep turned on in my systems)
Reply 43 of 47, by Im from Windows
DaveDDS wrote on Today, 14:07:
I'm not sure exactly what you are doing ... my DOSBOOT.ZIP archive contains a bunch of DOS boot disk images, as well as some too […]
Im from Windows wrote on Today, 13:49:
I just downloaded it thanks! after abstracting the file to my chosen folder (compressed zipped files) it looks identical to the other one that I downloaded before in the above screenshots
I'm not sure exactly what you are doing ... my DOSBOOT.ZIP archive contains a bunch of DOS boot disk images, as well as some tools for working with them:
W:\SITE\DNLD> ZDIR DOSBOOT.ZIP
2026-04-24 16:49:04 8362 _DOSBOOT.TXT
2026-04-24 16:49:04 1474560 CALDERA.IMG
2026-04-24 16:49:04 17408 DSKWRITE.EXE
2026-04-24 16:49:04 6776 FDI.COM
2026-04-24 16:49:04 3234 FDI2ISO.COM
2026-04-24 16:49:04 1474560 FREEDOS.IMG
2026-04-24 16:49:04 327680 MSDOS112.IMG
2026-04-24 16:49:04 368640 MSDOS211.IMG
2026-04-24 16:49:04 1474560 MSDOS331.IMG
2026-04-24 16:49:04 1474560 MSDOS400.IMG
2026-04-24 16:49:04 1474560 MSDOS500.IMG
2026-04-24 16:49:04 1474560 MSDOS622.IMG
2026-04-24 16:49:04 163840 PCDOS090.IMG
2026-04-24 16:49:04 163840 PCDOS100.IMG
2026-04-24 16:49:04 163840 PCDOS110.IMG
2026-04-24 16:49:04 368640 PCDOS210.IMG
2026-04-24 16:49:04 368640 PCDOS300.IMG
2026-04-24 16:49:04 1474560 PCDOS330.IMG
2026-04-24 16:49:04 1474560 PCDOS71.IMG
2026-04-24 16:49:04 1474560 PTSDOS.IMG
2026-04-24 16:49:04 3302 XDISK.COM
W:\SITE\DNLD>
The one you want is DSKWRITE.EXE
I downloaded and installed "DOSBOOT" there was no .img or .exe to it or anything. though it downloaded as a zip so it was "DOSBOOT.ZIP" I downloaded
Reply 44 of 47, by Im from Windows
DaveDDS wrote on Today, 14:28:
Ok, I just fired up XP (SP3) in a virtual machine, went to where DOSBOOT.ZIP is located: […]
It runs the command prompt for 1/2 a second then closes down. Nothing further
Reply 45 of 47, by DaveDDS
Im from Windows wrote on Today, 14:54:
DOSBOOT doesn't "install" - it's just an archive of a collection of files (which happens to include DSKWRITE.EXE and a bunch of .IMGs for various DOS versions)
I really don't know what you did
Just to confirm, I've just downloaded DOSBOOT.ZIP from my site to my R:\ drive and double-clicked to open it - see attached screenshot.
Reply 46 of 47, by DaveDDS
Im from Windows wrote on Today, 14:58:
Then I "dragged" DSKWRITE.EXE from the right window showing the content of DOSBOOT.ZIP to the left window showing R:\ (my RamDrive)
and double-clicked DSKWRITE.EXE in the left window.
Reply 47 of 47, by DaveDDS
Im from Windows wrote on Today, 14:51:
When asking for help manipulating files, it's a good idea to accurately describe those files - this include things like exact name and extension, and exact size.
To always display extensions, you go to ControlPanel -> FolderOptions -- and uncheck "Hide extensions for known file types"
In XP, right-click the "Title" bar (which will at least say "Name") and you will get a list of additional information you can choose to display (or not).
