New to MS-DOS 6.22)
Reply 41 of 67, by ModernMan
wierd_w wrote on 2026-07-16, 20:47:
Uhm. That's a DB9. It's a serial port. Like it says on the tin. […]
Old PCs had these, and they looked like this.
Serial-port-on-laptop-2.jpg?q=49&fit=contain&w=750&h=422&dpr=2
A serial packet driver, or a serial terminal program, could use it like it was an oldschool serial modem.
It even supports the hayes AT command set.
Sorry that is not on my MB. I do however have a pink female 26 pin port, if I can do anything with that. I mean if they make one for that, that is?
Reply 42 of 67, by ModernMan
douglar wrote on 2026-07-17, 13:32:
First you want to locate the config.sys file if one exists.
If you are booting from a floppy, it is going to be on the floppy, A:
If you are booting from a fixed storage device, it is going to be on the fixed storage device C:
To be honest I dont really understand any of it. image attached
Reply 44 of 67, by douglar
ModernMan wrote on 2026-07-18, 14:20:
douglar wrote on 2026-07-18, 12:53:
Here is a thread where someone made bootable floppy images with usb support
Custom made DOS boot floppies that support USB Flash stick / USB CD/DVD drives
So you are saying that the file in question needs to go on a USB stick and booted from USB while running DOS right?
What device has DOS installed on it? A Floppy disk, a fixed drive, or a USB drive?
Reply 45 of 67, by ModernMan
douglar wrote on 2026-07-18, 19:23:
It was a hard drive C
Reply 46 of 67, by NeoG_
This thread is crazy, what is getting the flash portion of a modern USB cellular device going to do in DOS 6.22? Absolutely nothing
Reply 47 of 67, by douglar
NeoG_ wrote on 2026-07-19, 00:30:
I think the OP is just trying to get a USB microSD card reader to work so he can transfer files and has a really hard time describing what he's trying to do.
Reply 48 of 67, by Jo22
douglar wrote on 2026-07-19, 00:35:
Oh. I've used to use an old Windows utility for that: HP USB Disk Storage Format Tool
Supported MS-DOS 6.2, 7.x and FreeDOS I think.
Oddly, it only needed to be pointed to the DOS system files.
It already knew the bootloader code for these DOSes.
This was from a time before Rufus had existed, of course.
It was intended to have bootable USB pen drive with DOS for performing firmware upgrades etc.
Reply 49 of 67, by feda
This has to be a troll, just like that Epstein pic guy.😁
Same crazy misspellings and ineptitude. In fact, didn't the Epstein guy stop posting right before this one created his account? Hmm...
Reply 50 of 67, by NeoG_
I recommend the ModernMan provide some clarity on what they are trying to achieve before you spend a bunch of time on it
Reply 51 of 67, by feda
Yup, I was right. This individual previously posted similar nonsense under "Im from Windows".
Both happen to have a user folder simply called "a" Re: cant coppy onto floppy drive
Both are posting 800x600 screens from XP and have a Pentium 4 🤣
Care to explain, ModernMan?
Reply 52 of 67, by NeoG_
feda wrote on 2026-07-19, 02:15:
Yup, I was right. This individual previously posted similar nonsense under "Im from Windows". Both happen to have a user folder […]
$5 on forgot password and couldn't figure out how to reset it, or they completely forgot they even had an account
Reply 53 of 67, by RetroPCCupboard
NeoG_ wrote on 2026-07-19, 01:53:
Several people have asked, but the OP doesn't appear to respond to those messages. Not only that but has been quite rude to people in responses. My money is on this being a prank.
Reply 54 of 67, by ModernMan
yes yes all of that and more
As i said on page 1, want to write some letters up (and JPG files too) save to USB stick and load them up in the library from USB stick then print them off
Reply 55 of 67, by ModernMan
Jo22 wrote on 2026-07-19, 01:24:
Oh. I've used to use an old Windows utility for that: HP USB Disk Storage Format Tool Supported MS-DOS 6.2, 7.x and FreeDOS I th […]
I do happen to have a copy of reulers and as i recall it is for burning to USB so as to boot from USB. I take it that this is what you want me to do with said file in question right, burn to usb then boot the usb stick in DOS???
Reply 56 of 67, by ModernMan
No no no you are deeply mistaken!
Reply 57 of 67, by ModernMan
I have just tried burning to USB with Ruflers,
Ruflers is for ISO. the file in question is a system type file. It dose not work!
Reply 58 of 67, by RetroPCCupboard
ModernMan wrote on 2026-07-19, 22:14:
Ok. But why use MS-DOS for that? You clearly have XP, which would support Microsoft Word for Windows for better features and compatibility with library computers (and also built-in USB support).
I know that there is a trend right now for distraction-free writing by using an offline basic computer. Is this your goal?
https://youtu.be/H10x_n0zt_I?si=Tvd4catW7xaXUc1T
Reply 59 of 67, by feda
His goal is to troll the users of this forum using multiple accounts.
