Reply 40 of 41, by Mike1978
red-ray wrote on 2026-09-09, 15:53:Strange, it's OK on NT4, maybe it's too new for W95A. What happens with the attached? Do all the missing .DLLs load? […]
Mike1978 wrote on 2026-09-09, 15:24:The font you shared previously wouldn’t load and was saying corrupted when I tried to add it.
Mike1978 wrote on 2026-09-09, 15:24:it takes a few minutes to launch as you may imagine it’s working hard.
I wanted to attempt to skip some of the hardware not present.I doubt doing -NOACPI -NOPCI -NOSMB will make much difference, either way if there is a lockup I would prefer to fix it.
If really needed I would do SIV32L -NOACPI -NOPCI -NOSMB then Menu->File->Save Selected as this would mean the SIV start-up + per section times would be in the save file.
Mike1978 wrote on 2026-09-09, 15:24:Actually yes I do have a couple of MCA systems but I’m a little time limited to do exhaustive testing.
Looking at your profile I guessed as much. AFAIK SIV has never run on an MCA system, I suspect/hope it does OK.
Ray
Full run - i installed the fonts and they appeared to work - do you need the additional cpu check as well ?
