Reply 40 of 40, by Mondodimotori
- Member
Warlord wrote on Today, 18:01:14 and 15 irq should not be legacy isa, both need to be pci/isa. Disable usb and don't assign irq for it if you don't need it […]
14 and 15 irq should not be legacy isa, both need to be pci/isa. Disable usb and don't assign irq for it if you don't need it, it could be irq sharing with the nvidia card. video bios cacheable and video ram cacheable should be enabled those boost performance.
what could be happening i dont know is setting irq 14 and 15 to isa, forces the ide controllers on to 10 and 11 along with the usb controller and the vga card which is not good.
IRQ Standard Assignment NotesIRQ 0 System Timer Internal Intel 8253/8254 timer; cannot be reassigned.IRQ 1 Keyboard Controller PS/2 or AT keyboard interface; cannot be reassigned.IRQ 2 Cascade to Slave PIC Routes signals from IRQs 8–15 to the Master PIC.IRQ 3 Serial Port 2 (COM2) Often shared with COM4.IRQ 4 Serial Port 1 (COM1) Often shared with COM3.IRQ 5 Parallel Port 2 (LPT2) / Sound Card Default choice for legacy ISA sound cards (e.g., Sound Blaster).IRQ 6 Floppy Disk Controller Dedicated to floppy disk drives.IRQ 7 Parallel Port 1 (LPT1) Primary printer port; occasionally used as an alternate sound card IRQ.Slave PIC (IRQ 8–15)IRQ Standard Assignment NotesIRQ 8 Real-Time Clock (RTC) Internal CMOS clock; cannot be reassigned.IRQ 9 Redirected IRQ 2 / ACPI Software-redirected to replace IRQ 2; used for ACPI on newer chipsets or open for peripherals.IRQ 10 Available (Open) Commonly used by SCSI adapters, network cards (NICs), or USB controllers.IRQ 11 Available (Open) Commonly used by SCSI adapters, NICs, or video cards.IRQ 12 PS/2 Mouse Available for peripherals if no PS/2 mouse is installed.IRQ 13 Math Coprocessor / FPU Handles floating-point unit errors; cannot be reassigned.IRQ 14 Primary IDE / ATA Channel Controls primary hard drives and optical drives.IRQ 15 Secondary IDE / ATA Channel
Great! Thank you for the detailed answer, I'll test these modifications to BIOS tomorrow evening and I'll let you all know.
I've also disabled parallel and serial ports alredy, will do the same with USB, since it's 1.0 and quite pointless to use. I may put a network card in it and run an FTP server of my NAS (it's isolated from the internet).
But shouldn't this issue present itself with all GPUs instead of escalating from one GPU to the other?
Intel486dx33 wrote on Today, 19:26:I am pretty sure I was running windows 95 on my Celeron CPU’s build.
I also had a AMD k6-2@300 mhz build running windows 95
These were popular with budget Gamers.
I have yet to install the OS since I lack a free flopy drive and cable, it should be coming soon though, and I was thinking more and more about 95 since it has pretty good compatibility with DOS games loading from inside it and, if needed, booting directly into DOS mode.
