Oh, come on... that card is not "that bad" at all. I have to defend it a little bit 😜 Of course is not as fast as it should have been but at least some games are working on it 😁
First of all I do not reccomend running that card on Windows 2000/XP - Works much faster and without so many rendering errors on 98/ME.
All in all it is FASTER then ANY Savage 4 😉 Want some proofs? I have made a comparison.
My testing machine:
- Abit ST6
- Pentium 3 1400 MHz (Tualatin 512)
- 512MB RAM
- Windows ME
Cards being tested:
- Savage 4 EXTREME 32MB AGP (Diamond Stealth III S540 XTRM)
- Savage 2000 32 MB AGP (Diamond Viper II Z200)
Benchmarking software:
-3D Mark 99
-3D Mark 2000
-3D Mark 2001se
-Quake 2 16 bit
-Quake 3 32 bit maximum details
In order to set the cards on AGP 4X I capped all 3 jumpers and used non DIAMOND drivers...
I have to admit that both cards are quite good at overclocking.
Savage 2000 runs at default clocks:
GPU - 125 MHz
RAM - 143 MHz
I have managed to go up to:
- 152 MHz for GPU and
- 172 for RAM
The card was stable and showed no artifacts at those speeds and I still could push it a little bit higher.
MY Savage 4 EXTREME runs at default speeds:
GPU - 160 MHz
RAM - 155 MHz
I know that there are faster versions, so I overclocked it way above the "standard" EXTREME versions:
- 185 MHz GPU
- 180 MHz RAM
Those speeds were at the edge of it's limits, when I gave 2 MHz more I got errors and the card was not stable.
So, let's see what results I got on 3D Marks first:
We can see that Savage 2000 is faster in 3D Mark 99 and 2000 at default speeds. It got a little bit worse in 3D Mark 2001SE but I think it is because of the Processor's speed. I assume that If I used a slower processor then the results would be better for Savage 2000.
The thing does not change when the cards are overclocked. Still Savage 2000 is better in 3D Marks 99 and 2000 but slower in 2001se, but this time the difference is smaller.
Lets go to Quake 2 now:
This time Samvage 2000 is the winner in every case 😉 One can see that even when Savage 4 is overclocked it is still slower than Savage 2000 on default speeds. The test was done in 16 bit mode.
And finally Quake 3 Arena:
Here things are not so simple. At first we see that Savage 4 is faster at default speeds in comparison to default Savage 2000. But when Savage 2000 is overclocked than it is better than overclocked Savage 4 😁 The game is even fully playable at higher resulutions with maximum settings on both Savage 4 and Savage 2000 when overclocked.
Thanks for attention, I hope you have enjoyed it 😉
