Xi 8088 by Segey Kiselev
Reply 40 of 624, by stamasd
Shorting +5V to GND shouldn't theoretically damage any of the ICs. The power supply, maybe. The jumper itself, probably. Some power traces on the PCB, possibly. Inspect the PCB carefully for any burned out traces.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 41 of 624, by keenerb
There's a trace from C31 to speaker pin 4 that's discoloured. The jumper itself certainly. Another SBC works fine on the backplane, so power supply and backplane are possibly still OK.
Other than that everything looks OK-ish.
Reply 42 of 624, by stamasd
Well then perhaps you didn't manage to kill it yet. Don't worry, I'm known for making mistakes just like this. Once I managed to plug a 4-pin molex connector into a HDD upside-down. The magic smoke escaped. 😀
BTW that is probably a design mistake on the board. You shouldn't be able to casually jumper Vcc to GND.
I/O, I/O,
I/O, I/O
Reply 43 of 624, by keenerb
Yeah I wasn't overly dismayed, I know shorting to ground isn't necessarily fatal but nobody wants to see their hard work emitting smoke.
Reply 44 of 624, by keenerb
Allrighty, I'm still unable to flash the file. It complains that "the bios128k-2.0.bin file is empty!" even though it's just the plain old downloaded file.
Very annoying.
I don't believe the XT-IDE board will present more than 32kb anyway; I'm not sure if it's possible to split the bios and have it fit into one 32kb segment...
Reply 45 of 624, by BloodyCactus
i flashed my 128k v2+xtide bios tonight in my g840. I'm missing ONE chip 🙁 aaargh.
mouser sent me a 74F112 instead of a 74F11.... sigh. i need to buy a single 60c chip 🙁
Reply 46 of 624, by keenerb
Yep I literally have nothing capable of flashing this ROM. Went through my entire stack of motherboards and not a single one has a 32-pin socket. Only a few ISA NICs that aren't supported by flashrom.
Anybody have any suggestions as to a cheap SST39SF-compatible flash programmer?
It DOES appear that only 32kb of the rom actually contains any data, the bits from 8000h to FFFF. If I split the rom on 32kb segments, I'm able to isolate just that code and flash, but it still doesn't boot.
I expect it may be a ROM checksum issue now? Why does the rom seem to use FF for blank space rather than 00?
Reply 47 of 624, by BloodyCactus
Its probably to do with that its FF because when ram is not present, you get an FF on the bus because the lines are pulled high by default.
Reply 48 of 624, by stamasd
I have a TL866 USB programmer; not very cheap (~$40-50 depending on variant and how many adapters it includes) but very capable. Search for "MiniPro" or "TL866" on Amazon, ebay etc.
I would offer to program your chip for free but I'm going away on vacation in a few days. If you think you can mail it to me so that it gets here before Monday, I'll be glad to do it (zip code 06612)
I/O, I/O,
I/O, I/O
Reply 49 of 624, by keenerb
Coincidentally enough, I ordered one of those immediately after I made that post.
http://www.ebay.com/itm/111870509772?_trksid= … K%3AMEBIDX%3AIT
Seemed like a good idea, there have been several situations where having one would have saved me some additional $$$.
Reply 50 of 624, by stamasd
Yes, it's been a life-saver in a few situations. The 866CS that you ordered doesn't have an ICSP header (mine does, but it cost about $10 more). I never used the ICSP port but it's nice to know it's there just in case. I think there are instructions somewhere on the web on how to mod a 866 to add the ICSP port.
I/O, I/O,
I/O, I/O
Reply 51 of 624, by keenerb
Hopefully this puppy fires up OK, and I didn't irreparably damage any important bits. The V20 and Flash chip are OK at the very least, I was able to test those out...
Reply 52 of 624, by keenerb
I didn't think to check before, but I hope it supports the BIOS chips on my Tandy 1000TL/SL. I've been wanting to dump those and see about upgrading the on-board DOS...
Reply 53 of 624, by stamasd
The official support page is at http://autoelectric.cn/EN/TL866_main.html Includes a list of supported chips. It's been updated with new firmware and software releases quite regularly for the past 2 years or so.
I/O, I/O,
I/O, I/O
Reply 54 of 624, by keenerb
Should have known better than to try to save $10 on Ebay. They're telling me I won't get it until after July 4th.
Should have used Amazon Prime...
Reply 55 of 624, by BloodyCactus
so, got my last chip today!
no psu tho.. so time to break out the bench top psu's and rig up a +12 +v...
hmm I get a 5 note startup tune.. keyboard lights flashed.. I can ctrl-alt-del reboot..
lots of faffing with switches...
Eventually I pulled the psu from my industrial shoebox wired it up and
so something wants the -12 or -5 (could be my video card.. who knows)...
the strange thing now is, keyboard ctrl-alt-del wont reboot it! 🤣.
anyways.. since I flashed the XTCF-LITE version of the bios, I guess I now need to build the card!
once I get it into a more permanent home than the backplane just sitting on the bench I'll see how it goes.
seems to bootup fine with turbo on as well, with a 24mhz osc, thats 8mhz!
note to self, buy cr2032 battery tomorrow.
Reply 56 of 624, by stamasd
It's alive!
I/O, I/O,
I/O, I/O
Reply 57 of 624, by keenerb
Meanwhile, my programmer has been sitting in a DHL Global Mail shipping faciilty in Compton, CA for five days.
I honestly wouldn't have thought it POSSIBLE to ship something cross-country this slowly.
Reply 58 of 624, by BloodyCactus
tried the 40mhz oscillator, which would be about 15mhz, xi8088 would post (play its 5 note song) but the VGA card would not come up. I need to grab some bits from Mouser for the XT CF IDE-LITE card so I'm going to grab a 36mhz osc, which should be 12mhz turbo and see how it goes. turbo at 8mhz seems fine tho.
Reply 59 of 624, by stamasd
I never, ever use DHL. For many reasons - this being one of them.
I/O, I/O,
I/O, I/O
