8-bit sound card on FPGA
Reply 40 of 45, by Tiido
Such things are normally run at tens of MHz speeds, the higher the theoretically better resolution is possible but analog factors start getting in the way rapidly.
Reply 41 of 45, by newold86
Scali wrote:
newold86 wrote:
I use the world's simplest DAC (ONE resistor and ONE capacitor - that's all) to convert that digital one-bit signal to analog sound.
That's interesting. Sounds like how the PC speaker circuit is constructed. How exactly do you drive this? You have a high-resolution timer? What frequency does it run at?
First of all, there is a simple explanation of the technology - https://www.fpga4fun.com/PWM_DAC_3.html, I'm using a circuit #3. In my case the clock frequency is around 50MHz.
P.S. Do you know any software that runs on XT and uses DSP and OPL2 simultaneously ?
Reply 43 of 45, by root42
Maybe SpaceQuest 1 VGA version supports all three. It will be horribly slow, but should work, I think.
Edit: EGA version of the remade SQ1 supports XT:
https://www.mobygames.com/game/space-quest-i- … ounter/techinfo
YouTube and Bonus
Reply 44 of 45, by gdjacobs
Yup, you need an extremely fast I/O pin and a fast DSP or FPGA to perform DDS of the PWM waveform. Conceptually the simplest method is to set the pin output as the result of a comparison between a periodic ramp or triangle wave function and the frequency space waveform of the audio signal.
Reply 45 of 45, by newold86
Just for the collection - PoP full FM
