First post, by newold86
While working (very) slowly on much more complex project inspired by the discussion, decided to make a simple SB-like card with DSP part (and OPL DAC) inside of FPGA, and original OPL2 chip just to test some ideas:
Great effort 😀
Personally love the wavy routing. What package is that FPGA?
Minor suggestion: Make sure there's no solder mask on the ISA connector ... that can lead to issues over time and/or look bad after a few plug/unplug cycles.
Current Project: new GUS PnP compatible soundcard
[Z?]
Huh, very interesting!
The more sound cards, the better.
AdLib documentary : Official Thread
Youtube Channel : The Sound Card Database
Awesome! It'd be very cool if there could be an FPGA sound card like this that could be reconfigured via a DOS application to a variety of different cards. Of course, SB clone is also awesome.
Old precedes antique.
Lookin' good, man.
MAX10 <3
wrote:MAX10 <3
What does it mean ???
<3 looks like a sideways heart so it means Tiido really likes the MAX10 fpga
wrote:<3 looks like a sideways heart so it means Tiido really likes the MAX10 fpga
Looks more like a butt 😀
don't be negative 🤣 🤣 🤣
Hahaha, <3 is meant to be a heart so Keropi is right here. I like MAX10 FPGAs and I use them on several things.
I dont see any DAC, I suppose you're doing PWM/PDM there for sound output ? Or maybe it is under the YM ?
wrote:wrote:<3 looks like a sideways heart so it means Tiido really likes the MAX10 fpga
Which in itself is not always less desirable than a heart.. but I digress.
wrote:(and OPL DAC)
Interesting.
My question is: how did you implement this?
Do you have a single DAC that you use for both the OPL and the DSP sample output? In which case, do you just convert the custom OPL output to standard linear PCM, and mix it with the DSP output?
Or do you use two independent DACs, one for the FM and one for the DSP, and mix them in the analog domain?
wrote:I dont see any DAC, I suppose you're doing PWM/PDM there for sound output ? Or maybe it is under the YM ?
Yes, just a simple 8-bit PWM with one resistor/capacitor... Converting OPL2 output to parallel 16-bit format and sending only 8 MSBs to PWM (doesn't add a sound quality, but good enough for my purpose).
wrote:... do you just convert the custom OPL output to standard linear PCM, and mix it with the DSP output?
Yes, just using arithmetic add operation. Again, the quality is a bit weird, but better than expected. Will try to find my recorder later today to provide some examples.
well it is certainly impressive for a test board - mainly compatibility tests. Output sound quality can always be tackled once you have a good base for the sb controller. 😀
Someone who is not really offended by a terrible sound (probably, noise is more correct word) can try to recognize the game 😀 - https://clyp.it/ezauzslh
Prince of Distortia!
Actually, I don't understand why did I get this kind of the distortion effect - sounds like it was almost done on purpose...
Does anyone know how does YM3014 work ??? The datasheet shows 16 bits for each SH cycle (3 unused, 10 mantissa and 3 exponent), but in reality YM3812 is sending 18 bits. I can’t recognize required data just looking at the logic anslyzer screen, and too lazy to experiment 😀
