Reply 40 of 53, by Kekkula
Does anyone know if X-fi fatality edition bracket is compatible with sb live! card?
X-fi original cable won't fit but i could use standard ide cable instead.
Kekkula wrote on 2022-08-25, 05:59:Does anyone know if X-fi fatality edition bracket is compatible with sb live! card?
I think they're not compatible: Re: Different versions of Live Drive?
Thanks.
So it seems that they are not indeed compatible 🙁.
And I think X-fi is not compatible with windows 98.
Kekkula wrote on 2022-08-25, 07:55:Thanks.
Get a Live! Drive IR and put on the faceplate of a X-Fi Drive.
Or get a Audigy 2 or 2ZS wich have the connector needed for X-Fi drives.
FCKGW-RHQQ2
Kekkula wrote on 2022-08-25, 07:55:And I think X-fi is not compatible with windows 98.
No it's not.
Audigy is the last with official driver support.
But there are are modified drivers for Audigy 2.
So the Audigy 2 ZS Platinum Pro is the last one you can use in Win98.
RaiderOfLostVoodoo wrote on 2022-08-25, 13:03:Audigy is the last with official driver support.
Both the regular Audigy 2 and the ZS version have Win98 drivers on the official install CD.
There is no need to make any modifications to get this working. Just pop the CD in and follow the instructions on the screen.
Oh really? I thought you'll need modified drivers.
Good to know.
Intel486dx33 wrote on 2019-04-03, 05:49:more photos:
Sorry to resurrect this thread, but what is the digital i/o card being referred to here? I can't find it anywhere. I found a CT4770 device but that doesn't look like it has optical out on it. I would love to find one of these simply for the optical out. If anyone has one that they are willing to sell then please contact me.
Thanks!
jaskamakkara wrote on 2024-03-13, 19:54:Intel486dx33 wrote on 2019-04-03, 05:49:more photos:
Thanks!
Try to find on Aliexpress or another shop "SPDIF out bracket", you will find something like this:
You must connect to pin 29, pin 30 and +5v on pin 1
I think wrong pins. On https://pinoutguide.com/Audio-Video-Hardware/ … nt_pinout.shtml iIsee that spdif out pins 8 and 9
If any one interested, you can find some information on site https://sblive.narod.ru/ You can use google translator or yandex translator.
Went through my box of stuff and came across this CT4770. Anyone tried this card? I'm guessing you just use a standard 40 pin ribbon cable to the Live card. I wonder if the midi out would work in DOS?
fyi, if anyone didn't know. Creative has a full list of all their products and accessories listed here https://support.creative.com/kb/showarticle.aspx?sid=10846
So I have a system with a CT4620 installed along with the CT4660 breakout... All good and working. But somewhere I have a Live! Drive 2 lying in the dust... can I connect it to the soundcard and then connecting the CT4660 to the Live! Drive (CT4860A)?
Thanks
Martin85 wrote on 2026-05-03, 18:56:So I have a system with a CT4620 installed along with the CT4660 breakout... All good and working. But somewhere I have a Live! Drive 2 lying in the dust... can I connect it to the soundcard and then connecting the CT4660 to the Live! Drive (CT4860A)?
Yes, this is the configuration I have.
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, Voodoo2, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
