Retro 3D print topic
Reply 40 of 113, by Major Jackyl
douglar wrote on 2024-12-27, 01:17:
Here's what I came up with: https://www.thingiverse.com/make:1207377 […]
douglar wrote on 2024-12-22, 16:28:
Anyone know of a 3d printable ISA/VLB card storage unit better than this one?
Tried to maximize strength and cleanability while minimizing filament use and overhangs
Wow, those look great, nice work! I have a few ideas, but have been too busy to work on it. I've made single card displays for PCI, AGP, PCI-E, and SLOT1/A. I haven't finalized them to my satisfaction yet. I want a fan header(s) on the Slot1/A stand and the AGP on is a bit loose since the slot is small.
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 41 of 113, by oh2ftu
has anyone encountered a suitable 2,5"->3,5" print with a "slot" for the startech ide2sat2-adapter?
I just got a 3d-printer, but I'm at loss with fusion360.
Reply 42 of 113, by douglar
oh2ftu wrote on 2024-12-27, 15:01:
I did this for an Msata device.
https://www.tinkercad.com/things/dIGRnd9BlWk- … a-to-35-marvell
The attachment Photo Dec 27 2024, 3 23 02 PM.jpg is no longer available
Maybe you could use that as a starting point and combine it with this?
https://www.tinkercad.com/things/k9WQeCkhbz1- … 5-to-35-adapter
Reply 43 of 113, by douglar
Major Jackyl wrote on 2024-12-27, 01:44:
I'm just trying to clean up my desk. So far so good!
The attachment Photo Dec 28 2024, 2 43 42 PM.jpg is no longer available
Reply 44 of 113, by H3nrik V!
douglar wrote on 2024-12-28, 21:10:
Wow, I need a bigger desk ... or maybe just one where I don't have the setup for my work laptop as well 🤣
Are the labels on the cards index codes or short descriptions?
Reply 45 of 113, by douglar
H3nrik V! wrote on 2024-12-28, 21:44:
Two digit codes. When I do DOS benchmarks on the VLB IDE cards, I name the 8.3 output files as [2 digit Card code][2 digit driver or Bios code][4 digit storage device code] Then when I load the files into the database, I can parse the file name to get the card info since these cards got no plug and play details. Putting the lable on the top makes it easier to spot the cards.
Reply 46 of 113, by oh2ftu
This is my first item I designed myself with fusion.
I used @douglar work for the ide2sat2 slot and modified it quite a bit.
I have yet to reprint it with looser nubs for ssd-mounting holes, and it will also have floppydrive-matched holes so it can be installed as a floppydrive as well. A facia might be needed..
Fusion took a while to get a hang of, I keep looking for ACAD-features, as I've used ACAD at work (electrical design) for 15 years 😀
The attachment 20241229_200619.jpg is no longer available
The attachment 20241229_200607.jpg is no longer available
Reply 47 of 113, by douglar
oh2ftu wrote on 2024-12-29, 18:11:
I like the design. What's it look like with the clips on? What kind of build is it going in? PIO? MWDMA? UDMA?
I have not used Fusion. I use tinkercad and export an STL. I used to send it off to my public library to print, but now I import into Creality Print and create a gcode file for the printer.
Reply 48 of 113, by oh2ftu
I have multiple systems so I will be printing quite a few of these (maybe eight?).
What clips did you mean? 😀
Reply 49 of 113, by douglar
oh2ftu wrote on 2024-12-30, 08:40:
Getting bridged sata devices to do MWDMA transfers can be a challenge. IDE contollers that do MWDMA but not UDMA are late 486 controllers like the CMD640 and PDC20630 up through the PIIX3 pentium south bridge from intel. Mostly systems that would have shipped with Windows 95. You can always fall back to the PIO modes.
These were the clips I was talking about:
The attachment IMG_2792.jpeg is no longer available
Reply 50 of 113, by oh2ftu
Oh, those were just prints to adjust the sata-adapter mount 😀
Reply 51 of 113, by khyypio
Hello!
Got a tip this thread. This is an adapter that you can use to install a 60 mm fan to stock Intel socket 478 cooling assembly.
The attachment 1.jpg is no longer available
The attachment 2.JPG is no longer available
The attachment 3.JPG is no longer available
The attachment 4.JPG is no longer available
The attachment 5.JPG is no longer available
A video: https://youtu.be/xkzoRT0c4uE
Download: https://www.thingiverse.com/thing:6879228
Reply 52 of 113, by douglar
As I worked through the AGP & PCIE, I realized that:
  1. Newer cards often meant heavier cards that need better support
  2. AGP & PCI cards have tables for stands that work a lot better than mounting on the contacts
  3. Big flat bases use a lot of plastic and are prone to misprint
  4. Needed to improve support for double width cards
So here's the new batch. Might be a little tweaking over the next few days, but pretty much done at this point:
ISA/VLB Card Stand:
https://www.tinkercad.com/things/16pMpNOqcl8- … d-stand-36-gram
https://www.thingiverse.com/thing:6919767
PCI Card Stand:
https://www.tinkercad.com/things/iYex3uzUq3u- … d-stand-24-gram
https://www.thingiverse.com/thing:6919775
AGP Card:
https://www.tinkercad.com/things/5mAiN2849sr- … d-stand-28-gram
https://www.thingiverse.com/thing:6919778
PCIE Card Stand:
https://www.tinkercad.com/things/gHMSxvgj37Y- … d-stand-36-gram
https://www.thingiverse.com/thing:6919789
Reply 53 of 113, by oh2ftu
Ok, so after a few attempts it seems quite ready. The mount itself is still a little flawed, but I'm waiting for better filament before a reprint.
These are not available on printables (yet) but at some point they will be.
The SSD-adapter will hold a Startech-adapter with one drive connected. Another drive can be slotted in above it.
Only 7mm drives supported, but it's easily modified to take just one taller drive.
It has 3,5" dimensions with holes for 6-32UNC with HDD-spacing, as well as M3 holes with floppydrive-spacing. There's a faceplate that should fit a floppy slot too.
The side and front which accomodate mounting to the Fractal design Focus G case are screwed with 6-32UNC screws (also snap-on fitment). The front facia mounting also has slots for M3 square nuts if you prefer M3 countersunk screws.
Reply 54 of 113, by red_avatar
khyypio wrote on 2025-01-02, 15:40:
Hello! […]
Hello!
Very nice!
As long as the heat sink doesn't go beyond 60-70°C the 3D print should hold without warping if PETG is used.
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
Reply 55 of 113, by aspiringnobody
I modified a Slotket mount from printables to work better with Asus S370 series slotkets. I also adapted the model to use the default intel supplied retention screws to eliminate the need for a new backplate.
pictures here:
Re: What retro activity did you get up to today?
stl here:
https://www.printables.com/model/1146783-asus … l-slotket-mount
Reply 56 of 113, by aspiringnobody
douglar wrote on 2025-01-03, 12:52:
ISA Card Stand Revised: (Less plastic, easier to insert cards) https://www.tinkercad.com/things/5l1ZAej2Uer-isa-stand-x8-v2 […]
PCI Card Stand:
https://www.tinkercad.com/things/5somcojxj7R-pci-stand-8x
The attachment Photo Jan 03 2025, 7 41 56 AM.jpg is no longer available
The attachment Photo Jan 03 2025, 7 41 50 AM.jpg is no longer available
Any chance you could make one for AGP? I've got more of those than I remembered...
Reply 57 of 113, by douglar
aspiringnobody wrote on 2025-01-14, 11:24:
I did the prototype but then I needed more filament. And then I got more filament but ran out of retro time. I’ll have something by the weekend.
Reply 58 of 113, by douglar
I need a second draft. The AGP cards have that high cut at the end.
The attachment Photo Jan 15 2025, 8 44 06 PM.jpg is no longer available
Reply 59 of 113, by aspiringnobody
douglar wrote on 2025-01-16, 01:49:
Looking good!
