douglar wrote on 2025-01-25, 20:38:
Ozzuneoj wrote on 2025-01-25, 19:41:
What about something like this CF card with a microSD slot?
https://www.aliexpress.us/item/3256804818600954.html
You can use whatever CF>IDE adapter is convenient for you, with the flexibility of using microSD cards. They are also on Amazon of course, but they're twice as expensive for exactly the same thing.
It's just another sintechi SD-IDE bridge, but with a 50pin instead of 40 pin IDE port.
They can be tricky because many require 3.3v, and not many CF adapters provide clean 3.3v.
Interesting. So one of those would probably work in a camera or something that can properly supply 3.3v or 5v, but not in basic IDE CF adapters that lack a suitable 3.3v supply.
I have a bunch of these:
https://www.aliexpress.us/item/3256801622107339.html
And you're right, there isn't any kind of 3.3v supply on this thing.
By chance have you tried combining the SD>CF adapters with a basic IDE>CF adapter like the one above? That's a real shame if the SD>IDE bridge would cause the device to not be compatible with 5v supplies at all... but I see that the specs do say that it is 3.3v. Still, if there are any additional components inside that allow 5v operation this wouldn't be the first time that an aliexpress listing left out such a detail. Though, for as cheap as it is, you're likely correct and it will only operate at 3.3v.
EDIT: Ah, I see this has all been covered hear several years ago!
SD->CF (Secure Digital to Compact Flash) Adapter for use with CF->IDE adapter.
Hard to believe that THESE adapters and THESE 3D printable brackets have been available for 5+ years, and yet no one is selling one of those adapters with a metal bracket attached already.
