Reply 40 of 50, by feipoa
Thanks a lot! You have confirmed my suspicion, which I have now tested for.
Unfortunately, I didn't have any parity 256K modules, so I also tested with 4x 1 MB modules. I found that the RAMpAT board was more likely to read the full 16 MB when installed using 9-chip modules, rather than 3-chip. With the 3-chips, I was sometimes getting 12160K or 8192K detected.
I do not quite follow the numbers on the RAMpAT config file.
The attachment RAMpAT_Config.JPG is no longer available
It looks like config is counting the existing motherboard memory as 4096K - BIOS SHADOW (64K) - VGA SHADOW (32K) - SCSI SHADOW (32K) = 3968K. But then why is the "next starting address" at 4352K? Should be at 4096K (I think).
Furthermore, the config utility then looks to be eliminating all of the motherboard's system memory except for 640K conventional, then adding the RAMpAT amount (16384K) minus 128K = 16896 K total memory. Complicating matters, the DOS mem command shows 15872K total memory. Is anyone able to make sense of this?
The attachment DOS_mem.JPG is no longer available
I ran Windows 3.11 IE5, loaded google, with the 16 MB on the RAMpAT. No issues there.
Ran a DOOM/Quake comparison with and without the RAMpAT
16 MB w/RAMpAT
DOOM = 21.28 fps
Quake = 2.5 fps
16 MB on motherboard only
DOOM = 21.57 fps
Quake = 3.1 fps
Rests were run on a SiS Rabbit board with an IBM BL3-100 (3x66) and ISA at 13.3 MHz. Graphics was GD5434 ISA.
Reply 41 of 50, by pshipkov
Nice.
My understanding is that the total combined addressable memory RAMPath can provide is 16Mb.
It is not clear to me if that is a sum of 4Mb on-board + 12Mb from the card, or 1Mb on-bard + 15Mb.
retro bits and bytes
Reply 42 of 50, by mkarcher
feipoa wrote on 2023-02-06, 11:23:
There is no normal RAM between 640KB and 1024KB. The 640KB conventional memory is located between 0KB and 640KB. The extended memory starts at 1024KB. If your board provides 3328KB of extended memory, that memory is located at addresses between 1024KB and 4352KB. You are correct that the simple way of dealing with on-board memory would map the 4MB of mainboard memory to 0KB to 4096KB. As the address space between 640KB and 1024KB is reserved from expansion cards, the 384KB of memory mapped to that area is inaccessible. Some of this memory is used for shadowing, but the remaining memory would be "lost" if the chipset didn't support memory relocation aka memory remapping. This remapping moves some of the memory between 640KB and 1024KB to high address past 4096KB. The amount of memory that can be relocated in different configurations (shadow for some addresses enabled/disabled) varies depending on chipset, and for certain chipsets also on total memory size. Your chipset seems to be doing the perfect job: You need 128KB of memory for shadowing, so there is up to 256KB that can be relocated, which is actually the amount that is relocated on your chipset.
The highest address that can be provided by an ISA bus card is 16384KB. As extended memory starts at 1024KB, the maximum amount of onboard + RAMpAT extended memory is 15360KB. Furthermore, your board is a 386SX board with just 16384KB of total address space. The 80386 processor starts executing at the end of the address space, so the highest 64KB get allocated to a second copy of the BIOS ROM (which will always map to the hardware ROM, even if the ROM at F000:0000 is mapped to shadow RAM). This reduces the theoretical maximum amount of extended memory by another 64KB to 15296KB. The MEM output shows another 64KB less, so I guess your chipset reserves the top 128KB for ROM access.
Reply 43 of 50, by mkarcher
pshipkov wrote on 2023-02-06, 16:19:
Nice.
The memory on board can not be disabled by the RAMPpAT card. To avoid conflicts, the RAMpAT must not respond to cycles that are also handled by the 4MB onboard RAM. So you will most likely get 4MB on-board and just short of 12MB from the card.
Reply 44 of 50, by pshipkov
Agreed.
Never put much thought into how memory expansion cards work.
All your comments make sense.
Thanks for that.
Reply 45 of 50, by feipoa
Thank you for the perfect explanation (again!). The particular board that I was testing on is a Chaintech 340SCD based on the SiS 310/320/330, aka "SiS Rabbit". It is a 386DX motherboard that supports 32 MB DRAM. There is not an option in the BIOS to allow for memory relocation, but from what you've written, it sounds like it is relocating memory by default. When using BL3 chips on 386 boards, I usually avoid memory relocation because of higher chances of memory errors. With 16-32 MB of RAM installed, another 64K-256K doesn't matter much. No such issues with the remapping on the SiS Rabbit.
I did install the RAMpAT into my 286 and found that my RAMpAT config screenshot matches that of pshipkov's, implying that the system is not relocating unused reserved RAM. Unfortunately, when using the RAMpAT in my 286, I would get
PARITY ERROR ???
SYSTEM HALTED_
when trying to run DOOM. I tried different modules to no effect. I was able to load Win3.11 fine. I also was able to finish the Quake timedemo. It look around 25 minutes and the score was incredibly low at 0.7 fps. A 286 with 16 MB RAM at 66 MHz w/1K L1 doesn't feel anything like a 486.
I ultimately put my enormous 3 MB Everex EV-159 back into the 286 because it didn't have parity RAM errors with DOOM.
The attachment 07-Cards_Everex_EV-159_RAM_3000_Deluxe.JPG is no longer available
Reply 46 of 50, by douglar
feipoa wrote on 2023-02-07, 04:13:
I did install the RAMpAT into my 286 and found that my RAMpAT config screenshot matches that of pshipkov's, implying that the system is not relocating unused reserved RAM. Unfortunately, when using the RAMpAT in my 286, I would get PARITY ERROR ??? SYSTEM HALTED_ when trying to run DOOM.
Doom requires a 386 because of its built in memory manager, no?
Reply 47 of 50, by feipoa
I'm using a 286-to-486 upgrade: Cx486SLC2-50MP at 66 MHz.
Reply 48 of 50, by LeTOND
All, I am having a little different issue. I am not sure if is because my system board only has the 512Kb or if there is some other issue. The card installs correctly. I am running an IBM5170 with the QUADTEL BIOS upgrade. The Config sees the memory. The Install.exe also sees the memory. See attached pics. When it reboots, the BIOS counts through the memory and then gives an error: 3082 Memory Fault error. FAULT is at FFFFFFFF. As long as I do not have EXPANDED memory configure, the system will continue to boot up to the DOS command prompt.
When I run "mem" from the command line, it does show all the memory. However, except for the conventional memory, there is "0" free memory. Nothing is available.
A few notes:
* The battery is dead. I have to reconfig BIOS if the PC is off for more that 2 minutes.
* I do not have 128Kb memory expansion card. The system is running with only the 512Kb on the motherboard, plus the RAMpAT card.
* I am unsure if the motherboard is Type 1, 2 or 3. MSD does not recognize the processor (unknown).
It is not type 3 based on the BIOS layout on the motherboard.
It is running the original MFM controller card. However the QUADTEL BIOS does allow me to operate a 1.44 mb 3.5 disk drive.
Reply 49 of 50, by Mike1978
Hi all,
I’ve ended up here after I’ve had issues with my NOS RampAt Plus!
I have an IBM 5170 type 1 running fine with the Phoenix bios from -0 degrees website. I have different boot options but atm I am using an IN-2000 scsi card with a bluescsi this booting fine to dos6.22 and detecting other images fine. I’ve hooked up the fdd to a multi i/o card and can use either a 1.2mb 5.25 drive or a 3.5 1.44 drive booth bootable.
The phoenix bios booting fine for 1.44mb support.
If it put the card in the system it doesn’t boot. If I flip the jumper jp1 to disabled everything boots.
If I enable nothing no life no boot options it halts the system though the fan runs I just never get the screen to come on or any system beep from the speaker of keyboard light activity.
The 5170 board has 256kb as I discovered some bad ram chips thanks to a dram tester. But I have an IBM board that tops up the ram to 640kb. All works fine.
I’ve tried with / without the IBM top up ram. I have other options for boot a multi i/o with ide and fdd support, a picomem or the scsi I’ve so far tested the picomem and scsi and have the board overclocked with a faster crystal and supporting fine a 10mhz AMD 286-10 with a Intel i287XL for the FPU.
I noticed today if I remove the 6116 (SRAM) there is a Dallas DS1213 on the RampAT card, I can safely assume the battery on that may well be dead and seeing above photos I wonder if that’s why I see coincells on the boards of other cards / earlier iterations.
Could the Dallas socket be preventing it from booting due to bad battery? I know I’ve reworked other Dallas chips and added a coin cell before.
Any other thoughts? Could I have a short on the board preventing boot?
The board was brand new unopened and I’ve bought 16mb by a combination of 4 x 4mb 30pin parity simms (80 nanosecond) known tested working 9 chips on each and in spec of what was detailed in the board installation guide. I’ve tried with ram, without ram, with 1 stick of ram etc.
The 3.5 floppy driver disk wasn’t reading ,so I hooked up a 5.25 drive and that reads the software from the supplied 5.25 driver disk
With the card disabled it works and detects the system conventional ram but with the board set enabled it just stops the system booting.
I have tried it in other machines and same behaviour.
Please help as I’d love to be able to get my 5170 with the full 16mb enabled
Note I know some of you are still active from prior conversations and I saw this link updated this week also which is the same card I have.
https://theretroweb.com/expansioncards/s/accu … inc-rampat-plus
Thanks in advance
Mike
Reply 50 of 50, by douglar
Hey! That's my card! =)
When you say it doesn't boot, are you getting video and num lock action or is it stone code dead?
Do you have an ISA post code card? It might give some hints where there boot process is stopping if the computer is not completely dead.
