Reply 40 of 51, by Prez
Vapita wrote on 2020-12-22, 10:03:
Hi Philippe, […]
Prez wrote on 2020-12-18, 16:57:
Yes the S2 is a great wavetable addon ! Sounds really great and doesn't cost much ! […]
Vapita wrote on 2020-12-18, 08:18:
Thank you very much. Prez helped out alot as he figured out that the Futro doesn't have the required 12v pci support and how to […]
Thank you very much. Prez helped out alot as he figured out that the Futro doesn't have the required 12v pci support and how to fix it.
I already noticed that the ESS Solo has a wavetable connector. I found a dream blaster s2 daughterboard at
https://www.serdashop.com/waveblaster
It says it is compatible with most soundcards and it seems to be tiny enough to fit into the futro. i will check if the necessary space is available.
kind regards,
Vapita
Best regards
Philippe Dubois
Hi Philippe,
can you recommend a VGA capture card for capturing the video of the thin clients? I like your videos on youtube very much. Currently I am only able to record through my DSLR and that's neither very fancy nor suitable.
kind regards and happy christmas,
Ben
Hi !
You can use some not cheap VGA to HDMI scalers, but most offen i use this one, very cheap and that works very well :
https://fr.aliexpress.com/item/32692452101.ht … .27426c37z2utgD
Then, of course, you have to use a HDMI capture device, nearly all of them will work, but i can recommend this one as well, still cheap, with a direct ouput and a small lag when acquiring :
https://fr.aliexpress.com/item/10050012738956 … .3f986c37I0PPSJ
or this one, better :
https://fr.aliexpress.com/item/10050014019421 … mMoreThisSeller
It offers a lot of different resolutions and some 4/3 direct format ones, so that's great for old msdos games !
ps :Whatchout for audio input.
Best regards
Philippe Dubois
Old computers and videogames freak
President of french association https://mo5.com
Get better, get old ! 😁
Reply 41 of 51, by pc-sound-legacy
Hi Philippe, […]
kind regards,
Vapita
Best regards
Philippe Dubois
Hi Philippe,
Ben
I am using Epiphan DVI2USB (wich worked fine with a generic vga to dvi adapter) capture device. Sometimes they are offered for less than 100 € , got mine for just 40 EUR
Pro: Supports all of the old resolutions, also msdos text and low res ega/vga. Con: everything above 640x480 decreases frame rate below 30fps as it is USB 2.0 (there is a 3.0 variant but it's expensive)
Reply 42 of 51, by Vapita
pc-sound-legacy wrote on 2021-02-28, 23:59:
Hi Philippe, […]
Best regards
Philippe Dubois
Hi Philippe,
Ben
Thanks alot. I will give it a try.
Stay save and healthy!
kind regards,
Ben
Benjamin Voigt
Chief Executive Officer
Vapita Media Agency
https://www.vapita.de
Reply 43 of 51, by segfault
Thanks to this thread, I was able to get my ALS4000 sound card running in DOS on my TR3540 mainboard. I soldered a cable to the pin on the PCI riser card and used 5V from the USB head located right next to the PCI slot. Works perfectly with this card. Thank you guys for all your inputs.
(Next step will be USB mouse support in DOS if possible, and then I'm completely happy with DOS gaming).
Reply 44 of 51, by Prez
segfault wrote on 2021-09-10, 13:53:
Great !! Enjoy your games 😉
Best regards
Philippe Dubois
Reply 45 of 51, by pycur
@segfault
Hello! I need some assistance!
I bought a siemens futro s200 to run my software in pure dos mode, and with sound card.
I soldiered the wire to the mentioned points and voila, I got my sound card working, BUT it made me another problem. That 5V wire comes directly from the power supply and it keeps my soundcard's amplifier turned on even with powered off computer.
So it's in use 0-24 and it made some damage. I found out that some capacitors came bumped out, and my sound card whistles extreme loud.
So I need to recap some capacitors, and then move the wire to the USB point, and it will be software managed, not always powered on.
Can you show me the correct pin where to soldier that wire?
Thank you for this awesome topic where I could make this machine working for my needs. 😀
Reply 46 of 51, by Prez
pycur wrote on 2023-07-17, 18:34:
@segfault […]
@segfault
Hi ! The USB connector is very simple.
Here is a schematic where you can find the +5V pin :
https://www.etechnophiles.com/wp-content/uplo … =ng:webp/ngcb41
Best regards
Philippe dubois
Reply 47 of 51, by pycur
Awesome, and also thank you for the very fast reply to this old topic. 😀
Reply 48 of 51, by pycur
Hello again! I need some more help. 😀
Referring to xjas in this post: Re: Quick/easy/dirty mod to make thin clients like Fujitsu Futro S220 or TECO TR3540 works with some soundcards !
I read that some capacitors on the pci riser card can remove the mainboards noise.
If it's true, then what type and kind of caps should I soldier in?
I'm not good at electronics, i only can solder some parts and wires...
Reply 49 of 51, by Vapita
That's very nice.
Benjamin Voigt
Vapita Media Agency
Reply 50 of 51, by Vapita
Hi again,
I'm really curious about what other interesting projects are out there related to retro gaming. Are there any exciting hardware components worth trying out?
I still need to test the wavetable for the ESS-Solo, for sure. How about you?
kind regards,
Ben
Benjamin Voigt
Vapita Media Agency
Reply 51 of 51, by dkaram
@teco tr3540 owners. Has anyone managed to run dos successfully from the embedded cf reader or even from the ide connector using ide to compact flash adapter?
I have tried many ways , including installing dos on the cf by using virtualbox and then connect the cf to the teco but unfortunately no luck.
Either boot sector is not recognized or I get a black screen and cursor on the screen blinking on the top left leading to no-boot for the os.
I can boot successfully using a bootable usb (dos 6.22 or freedos) but no luck using a compact flash connected to the mobo.
