Reply 40 of 90, by 2mg
chinny22 wrote on 2022-11-30, 11:44:I say go for it, in the end only you will know if it works for you. […]
I miss understood you were installing 2 video cards. Assuming you would simply disable the GF6 in Win98 and FX in WinXP. otherwise it'll be very confusing driver wise as both cards share the same driver package.
That said I'm not even sure if you really need both video cards. Admittedly I didn't do much testing or troubleshooting but only game I remember not liking the GF6 was C&C Generals. Could well be all your games run fine?
As you have a backup Win9x PC I'd just play any games that don't like the GF6 on that and like you said get 999 fps in Quake 3Also I never had any problems with HT enabled as Win98 just ignores it, if any inefficiency does exist the CPU is so overpowered for Win98 you don't notice anyway.
Worst case as I see it if the PC doesn't work out just forget about XP, chuck the FX card in and your still left with a crazy fast Win98 PC and as a worst case scenario it's a pretty good one.
Yeah about that dual GPU setup...
The PCI FX5 cards are horrible, and the AGP FX5 cards are overpriced and offer DX9 support as a "demo feature".
The PCI GF4 cards are MX only so horrible again, and the AGP GF4 Ti cards are overpriced and have DirectX 8 max.
The PCI GF6 or newer I didn't bother with, nor anything from ATI, as they break table fog/palettized textures.
Going the reverse way - strong W98 AGP card + fastest PCI DX9 GPU just flips the problem, there isn't a PCI card worth it for DX9.
The PT880 (Pro/Ultra) chipset offers AGP and PCIE (at x4, should be enough?) so this could be mitigated, but these rare dual/hybrid GPU motherboards are expensive, and god forbid the MBO dies, finding a replacement would be pain.
AGP this modern takes only 1.5V cards, so I dunno what options are regarding Voodoo cards if I ever wanted one in the build.
So unless I have some kind of "AGP switchboard" or a "dual AGP riser" or manually change AGP GPUs per Windows boot, a solid hybrid seems just out of reach...
A single AGP GPU if I had to choose for the system always has one drawback - FX5 is just a faster "DX9 games in DX8 mode" card than GF4Ti, GF4Ti is DX8 fixed so I dunno how it handles Glide wrappers but it has a long driver support for compatibility but slowest of the bunch, and GF6 wins with DX8 and DX9 but breaks some compatibility and I'm unsure if anything other than 6200 is officially supported and I can't go further than this series for DX9 WXP speeds.
What about an AGP GF4Ti/FX5xxx + PCI 9500GT?
It's slightly period incorrect, but much cheaper (compared to 2 builds or AGP+PCIE mobo) and covers this whole idea, Turbo98 + solid mid-life XP?
Except for this issue: Re: Best low-profile PCI graphics card?
Or AGP to PCI, PCI-E to PCI thingies I see around?
