Reply 40 of 59, by Thermalwrong
atar wrote on 2025-12-22, 12:21:Thermalwrong wrote on 2025-01-18, 16:09:The main cap that should be bad on the T1960 will usually be C511 which is 6.3v 1000uF.
Sorry for a dumb question, going to replace the C511, have just ordered a soldering station with a heat gun. What would be the best approach on replacing C511? Iron solder or a heat gun? And what temperature would be the best? I'm afraid if I set it too low, I would overheat the neighbouring components waiting till it starts working, and the same would definitely happen when I set it too high.
A heatgun or hot air station on the area is pretty risky, there are lots of SMD components on the back where you need to remove the capacitor's legs from. Simply heat one leg with a soldering iron and try to 'rock' the capacitor out on that leg, then heat the next leg and rock it out on the other side.
It'll probably take going back and forth a few times but it's the cleanest way I've found to remove caps in busy areas. For an idea of the tip I'd use to do it, look at the BC2 soldering tip.
The PCB isn't too bad for ground plane heating issues so you should have little trouble getting the cap to remove. Once the cap is off, clean up any electrolyte visible on the board around where the cap was with a cotton bud soaked in IPA.
Personally I then use a solder sucker to clear the holes and this can be a bit challenging. Solder wick might work but would be best on the top-side of the PCB since there are so many components surrounding the cap legs on the underside.
Good luck with the repair 😀
