First post, by vbug
Hi everyone, I have some old Toshiba T1900 series laptops (T1900-1910-1950-1960 S/CS/CT). This series is known to have a faulty capacitor in the PSU board, a 6.4V 1000µf capacitor, avoiding the board to work properly and blocking the power on. Most of the time you just have to change that capacitor to get the psu board works back. But on some of them the board is still faulty after the replacement of that capacitor. I noticed something strange : when I warm up the board using a hair dryer, the board is able to start and work properly, but will be unable to start again once it has cooled. I replaced most of the others capacitors on the board but it doesn't change anything. Does someone has an idea of what could be wrong, what components could be thermal sensitive, what I can check ? Thanks.
1.49 MiB
1.61 MiB
1.98 MiB
1.6 MiB
1.59 MiB
Reply 1 of 8, by Thermalwrong
On the vias in the white silkscreen surrounding the capacitors, it looks like there's still some electrolyte / residue there. Washing it in an ultrasonic would probably help, but in my case I cleaned it up extensively while the capacitors were off the board.
My T1950CT had the same issue as you're seeing now originally where it would only power on after being heated for a while, but replacing the C511 cap & cleaning resolved the issue on mine.
Reply 3 of 8, by vbug
Another card, same symptoms, I removed most of the capacitors, I completely immersed the card in IPA for about 30 minutes then I scrubbed with a toothbrush and dried with a hair dryer, no change, the card only works when it has been heated. I tried with different values of replacement capacitors for C511 (two different models of 6.3v 1000µf, one 6.3v 1800µf, one 6.3V 2200µf, one 10V 2200µf), no change. I don't know what I could try now, any suggestions ?
1.47 MiB
1.57 MiB
1.26 MiB
1.47 MiB
Reply 4 of 8, by Thermalwrong
Well, I'm not sure - what's the weird marking by the fuse on that last picture?
Do you have an ultrasonic cleaner? It might be worth giving that end of the board a bath since it's got electrolyte and flux residue all over, at least it was on mine. Scrubbing in IPA should achieve about the same thing though, that's all I did for mine.
Sometimes really perplexing things can happen after cleaning, I was repairing a Toshiba Portege 300CT the other day and had the same problem you now have, after replacing the corroded capacitor & cleaning traces it would only work briefly after warming it up, or if the computer ran for a minute in that broken state it would then start up on the second try. I've left it for a few days and now it's working first time so perhaps something needed to dry out.
I'm planning to get another T1900 laptop so I'll be able to perhaps help more directly soon.
Reply 5 of 8, by Thermalwrong
So I did indeed get the T1900C laptop and I'm happy to report it had the same fault you're seeing! It would give the DC fault where the DC light would extinguish and begin to flash as soon as the power button was pushed.
After initial capacitor replacement of the big electrolytics, the fault persisted and the laptop would only power after heating with a hair dryer for a few seconds.
1.26 MiB
First of all my recommendation is to swap out every one of the 'Elna' brand brown caps since they had all started to leak. You can detect caps that have leaked if you heat the legs of the cap before the board is washed. Sizzling = electrolyte on the PCB, it may also stink of fish.
The ones I had to replace because there leaking were
C511 - 1000uF 6.3v 105c. Height: H10mm & Diameter D10.5mm. Replaced with 10v 1000uF of same size
C521 & C518 & C516 (next to C518) - 120uF 16v 105c H11.5mm D6.5mm. C518 was 56uF but I replaced it all 3 of these with 16v 100uF Rubycon caps w/ H11.5mm D6.5mm
C520 (next to R548) - 56uF 16v 105c H7.5mm D6.5mm. Must be replaced with a cap of same height or less. I replaced with 16v 100uF of same size
C509 - 2200uF 6.3v H20.5mm D12.75mm.
After doing all that, the board would not power up unless heated. So I checked it close up with a torch to look into the board sandwich where that board to board connector is - I spotted some green on the legs of capacitor C63 (33uF 6.3v) on the upper board:
839.75 KiB
Bad cap on upper PCB
It stunk up the whole room removing that thing. To get these sideways mounted small electrolytic caps off, I found that heating both legs at the same time works best. It's fine to melt the cap body in the process, then using some needle noise pliers twist the body of the cap sideways and it should pop off, taking most of the epoxy with it. Doing it cold results in the cap's plastic body coming off in multiple pieces and leaving epoxy behind.
Then the area was cleaned up with fresh solder, cleaned with IPA and rosin flux removed. I'm using MLCC capacitors for these because they're non-polar and shouldn't degrade / leak - the replacement is a 22uF of some voltage above 6.3v.
678.04 KiB
Looking at more of them I found that the 10uF 6.3v C526, C527 & C528 on the the lower board's top-side and C523 on the lower side all needed replacing too, they sizzled when removed so they've also leaked, again 10uF MLCC capacitors were put in their place. Lastly C208 (? I got the names from the maintenance manual, it's low-res) on the underside which was 33uF at 6.3v was replaced just to get them all.
1.07 MiB
After that the laptop has turned on without issue, hopefully your problem is something similar - looking really closely at your pictures, C528 on your board looks just as crusty as these small bad caps on mine did.
Reply 7 of 8, by vbug
So, I replaced C518-C520-C523-C526-C527-C528, and now it seems to work on both cards ! I'll test on a third card but I'm confident ! Thanks a lot for your tests and your time @Thermalwrong.
Reply 8 of 8, by Thermalwrong
That's excellent! Congratulations on getting your ones back up and running 😀
It's got me wondering whether it affects only ones from early in the production run - my T1900C is much older than the T1910CS - or whether these little 'SMD' electrolytic capacitors will all eventually need replacement. I don't want to take my other ones apart again...
