Reply 400 of 788, by nd22
- l33t
C. KV8
C. KV8
Nothing to see, all 3 results are still close so we move to:
11. 1280*1024 max details with no sound:
A. NF8
B. KU8
C. KV8
12. 1280*1024 max details with sound:
A. NF8
B. KU8
C. KV8
Still no clear winner as we head into the most demanding settings:
13. 1600*1200
A. NF8
B. KU8
C. KV8
14. finally we reached the end of tests in Aquamark3 with 1600*1200 sound on:
A. NF8
B. KU8
C. KV8
In Aquamark VIA has across all resolutions a 2-4% advantage over nforce3 - still not enough to score a clear victory. ULI is extremely close , even overtaking VIA at 1600*1200 with a very small lead!
15. We go back in time to the only Directx7 benchmark: 3dmark 2000; all 3 systems are way overkill for any Directx7 test as we see in the results. Also Cool and quiet MUST be disabled in this test otherwise the CPU will just sit at 1000 MHz - and yes I did test all 3 systems with cool and quiet enabled and disabled
1024*768
A. NF8
B. KU8
C. KV8
Abit KU8 with cool and quiet - notice the score is cut in half!
16. 1280*1024
A. NF8
B. KU8
C. KV8
17. 1600*1200
A. NF8
B. KU8
C. KV8
In this CPU limited benchmark we got no winner! Clearly you are not going to encounter any problem playing your favorites games from the late 90's on such a system!
18. Many people will consider 3dmark 2001 as the most important test for a system designed to play early 2000's games! A staple for all PC's from the 2000's with any operating systems - be it 98 or XP - it is considered a fundamental metric in all comparatives.
1024*768 default settings
A. NF8
B. KU8
C. KV8
And we got a winner! VIA overtakes both nforce3 by 8% and m1689 by 5.8% in this test! For the first time since Newcastle is under testing there is a clear victor.
19. 1280*1024 resolution with all details maxed out:
A. NF8
B. KU8
C. KV8
20. 1600*1200
A. NF8
B. KU8
C. KV8
VIA manages a first victory with Newcastle in 3dmark 2001!
