Battle of the platforms: socket 939!
Reply 400 of 616, by nd22
All of the above is a moot point (including the remaining issue with the command rate of the memory and the fact that I solved the video card problem by purchasing a GTX 285 or the excellent compatibility of nforce4 with SSD's )because:
B. VIA managed an excellent comeback on both socket 754&939 with K8T800 PRO. It proved to have the best performance out of all AGP platforms. Having proved superior to NVIDIA' nforce3 VIA set out to design a PCI-express chipset and the first one is K8T890. NVIDIA already proved by designing nforce4 that the first try can be a very successful one so now is VIA's turn.
Unlike nforce4 K8T890 is a classic northbridge/southbridge design. Usually that means more freedom as you can match them any way you want unlike the single chip nforce4 that is practically "set in stone". The northbridge is the new part while the southbridge is the true and tried VT8237!
Reply 401 of 616, by AlexZ
VT8237 unfortunately has the infamous problem with SATA protocol version negotiation so new magnetic drives or SSDs won't work. It's a major downside. PCIe X1 SATA card will be necessary to make it usable. Not a problem with AGP boards intended for Windows 98.
There is ABit AX8 selling locally with VIA K8T890 + VT8237.
I think we will have to admit that in the end s939 works best with 2x 1GB sticks as then we can use CR 1T. In s754/s939 we need every drop of performance for Windows XP era as these platforms have low clocks.
I use CR 2T in my AM2+ system but only because it serves Windows XP/Vista/7 era so badly needs 8GB RAM. It also limits memory speed to DDR 800. It is less punishing as we have fast 4 cores that make up for the latency. It is suboptimal and I only use it that way because s754 already covers most of Windows XP.
To max out these systems I believe we should use:
s939 - X2 Toledo CPU, 2GB RAM (2x 1GB) DDR 400, CR 1T, Windows XP era. Small swap file is necessary (mostly unused). A few lucky owners can use 2x 2GB registered memory clocked at DDR500 and turn off swap file.
AM2 - X2 Windsor CPU, 4GB RAM (2x 2GB) DDR2 1066, CR 1T, Windows XP era - not powerful enough for full Windows Vista era
AM3 - X4 Phenom II CPU, 16GB RAM (2x 8GB) DDR3 1600, CR 1T, Windows Vista/7 era
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 402 of 616, by nd22
Don't buy until you can get a clear look at the revision!!
Abit manufactured a single design named AX8. By providing extra controllers or extra hardware we got 4 models: AX8-V which is the basic model that comes with only what the chipset offers; AX8 that comes with an extra controller also from VIA - VT6421 with 2 SATA ports and 1 IDE port - and an useless firewire; AX8 third eye that is the same as the above and adds GURU clock first generation - the one that you install in a 5.25 inch bay; AX8 2.0 -everything that comes with the previous model but with a different VRM!
Reply 403 of 616, by nd22
The one you want is version 2.0 because it is the only one that supports dual cores Athlon 64 X2. It should be printed in full view on the board so you should not have a problem identifying it! I got both 1.0 and 2.0 and dual cores work only on 2.0. They also have different BIOS versions and if you flash the wrong one you got yourself a bricked board.
Reply 404 of 616, by nd22
AX8 1.0 you can see the sticker below the blue northbridge heatsink:
Reply 405 of 616, by nd22
AX8 2.0:
Reply 406 of 616, by AlexZ
I'm not planning to buy it, but it's AX8 2.0. It's visible on the sticker below chipset heatsink. Also when it boots, it displays ABIT logo with logos of 3 CPUs, Athlon 64X2 is one of them. Comes with uGuru utility. I looked at manual and it seems to be a decent model with VIA except for the SATA bug.
Reply 407 of 616, by agent_x007
S939 : I used 4x2GB ECC and it did run 1T CR at DDR500 speed (some benchmarks were done).
AM2 : You can use 2x 4GB config if you want (since there are 4GB AMD sticks to buy), but they probably won't do 1066 speed though.
Reply 408 of 616, by AlexZ
I have a few of those 2GB registered DDR400 ECC sticks, too much binning is needed to get 4 of them working at DDR500 (need to buy 4-8x more sticks than needed). You also don't need 8GB RAM in Windows XP and s939 is too slow for Windows Vista. For most people, the cheapest solution with good performance is to stick to 2GB RAM with s939.
Reply 409 of 616, by nd22
agent_x007 wrote on 2026-08-29, 09:02:
Congrats, that must be really difficult to run at DDR-400 yet alone at DDR-500!
AX8 has some serious motherboard layout issues!
The first is the location of the main ATX & P4 connectors which are between the I/O ports and the CPU socket - bye, bye cable management! Also notice the fan header glued to the main ATX connector - a difficult position to reach!
Reply 410 of 616, by nd22
The second faux pas is the CPU fan header which is right next to a capacitor so you can not use 4 pin connectors like the one found on Arctic freezer 7 pro! You must connect the fan to the header right next to the main ATX connector!Good luck trying that with the board installed inside the case!
Reply 411 of 616, by nd22
AX8 has the infamous VIA VT8237 southbridge that does not work with any SATA drive except the first generation! Also it does not support SATA optical drives! An advantage of most Abit boards is the debug postcode display which is very useful when testing 20+ years old boards! A plus is also the colored front panel header.
Reply 412 of 616, by nd22
The board has a second controller, also from VIA, VT6421 which support 2 SATA connectors and 1 IDE connector. This one has the same problem: only SATA 150 and no SATA optical drive!
Reply 413 of 616, by nd22
And the most annoying and worst - there are capacitors right next to the PCI-express slot that are slightly taller than the PCI-express X16 connector by 2 mm and also there is a bank of capacitors below the DIMM slots that prevent the installation of any graphic card with a big and bulky cooler like GTX 285 for example!!!
Reply 414 of 616, by nd22
So no GTX 285 for the tests, I must find a different card. I tried installing my GTX 560TI - the newest card I got - and it's a no go: the heatpipes on the card are blocked by several capacitors!
Back to the drawing board..
Reply 415 of 616, by nd22
The BIOS is extremely similar to the one found on AV8! It uses the first generation guru chip that, while inferior to the one found on AN8 ultra, is still miles better than most BIOS-es found on other socket 939 boards.
It over-volts the memory to 2.7V by default so I manually selected 2.6V:
Reply 416 of 616, by nd22
The board monitors 11 different voltage points and all 4 fans, however only 2 can be set according to different temperatures and voltages:
Reply 417 of 616, by nd22
Just like AN8 ultra we also got the black box showing usage statistics:
Reply 418 of 616, by AlexZ
So indeed AX8 has some very serious issues. Buyer would have to recap it to fix the issue with GPU fitting due to tall caps. 4pin connector on CPU fan would have to be replaced by 3pin connector as we cannot move the cap. Optical drives not working on SATA is also a major problem as PATA optical drives are basically dead by this point, very small chance to buy a good one. SATA ones are abundant.
The best card you can use is probably GeForce GTX 950, but no more as compatible as GTX 285. GTX 750 will be inferior, you can just use the GTS 250 you have and save money. I would just go with the GTS 250 in this case, if you have version with cooler from 9800 GTX+ with exposed heatsink. Some have cooler similar to GTX 285.
I would also like to draw attention to PCIe retention clip. GTX 285 will occupy space after the PCIe slot and below, with no way to unlock the clip with hand. If you are lucky it will unlock itself while removing the card forcefully. This clip is designed for 9800 GT, GTS 250, GTX 750, GTX 950 and not wide cards like GTX 285. Abit an8 ultra has the same clip.
I noticed it because yesterday I managed to break off PCIe clip on my Asus Sabertooth 990fx r2.0 with FX-8370. It has little wings on side so that one can push it with finger from above. But if you have a big cooler like Noctua nh-d15, there is no space for your hand and you need to use a screwdriver carefully. It broke on 2nd removal of GPU. Fortunately, these clips are non-essential. I had to remove GPU several times to test different memory sticks. In the end I left there just 2x 8GB sticks for best DDR3 speed and timings. It runs up to DDR3 2400, with 4 sticks just 1600.
Reply 419 of 616, by nd22
I tested last night an early gtx 260, the model with 192SP. The performance delta between it and the gts 250 is really small, I expected a big jump but got a small bump! Also the card has 896mb of VRAM which is insufficient in late WINDOWS XP era games such as Quake 4, Company of heroes, and so on.
The moment all the framebuffer is used up and it starts taking from the system RAM stutters appear and it lags all over the place. Below is a picture from Doom 3 RoE on a gtx 260 at 1280x1024 ultra quality, advanced settings all on, AA 16X. The card can mantain a 60 fps locked experience and is the lowest performing card that I tested capable of such feat. Note that Company of heroes is not playable on max details because it requires around 950-1024 mb of vram( tested on gtx 285)
