dgVoodoo 2.7.x and related WIP versions
Reply 400 of 474, by FulValBot
Fixing bicubic + Lanczos filters combined with integer scaling = ?
Fow now i see that both of these filters works as the nearest filter... (and this happen also with bilinear filter)
Reply 401 of 474, by ZellSF
It only happens under some additional circumstances, using the CRT scaling filter was the one I reported.
Reply 402 of 474, by FulValBot
GTA2 freezes with 3dfx mode (ALL dgVoodoo2 versions, and i think also dgVoodoo1 when XP was supported); this happen expecially when triple buffer is enabled (and this game doesn't support it)
It's happening also with nGlide program
Some years's ago with a very old PC with windows 98 GTA2 was freezing with triple buffer (in regedit there is a setting of it for GTA2) and this with a 3dfx Voodoo3 2000
in dgVoodoo2 where is Triple Buffer option? I have to disable it
with Half-life there are two cursors in-game with dgVoodoo2 (this with ddraw mode at least) and these don't work properly
Reply 403 of 474, by Dege
I release some additions and bugfixes to the latest WIP:
WIP79_1:
- Fixing a D3D12 cache bug (nv Chameleon demo)
- Implementing missing point-type fillmode (nv tech demos)
- Adding option DirectXExt\Default3DRenderFormat
- Fixing a bug with forced MSAA in D3D11/12 DX backend
- Glide fixings (Test Drive 5)
- Finetunig Glide (configured to Dosbox environment) window handling for Dosbox
http://dege.fw.hu/temp/dgVoodooWIP79_1.zip
http://dege.fw.hu/temp/dgVoodooWIP79_1_dbg.zip
Basically I intend this to be the next version, if no serious problems reported.
Reply 405 of 474, by lowenz
FPS limiter for Glide or D3D too?
Reply 406 of 474, by ZellSF
Shouldn't 60 be one of the preset FPS limits (I know you can probably just type in a number)? It's going to be more useful than 1000.
Reply 407 of 474, by Dege
lowenz wrote on 2021-04-08, 22:07:
For both, the presentation layer is common for them.
ZellSF wrote on 2021-04-09, 06:37:
I didn't have much idea for the most useful ones (but I guess limiting into range 25-60 makes the most sense, for old games), but I can change the preset in a subsequent patch version.
Reply 408 of 474, by ZellSF
Here's what I'm thinking of potential framerate limit settings that makes sense:
15/20/25 = just general "low" framerates for games that pushed graphics and just expected 3D rendering to be slow.
30/35/60/70 = "common" "low" refresh rates, or halves of them. Likely targets, games might have been running so close refresh rate mismatch judder wasn't so bad.
That's for the compatibility part of it at least, some people might want to limit FPS to their refresh rate, or their refresh rate - 3 (common with variable sync monitors).
Reply 409 of 474, by ZellSF
Also I'm struggling to close dgVoodooCpl.exe with the newest version, any idea why that would be? It frequently just seems to freeze, rather than close. WIP79_1 and earlier are fine.
This is regardless of if I'm closing with "OK" or the titlebar button.
Reply 410 of 474, by Dege
I have a guess what could be the culprit. I'll change it and also add the values of your suggestion to the preset.
Update: Ok, I fixed the problem. Plz re-download 2.74 with the updated CPL.
Reply 411 of 474, by lowenz
Yes, same problem with the control panel.
Preset for FPS limiter?
Typical options:
*30/60
*Vsync classic values (60,75,85,120,144)
Other options:
*Vsync classic values (60,75,85,120,144) + some FPS -> VSync testing
*Vsync classic values (60,75,85,120,144) - some FPS -> Adaptive Sync testing
Reply 412 of 474, by FulValBot
ZellSF wrote on 2021-04-09, 07:52:
Here's what I'm thinking of potential framerate limit settings that makes sense: […]
There are also some 12 fps games
Reply 413 of 474, by FulValBot
With Midtown Madness 1 in Direct 12 mode some graphics effect are missing; also some fonts are still corrupted, and this happen also when Cleartype is disabled
Reply 414 of 474, by ZellSF
FulValBot wrote on 2021-04-11, 16:26:
Works fine here. By more specific? Post screenshots?
Reply 415 of 474, by FulValBot
I know that works fine, but smoke effect is missing...
Reply 417 of 474, by FulValBot
Font smoothing change nothing in this game, and if i disable that it disable Cleartype too...
Reply 418 of 474, by ZellSF
Cleartype definitely breaks Midtown Madness' fonts; if they don't for you it's because Windows is applying the built-in compatibility mode (your exe is named midtown.exe).
Which brings us to the other point; try with a stock dgVoodoo.conf.
Reply 419 of 474, by FulValBot
Yes i see that it was using Midtown.exe and fonts was broken
i forgot to edit desktop shortcut... i have already both .exe files...
yes, i confirm that with renamed .exe all fonts are good when Cleartype is disabled
