Reply 420 of 452, by DenizOezmen
Sorry for the late replies, other stuff gets in the way.
dm- wrote on 2024-11-18, 17:09:So, the question is, can we mod ASUS P2B-DS bios to match HP E60 board?
I'm not sure I can currently spend time on looking into this. Did you gain any insights since your last test?
stas_mueller wrote on 2024-12-27, 23:09:Can I use a Tualatin CPU now? I use a P3 @ 1 Ghz with a Slotket Adapter in the moment.
Yes, technically you could have used a Tualatin CPU even with the stock BIOS. The mod just improves overall compatibility a bit, like checking for correct VCore in hardware monitor.
GigAHerZ wrote on 2025-01-17, 23:50:Would it be possible to apply adjustments on this like for other P2B boards?
Yes, I did prepare that one. I'll send you a PM in case you want to try it.
GigAHerZ wrote on 2025-01-17, 23:50:I have patched the before mentioned 1014 beta 003 bios with Bios Patcher 4.23 and it reports one of my coppermine-128 celerons now as celeron instead of a pentium 3. What more can be gained over Bios Patcher improvements from your work? 😀
Small stuff like better support for Via CPUs or the ability to insert and load any additional ROM in place of the Symbios option ROM (e.g. for XT-IDE or a boot manager like PLOP)... it's not like the hardware suddenly gets infinitely more capable. 😉
myne wrote on 2025-01-27, 17:48:I realise I'm years late, but for the sake of the next searcher:
I've been looking at the schematic for the p2b, and I'm basically 100% certain that the as97127f is not a hardware monitoring chip. And therefore I'm 99% certain the as99127f is also not a hardware monitoring Ic.So what are they?
I got the idea from the Linux kernel doc. They seem to think the AS99127F belongs to the W8378xx family. At least there's something on the boards that can be talked to as if it was a W8378xx. So dunno ...
