Reply 440 of 690, by zuldan
- Oldbie
_digitalbath wrote on 2026-07-08, 19:48:I wouldn't use Kyocera capacitors. Chemi-con PSG, Nichicon PLG or Kemet 750/755/759 are more reliable in their real measured val […]
zuldan wrote on 2026-07-07, 01:34:What do you think about doing this? Match the uF and voltage but still have low ESR.
I wouldn't use Kyocera capacitors. Chemi-con PSG, Nichicon PLG or Kemet 750/755/759 are more reliable in their real measured value.
Yellow is probably a Rubycon MBZ 6,3v/1800µF cap. I've replaced this position by a Chemi-Con PSG capacitor.
Pink has to be a polymer cap with a low ESR. Kemet may work but may also cause errors. Nichicon RN8 ( ESR 8 ) is here a possible way. My boards did work with Kemet 755 caps.
Rubycon YXG (dark puple and orange) is a general-purpose capacitor. They have to be replaced by electrolytic capacitors like Panasonic FR. Polymere caps may cause problems here. They are not crucial though.
Thanks digitalbath, I appreciate all the advice. All noted.
Could you also tell me what issues you experienced when using brainpower PCBs with the Winbond chips (post code errors maybe)? And is it better to use Samsung TCCD with the brainpower PCBs?
