Reply 440 of 575, by crazyeyes
BEEN_Nath_58 wrote on 2025-04-23, 21:13:This is fine. […]
crazyeyes wrote on 2025-04-23, 21:12:Here are the settings and audio files I've been using for the last several posts. Did I miss something? I haven't been using Pla […]
Here are the settings and audio files I've been using for the last several posts. Did I miss something? I haven't been using Play from CD.
This is fine.
Btw I have this game too. I can check next week if you don't figure the problem out.
Just to add again, Alt+Tab and Do not notify on task switch aren't the most pleasant things for the game
Yeah, I figured that part. I was just fiddling. I turned that off. However, I did figure out that if I change the window size to 1280x960, use "Desktop center," and turn on the mouse clipper, it fixes the scaling (since native game res is 640x480, there is aliasing on 800x600), always appears in the center of my screen, and it captures my mouse. So I rather like that config over fullscreening.
Thanks for your help thus far by the way. I would not have expected this sort of charity from any community. There is no rush, I can deal with only one music track playing per mission.
