Tandy 3 Voice Sound - SN76489 ISA Soundcard Project
Reply 480 of 491, by Boohyaka
I'm still rocking your old card and love it 😀 I must admit I didn't go through every single pages of this thread, can you maybe explain what your objectives are with this new card and what will be the major improvements over the existing one?
Reply 481 of 491, by matze79
I hope to finish the new design today (assigning JLCPCB parts for the order, rechecking all connections, and finalizing the routing). The past two weeks have been quite busy, so I didn’t have much time to work on hobby projects.
I might pick up a Keystone bracket today to do a fit test with a paper prototype.
The new card is basically the same design, just polished a bit and optimized for manufacturing at JLCPCB. Some component part numbers were changed to better match parts available there.
I also added a dedicated oscillator instead of relying on the ISA bus clock, since a user reported that the sound could be slightly off on some systems.
The voltage divider on the PC speaker mix-in will be adjusted to allow higher loudness.
I'm also switching to a Keystone metal bracket. The old design was originally converted from Eagle CAD, which caused quite a few consistency issues when replacing parts, so starting from a clean layout seemed more reasonable.
I also noticed that JLCPCB now offers metal cutting and bending services. In the future it might even be possible to order the bracket directly from them.
Reply 482 of 491, by holaplaneta
These are amazing news. Keep up the great work!
Reply 483 of 491, by jal
holaplaneta wrote on 2026-03-15, 10:29:
Seconded, glad to see the design is finished.
JAL
Reply 484 of 491, by Boohyaka
Amazing, thanks for the update and great work 😀
Reply 485 of 491, by matze79
5 pcbs are on order for testing purposes, i will report back soon 😀
Reply 486 of 491, by jal
Cool! Can't wait 😁
Reply 487 of 491, by underthebridge
I randomly decided to check back on this project, now I’m excited after hearing the update! 😃
Reply 488 of 491, by matze79
A small parcel arrived today!
Unfortunately, I won’t have time to test it until next week(end).
Depending on weather 😀
I’ll also set up a Google Sheet soon where you can add your forum name and other details if you’re interested.
Reply 489 of 491, by jal
Great!
Reply 490 of 491, by theelf
is posible to buy one?where? thanks
Reply 491 of 491, by jal
theelf wrote on 2026-04-14, 21:00:
See Matze's last post: "I’ll also set up a Google Sheet soon where you can add your forum name and other details if you’re interested." So no, you can't buy one yet, but if everything goes according to plan, you will be in the near future 😀.
JAL
