Reply 480 of 553, by YMK
Are you using a custom cable to connect to the wavetable headers on the card, or something routed over the joystick port? If the header, is it doing both the MIDI signal and audio to/from the sound card?
The SB16 is a CT4180. I soldered a two pin header (data and gnd) to the bottom of the 15-pin joystick port. There's a resistor between the SB16 and MacSD to limit current. The synth uses the same 4-pin audio header as CD audio.
So redbook CD audio is working without issue? Are you able to boot the PCs off a SCSI HDD image and do CD emulation and all that all at once?
CD audio is working without issue. This Gateway 2000 has an Adaptec AHA1520 (with ROM), so MacSD is the boot device. It emulates one CD drive and there is an IDE CDROM in there as well.
This is a DOS 6.22 / Win95 system. CD audio works great in Windows as well.
