EAX appreciation thread
Reply 480 of 1113, by Falcosoft
UCyborg wrote on 2025-06-13, 20:39:
...BTW, your Audigy Rx is listed as SB Audigy 5/Rx [DFC0], mine is SB Audigy 5/Rx [EC00]. Anyone knows the meaning of these labels?
It's the starting I/O address used by your card. It's like the "220" typically used by classic Sound Blaster cards. It's not part of the card's type and can be different on different systems.
The attachment IO_range.png is no longer available
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 481 of 1113, by sharangad
That's the io port the card's using, for instance, a classic sb would use port 220 (decimal) (port Dc hexadecimal)
https://patreon.com/Rready
Reply 482 of 1113, by sharangad
You wrote you didn't have problems, but your sound is definitely glitchy, you're not supposed to hear all that static when the game begins. Actually, I've noticed that when playing Interstate '76 through ALchemy, some sound would occasionally play distorted. But Amnesia really pronounces the problem here. You didn't go far enough to pickup any diaries, which have voice narration.
The static wasn't there while I was playing. I think that's propped up in the during the capture. I'll post another video.
Reply 483 of 1113, by sharangad
Here's a much better playthrough, leading to a BSOD while attempting to load the refinery map:
https://youtu.be/M71FDFXTkH4 (with correct DPI scaling settings)
https://youtu.be/CrOob-3Hw38
[EDIT] The high DPI scaling settings are off. Parts of the HUD are cropped.
Reply 484 of 1113, by UCyborg
Ah, thanks for clarification about I/O range, that's it.
sharangad wrote on 2025-06-14, 00:58:
Ha, so you do have messed up sound starting at 3:06. Interestingly, I think you can make the game use ALchemy to access hardware path in another manner, you should have dsound.dll in its folder and at very least OpenAL32.dll, ct_oal.dll and wrap_oal.dll in C:\Windows\SysWOW64, then you'll be able to select Generic Hardware device. Seems you shouldn't have Sens_oal.dll there for the test. So then it goes OpenAL->DirectSound->OpenAL...wacky!
But Sens_oal.dll implementation, which is Creative's software implementation, also seems to sound fine. Although both were tested very very quickly, could have missed potential issues down the road.
Isn't it odd that only directly using Creative's hardware OpenAL is broken? I wonder if behavior is the same on X-Fi cards.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 485 of 1113, by sharangad
UCyborg wrote on 2025-06-14, 06:37:
Ah, thanks for clarification about I/O range, that's it. […]
Maybe it's because I've set channels to 63 instead of 32? The game defaults to 32 hardware mixed voices. The X-Fi supports 128 - 1 (with the 1 reserved for Windows sounds) and the Audigy 64 - 1.
Reply 486 of 1113, by sharangad
Oh the messed up first journal entry also occurs on the X-Fi as well. Someone was complaining about it online a few years back and the random BSODs during map transitions.
Reply 487 of 1113, by UCyborg
I left channels at default. I doubt there's a point, I don't think this game ever relies on a huge number of simultaneously played sounds.
Reply 488 of 1113, by sharangad
UCyborg wrote on 2025-06-14, 07:42:
The bugchecks are a bit of a showstopper though. That was actually kind of a thing for some games back in the day, though most of the ones I was into weren't all that affected.
Reply 489 of 1113, by Joseph_Joestar
Not sure about that game specifically, as I've never played it, but many EAX 5.0 titles can make good use of those 128 voices. Relevant article from Creative's website.
In games like Quake 4, Prey and Battlefield 2 you can hear more detail with 128 voices. For my experience, distant sounds can be perceived slightly clearer, and reverb will be a bit richer, especially when using headphones.
My retro builds
Reply 490 of 1113, by KainXVIII
KainXVIII wrote on 2025-06-08, 18:28:
UCyborg wrote on 2025-06-08, 17:00:
Is that how it's supposed to work on X-Fi? The only EAX settings Audigy has apply system wide, so chosen preset is applied to any sound that is played by any program, which is not something you normally want (probably). Also, EAX doesn't work in Drakan if disabled in Riot Engine Options dialog or if you load a saved game made while EAX was disabled.
Seems so.
The attachment Снимок экрана 2025-06-08 212746.png is no longer available
Maybe its a common knowledge, but i just found out while playing Freedom Force that you can disable/enable EAX effects (or amplify EAX effects ammount) in realtime through audio control panel, for some reason i thought that you need to quit the game and then change EAX. Anyway, useful for comparing!
Reply 491 of 1113, by UCyborg
^^ Aye, I noticed.
I also noticed under certain circumstances, EAX page in Audio Control Panel and in Audigy Control Panel craps out, so you can't change anything. I can post a screenshot later.
Anyone have any thoughts about GTA: San Andreas? They also put EAX ADVANCED HD among intro logos. Are there places with reverb or anything?
Reply 492 of 1113, by Joseph_Joestar
UCyborg wrote on 2025-06-19, 06:27:
Should be pretty good, as the game supports up to EAX 4.0. Here's another article from Creative's old website.
Creative Labs wrote:
Grand Theft Auto: San Andreas
Explore the vast urban landscape, with dynamic EAX ADVANCED HD sound effects. The surrounding environments are accurately modeled for reverberation and reflections from obstacles. When moving from one environment to another, the settings are dynamically computed and applied, allowing the audio to gently morph between different EAX effects.
The audio engine scans around the camera position for obstructions to find out how enclosed the current environment is. This information is then used to adjust the sound effects accordingly. EAX ADVANCED HD creates greater realism of the environment by providing the ability to morph between different effect settings.
My retro builds
Reply 493 of 1113, by UCyborg
OK, it just seems to sound like I remember from back in the day (no EAX, plain stereo), though I've only been messing around in Los Santos recently. Perhaps more 3D-ey of course. It'd be nice to be able to play this thing at the normal frame rate.
These are the screenshots of Creative's control panels going nuts, I think one way to make it happen is launch Audigy Control Panel while EAX enabled game is running.
Reply 494 of 1113, by sharangad
UCyborg wrote on 2025-06-19, 19:19:
OK, it just seems to sound like I remember from back in the day (no EAX, plain stereo), though I've only been messing around in […]
Is this why reverb is so weak in game?
Reply 495 of 1113, by Joseph_Joestar
I mostly play WinXP era games on my X-Fi Titanium, and so far, I never had to manually adjust the EAX slider. Everything "just works", as they say. Not sure if things are somehow different on Audigy cards, as I tend to use those for Win9x games. That said, I haven't really played GTA:SA aside from firing it up a few times to test some things. But it's entirely possible that certain games use EAX in more subtle ways than others.
BTW, if you want to play something that can fully utilize EAX 4.0 functionality, try Thief: Deadly Shadows or F.E.A.R.
My retro builds
Reply 496 of 1113, by UCyborg
sharangad wrote on 2025-06-19, 19:25:
Sounds like there's no reverb at all when the control panels glitch. Restarting audio related services doesn't help. Last time I tried disabling and re-enabling the device in the Device Manager the driver crashed the OS...
If I disable and re-enable in Windows' Control Panel, sound dies. It's back after restarting services, but EAX is still dead.
Reply 497 of 1113, by riplin
I’m sorry if this has been discussed already, I haven’t read through all 25 pages of this thread, but is there any register level programming documentation (official or unofficial) out there on EAX capable cards?
Reply 498 of 1113, by Joseph_Joestar
riplin wrote on 2025-06-20, 04:13:
Not sure if this has the info you need, but the EAX 2.0 SDK is still available on the archived version of Creative's website.
My retro builds
Reply 499 of 1113, by sharangad
The open-source kx project has drivers for the Live/Audigy and EMU APS (all EMU 10k and derivatives). It also let's you program the chip directly for custom audio effects. The hardware accelerated EAX implementation in these drivers is a bit subpar, but the reigster level details should be all there.
