EAX appreciation thread
Reply 520 of 1214, by sharangad
Joseph_Joestar wrote on 2025-06-23, 02:28:
BTW, you can disable the dgVoodoo watermark by unticking the relevant checkbox on its DirectX tab.
Thanks, I'll do that.
https://patreon.com/Rready
Reply 521 of 1214, by sharangad
I disabled it after making this vid:
Need for Speed Hot Pursuit 2 -->https://youtu.be/SsYI8KGj48w
Reply 523 of 1214, by Joseph_Joestar
sharangad wrote on 2025-06-27, 19:33:
Half Life (Original) (Disc only worked after copying files over to harddrive):
https://youtu.be/tWuy-NtGGLk
There's a bit of static with NPC voices.
That might just be how they were recorded back then. Is the static present if you turn EAX off as well?
A few years ago, I played Half-Life on my Win98SE retro rig with an Audigy 2 ZS, and don't recall any major issues with sound. That was with patch 1.1.1.0 applied to the retail CD release.
My retro stuff
Reply 524 of 1214, by sharangad
Joseph_Joestar wrote on 2025-06-28, 11:01:
This is the Half-Life Generations budle. There's no static with software rendering. I didn't apply any patches though, it's just a straight CD install.
Reply 525 of 1214, by UCyborg
In GTA: San Andreas, if you modify savegame to unlock otherwise inaccessible Hot Coffee minigame and use ReverbSA, number of girlfriends have reverb in their houses, at least Denise, Michelle and Katie. Very rarely, it doesn't work. Though not realistic, it's amusing.
About Half-Life, there's MetaAudio plugin for current versions that replace sound system with OpenAL based sound system. But it's terribly glitchy on Audigy Rx's native OpenAL driver, if you stand at certain spot from specific sound source, it's not audible, even if you're very close. Not an issue with OpenAL Soft.
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 526 of 1214, by UCyborg
Additionally, MetaAudio + Sens_oal.dll = random crashes.
Reply 528 of 1214, by Joseph_Joestar
sharangad wrote on 2025-06-29, 18:17:
Does Halo Mcc support EAX? I gave away my boxed copy so I can't test it.
No.
Only the original PC release of the first Halo game (from 2003) supports EAX.
My retro stuff
Reply 529 of 1214, by sharangad
Joseph_Joestar wrote on 2025-06-29, 18:24:
No.
Max Payne 2 doesn't seem to want to startup.
Reply 530 of 1214, by Joseph_Joestar
sharangad wrote on 2025-06-30, 12:34:
I played through that game a couple of years back. It worked just fine with EAX enabled under WinXP.
If you're running it on a newer Windows version, I suggest checking the relevant PC Gaming Wiki page for possible solutions. In fact, I recommend doing that for every game from the XP era, as many of them have issues when played on modern systems.
My retro stuff
Reply 531 of 1214, by sharangad
Joseph_Joestar wrote on 2025-06-30, 12:40:
Thanks, that worked.
Reply 533 of 1214, by sharangad
Halo: Combat Evolved Demo ("The Silent Cartographer"). Long partial playthrough with the Audigy RX:
https://youtu.be/c9Mk3Ov_PEw
Not sure whether EAX is working in this.
Reply 534 of 1214, by UCyborg
Max Payne wrote:
You can't run from your past. You'll end up running in circles. Until you fall back down to the same hole you were trying to escape from, only the hole's grown deeper.
Max Payne wrote:
Life knows two miseries; getting what you don't want and not getting what you want.
Sigh.
Reply 535 of 1214, by Joseph_Joestar
UCyborg wrote on 2025-07-01, 21:39:
Sigh.
That's some classic Sam Lake writing. He was the lead writer for the first two games, and also the original model for Max's face and body.
You can definitively feel his absence in GTA: Sao Paulo Max Payne 3. It's just not the same.
My retro stuff
Reply 537 of 1214, by sharangad
Sigh.
The third game wasn't as well written and had a horrible ending.
Reply 538 of 1214, by Joseph_Joestar
sharangad wrote on 2025-07-04, 00:50:
Bioshock Remaster with OpenAL (FMOD):
https://youtu.be/L5yDYfVmOyA
Not sure if the BioShock remaster still has support for hardware accelerated EAX. The original version definitively does.
By the way, the original is included as a bonus when you buy the remaster on GOG. It's completely DRM free, and installs fine under WinXP as well. At least that was the case when I tried it a while back.
My retro stuff
Reply 539 of 1214, by sharangad
Joseph_Joestar wrote on 2025-07-04, 04:45:
I do have the original, but on the steam forums there were posts saying EAX works with the remaster through FMOD.
https://steamcommunity.com/app/409710/discuss … 42145692394453/
I'll try the original later.
