Reply 54300 of 58018, by MikeSG
BitWrangler wrote on 2024-09-12, 13:44:MikeSG wrote on 2024-09-12, 08:25:Ran some tests. It's not good for DOS games/overclocking... […]
MikeSG wrote on 2024-09-11, 08:26:Many of these Chips & Tech F65545 on Ebay right now. Some under $60 USD. Labelled "advantech pca 6653". […]
I got one because I was curious about the performance and of the third memory IC.
Modern 1998-99 production year. BIOS (Post and setup) is in 640x480 square even on a widescreen LCD.
Advantech still has the drivers and manual: https://www.advantech.com/en-au/search/?q=665 … rt&from=support
It's the same as a CL-5429 up to 11Mhz ISA bus. Does not like to go any faster.
Should be fine in windows though. Does hardware bitblt, hardware cursor, etc.
Well I'm reading that statement as "Isn't the fastest for games that leverage maximum 2D speed like Doom and Quake, but is fine for everything else." Which is pretty normal for anything you can put in an ISA slot, versus VLB or PCI options.
Well there's a up to a 40% difference between 1991 era ISA cards and 1996+ era.
The Chips F65545 is the same as the 1996 era cards, but not as good as the 1996 era cards that can run at 20Mhz ISA bus, and/or the 64-bit ISA cards.
But even at 11mhz ISA, all the 1996 cards can run Duke Nukem and Doom fine.
