Reply 54600 of 59752, by BitWrangler
Got a small haul of stuff at scrap price, kinda modern but some of it's 15 years old and not getting any younger. Didn't snap a pic since it didn't seem tooooo interesting. Two GPU, NVS 290, Asus HD4650 1Gb, PCIe, both low profile boards, so another couple to try in the Dell Apoplexy, I mean Optiplex, that is super picky. Do the Quadros implement PhysX? Because if it's not wanted in the dull, I might be sticking that NVS in things just for physx. (Tested previously with 9400GT PCI, 4x gain over CPU only)
CPUs, 3 of, i7-860 s1156, FX-8120, A6-6400. Pleased with those, don't look abused, realllly hoping the i7 works to swap out with the i3 in that box I got last week. FX-8120 and A6 I don't have seats for at the moment, though gonna check again since I thought I saw an AM3 FM2 board lot on offer. I wasn't wanting to get "into" FM2 and hafta find a CPU..buuuuut...
Desktop RAM: 8pcs 1GB DDR2, 1 pc 2GB DDR2... yeah bit disappointing, still still still low on 2GB DDR2 and I thought there was more of it in here. However, fast chips tight timing on one set of four 1GBs so maybe that might do something interesting for me.
SODIMM: 6pcs 2GB DDR3, 3pcs 1GB DDR2.... heh, why did I get this... though kinda wondering about putting some of the DDR2 chips on a desktop module, higher density.
All untested, but cosmetically good, all in about Bic Mac meal price for the lot, so I'll figure I got an okay deal if a couple of the 5 best things work. Actually if only the i7 works I'll consider that it payed off.
Reply 54601 of 59752, by Wes1262
So the results so far:
295 single PCB: I can get to windows and install drivers but crashes. There is something wrong with the shroud. Doesn't fully clip closed. Kinda annoyed by it because I bought it as a functioning card (60$)
295 dual PCB: this one works, from the same seller, could finish a 3dmark without any issue (60$) I am really happy about this because this is one of the cards I was missing from my collection.
3870x2 no.1: no screen. fan spins at superluminal speeds. I paid 10$ for it so I kinda expected it. Might simply be a poorly installed heatsink (card was clearly tampered with by the previous owner and a screw is missing...... )
fx5700: works perfectly. excellent aesthetic conditions too (10$)
8500LE: sold as non functioning, actually seems to work perfectly fine. It just needs a new fan. (10$)
775dual-vsta: I see text on screen but I didn't test further (10$) the PCB is super bent but I am guessing it is fine
I would've made some photos if my desk wasn't a total mess. I will take eventually photos of the entire collection 😜
Reply 54602 of 59752, by myne
1) code 43?
3) pics of pcb?
I'd wash them all and retest.
Dishwasher no soap is the lazy way.
I built:
Reply 54603 of 59752, by Wes1262
I will take photos myne thanks for offering! As I said my desk is a mess so I need to clean it a bit before I can start taking apart the cards. And yeah a good clean is mandatory. Even if the cards don't work I do like them for display and cleaning is something I enjoy doing and good at. I didn't check the error of the card, I want to clean it and repaste/repad it before I do more tests. I use IPA to clean PCB, and wd40-branded contacts cleaner.
Reply 54604 of 59752, by myne
Heh. I just chuck them in the dishwasher and rinse with IPA if I need it dry quicker.
I built:
Reply 54605 of 59752, by Wes1262
I would never do that 😜 but soft brush + IPA = success
Reply 54606 of 59752, by Trashbytes
Wes1262 wrote on 2024-10-07, 06:01:
Dishwasher with no soap work just fine, just make sure they are thoroughly dry before powering them up, you can rinse with IPA if your water quality sucks.
IPA absorbs water too so its likely a good idea to rinse with IPA in any case.
The other method is to throw them in the sink with some warm water and hit them with a soft paint brush, this wont hurt the parts at all but if washing a motherboard just make sure you remove the battery first.
Ive done both of these methods and they work great . .far better than just IPA+Brush alone
Reply 54607 of 59752, by Wes1262
isn't dishwasher...... a soap? 😜
Reply 54608 of 59752, by Trashbytes
Wes1262 wrote on 2024-10-07, 06:37:
only if you put soap in it otherwise its just warm water. we are talking about this right https://www.freepik.com/free-photos-vectors/d … washing-machine ? You can do this in the sink or tub too if that's what you have.
Though you may want to throw it on a rinse cycle before washing your PCBs to make sure there isnt any soap in there from the previous cycle.
Normal water wont hurt anything so long as you rise with 75% IPA if your water is terrible, here where I live in Australia the water is hard water so full of salt and lime and I need to do a quick rise after washing with some 75% IPA, this drives off the remaining water and I can leave it for a week or more in a warm spot to let it thoroughly dry.
Never had any issues with this method, I wouldn't recommend IPA any higher than 75% as it would become pretty damn expensive but if you have it handy and can spare it then it would be ok too.
Reply 54609 of 59752, by myne
I've used metho in a pinch.
Much cheaper, but it does leave a mildly annoying white residue
I built:
Reply 54610 of 59752, by Trashbytes
myne wrote on 2024-10-07, 07:44:
90% Ethanol would also be ok but that's much harder to get and Everclear is an expensive alternative, might be some Vodkas that would also be high enough proof to also work.
You really just need an alcohol that will absorb water.
Reply 54612 of 59752, by myne
Trashbytes wrote on 2024-10-07, 08:44:
Nah mate, just diggers from bunnings!
The point is a rinse. I still dry it properly.
I built:
Reply 54613 of 59752, by Trashbytes
myne wrote on 2024-10-07, 08:56:
ok you just gave it away, another Aussie !!
Fucking Bunnings and Diggers .. name a better combo.
Though . .they do have Bunnings in Kiwi land . .hmmm
Reply 54614 of 59752, by myne
Yeah, but I guess I'm an "expat" now.
I built:
Reply 54615 of 59752, by PcBytes
I avoid using soap or anything else besides tap water when cleaning very very dirty boards. Any other dirt comes off with iso alcohol, or contact cleaner.
Reply 54616 of 59752, by Jccwu
This adapter must be quite rare.
Sound card's music
Reply 54619 of 59752, by AGP4LIfe?
Jccwu wrote on 2024-10-07, 14:21:
some things made in Russia
I really like that IDE to M2 Board, I need to get me one of those! Much better IO than using compact flash.
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
