Babasha wrote on Today, 16:01:
douglar wrote on Today, 13:09:
I discovered that if you put a VLB controller with the OPTI611 IDE chipset in a motherboard with the OPTI4BH BIOS for 495XLC, an additional page opens up in the setup screen for the VLB IDE controller.
Hi! Can you send a screenshot?
Here it is--
The attachment Photo Nov 16 2026, 1 49 35 PM.jpg is no longer available
"On External Jumper" leaves the chip’s timing registers at their default value.
"On Selectable Rate" programs the chip timing based on the speed selected. Does it in the same way as optivic.sys, opti-set.exe & Linux pata_legacy.c 5.15
VL-Bus (LRDY): Has two options 0 WS & 1 WS. Adds a wait state for 50Mhz FSB.
? - Reads the drive’s IDENTIFY and shows the PIO mode it reports.
Detection: 1F3h echoes C0h; then in 1F1h ×2, out 1F2h,03h (config mode), 1F3h changes, out 1F2h,83h
Timing registers: When in config mode: 1F3h selects the drive bank, 1F1h = write timing, 1F6h = setup and read bank, 1F0h = read timing, 1F5h bits 0–1 = bus-clock strap.
The "?" only shows up when you select a drive
The attachment Photo Nov 16 2026, 2 03 16 PM.jpg is no longer available
Edit - Here is the Card I used https://theretroweb.com/expansioncards/s/seanix-super-16550. I just realized I wrote SiS instead of Opti. Fixing my posts. I get the SIS 83C611 confused with the OPTI 82C611 all the time.
