Reply 57620 of 59867, by Thermalwrong
sunkindly wrote on 2025-10-16, 00:17:
For my 386, I acquired this NEC CD drive from 1988 which also came with the SCSI controller card. My hopes aren't too high for working operation but if anything it'll be a cool piece to have in a bay.
Huh, I just saved the pictures of that one, congrats I think that's quite a find 😀. I don't think I've ever seen an earlier internal CD-ROM drive - that one even has its own weird looking NEC caddy.
sunkindly wrote on 2025-10-16, 02:55:
It did! […]
chrismeyer6 wrote on 2025-10-16, 02:02:
Did the drive come with the CD caddy? It's also fun seeing one of them as it brings back memories as a young kid using them in the school library computers.
It did!
The attachment IMG_7424.jpg is no longer available
Admittedly I've never used a CD caddy before, and if I did as a kid at school or something I don't remember it at all.
Yeah that's a cool caddy. Great that it came with one, since they're part of the disc clamp mechanism you can't do anything with a caddy drive without the caddy.
The attachment cr-501-b.jpg is no longer available
I recently couldn't resist a similar caddy-loading Matsushita CR-501-B drive which also came with an 8-bit SCSI card and cable. In my case it wouldn't read CDs initially but it would work after I aimed a hair dryer at its internals for a minute or two, indicating capacitor faults. Spent ages figuring out what does what and found out it's the same as the Commodore CDTV optical drive pretty much - on mine it was just the 16v 10uf capacitors had gone bad but all the other caps were fine. The mainboard has 32 electrolytic capacitors!
The attachment Matsushita-CR-501-B-Capacitors.webp is no longer available
The attachment Matsushita-CR-501-B-PCB-Mix.webp is no longer available
Once those were replaced it's now reading an audio CD fine but I haven't hooked the SCSI card up to a PC yet to test it properly
I wish you luck with getting your one working 😀
Reply 57621 of 59867, by Ozzuneoj
TheAbandonwareGuy wrote on 2025-10-16, 02:57:
acl wrote on 2025-10-12, 21:30:
Are you really sure about your information ? I have the same card as nfraser01 and reviews from summer 2000 show pictures of the […]
TheAbandonwareGuy wrote on 2025-10-11, 23:05:
Nope, what you have thereis a Rage Theater Gen 1.5 […]
THIS is a full clock speed, first gen ATI "R6" Radeon DDR aka the launch model.
They are quite a rare beast indeed. I actually have one in my possession but its missing a tiny transistor that is beyond my powers to solder currently.
I have the same card as nfraser01 and reviews from summer 2000 show pictures of the very same card.
The 64 and 32 MB DDR were apparently available at the same time with the 64MB version having VIVO built-in.
- Anandtech review (via archive.org) : https://web.archive.org/web/20040114065255/ht … html?i=1281&p=6
- IXBT Labs (scroll halfway through the article for a picture) : http://ixbtlabs.com/articles/radeon/index.html
AnandTech: ATI Radeon 64MB DDR (July 17th, 2000)
The attachment Capture d’écran du 2025-10-12 23-27-41.png is no longer available
Edit : Mine is an OEM one. The one from nfraser01 looks like an OEM version too. With cheaper 6NS memory instead of the 5.5 found on retail ones. But still available around the same time. Review Radeon DDR 64MB OEM with Rage Theater from Nov 2000 : http://www.dansdata.com/radeon.htm
No, I am not sure about anything. I really can't explain to you the rabbit hole you've stumbled upon by looking into the different variations of the original ATI Radeon.
That being said I've owned 200 GPUs, I've spent more time staring at GPUs than 99.9999 percent of computer enthusiast. I am reasonably positive the information I just relayed is correct.
Most people on this site are pretty knowledgeable in different areas, and many probably currently own or have owned significantly more than 200 GPUs (I, for one, haven't counted mine 😮)... if that was some kind of metric for knowledge... but it really isn't. It is always best to provide some kind of source to back up claims, especially in a community where any one member could be just as well versed in these things (or as willing to do research) as anyone else.
I am not an expert on Radeons because I didn't own one until the 9600 Pro came out and I haven't used them much since, but I am inclined to go with the original dated reviews from Anandtech and iXbitlabs from when the cards were released.
I also am not finding any records of a Radeon card being referred to as a Rage Theater Gen 1.5 aside from your post. Some ebay listings and other sites refer to these cards as ATI Rage Theater just because they read the name off of the chip, but... yeah, that's just a naming mistake.
Anyway... this thandor page has what looks like the exact same PCB layout (some caps are different) from nfraser01's post, except that the label on the back says that it is a "SAMPLE ONLY- NOT FOR QUALIFICATION", and it is dated March 31st, 2000, which is before the Radeon hit retail:
https://thandor.net/object/117
It also has the same designator printed on the PCB: PN 109-70700-00A
The number is higher than the SGRAM one you posted, likely because this is the top tier 64MB VIVO model. This would also explain why the reviewers got this model. Thandor's oldest SGRAM model is a sample from July of 2000.
Also note, this particular one doesn't have the Radeon logo printed on it because ATI had not yet even finalized or released the name Radeon (as opposed to Radeon 256, or something else) until after the first run of cards were made. The review samples in the Anandtech and iXbit reviews have the Radeon logo as well as the "Sample Only" label, but are otherwise basically identical.
This preview at Anandtech has an ATI stock photo that is also the same card, and no mention of SGRAM is made in the article as far as I can tell.
So, yeah... I would say that nfraser01's card is the original Radeon, particularly the top model, the "Radeon DDR 64MB VIVO". The SGRAM models came some time after the original release, unless there is a picture somewhere of an SGRAM model from before April of 2000.
EDIT: By the way, I was curious about this myself when I saw you guys discussing it. Doing this research was fun. 😀
Reply 57622 of 59867, by H3nrik V!
I don't even think I KNEW about CD-ROMs in 1988 - and got my own first 4 speed in 1996. Wow! 🤣
Reply 57623 of 59867, by acl
Ozzuneoj wrote on 2025-10-16, 05:07:
Most people on this site are pretty knowledgeable in different areas, and many probably currently own or have owned significantl […]
Anyway... this thandor page has what looks like the exact same PCB layout (some caps are different) from nfraser01's post, except that the label on the back says that it is a "SAMPLE ONLY- NOT FOR QUALIFICATION", and it is dated March 31st, which is before the Radeon hit retail:
Thank you, very thorough and interesting.
Additionally i think that wikipedia is wrong here : https://en.wikipedia.org/wiki/List_of_AMD_gra … eon_R100_series
The Radeon DDR Vivo is on a separate line, with the 2001 date of release. While it's clear that the Rage Theatre chip has been on the 64M versions since the initial release and even on pre-release samples.
Maybe the wikipedia contributor meant AllInWonder instead of VIVO (they exist, but still not sure about the 2001 date. pictures)
Wikipedia correctly depicts 64M DDR OEM versions to have slower memory (6ns instead of 5.5ns like nfraser01'card and mine (see pict below)) but on the VIVO line with the date of 2001, while there are evidences that this card was available in 2000 too (http://www.dansdata.com/radeon.htm).
So wikipedia seems wrong on two things :
- Having a separate line for VIVO seems not correct (maybe a confusion with AIW version)
- Listing 64M DDR OEMs as 2001 is incorrect
The attachment Radeon.jpeg is no longer available
Reply 57624 of 59867, by PcBytes
pete8475 wrote on 2025-10-15, 21:48:
PcBytes wrote on 2025-10-15, 17:03:
PD2JK wrote on 2025-10-15, 15:25:
I wouldn't say that an Intel Dakota isn't interesting. The version with sound perhaps? Congrats anyway. 😀
- ASUS CUBX TOP
I've never heard of a TOP variant of the CUBX and can't find anything online. Can you post a pic of it?
My bad I copied it from another website I posted it on where people would "rate" the boards. It's a standard CUBX w/ CMD controller instead of Promise.
Reply 57625 of 59867, by PD2JK
Epox 8RDA+ as a cold spare, caps need to be replaced. What's up with the upside down logo on the heatsink by the way, always wondered...
The attachment DSC_0091.JPG is no longer available
Geforce4 Ti 4600, one or more memory chips probably need a reflow since there are artefacts. If it's working as it should, I'll install some heatsinks on them.
The attachment DSC_0095.JPG is no longer available
has all kinds of stuff
Reply 57626 of 59867, by Ozzuneoj
acl wrote on 2025-10-16, 09:05:
Thank you, very thorough and interesting. […]
Yeah, sadly, the extremely convoluted, contradictory and ever-changing naming of ATi's products back in the day seems to have made a mess of any efforts to catalog them. I think what really messed this up badly was that different driver versions will refer to the same card differently. So, you could find a DDR SDRAM model like yours in a PC with a driver saying "Radeon 7200", and then find an SGRAM model in a system with an older driver on it saying it's a "Radeon DDR", or vice versa. I guess you could even have SDR models with certain driver versions and they'd show up as a Radeon 7200 as well. Nice. 😕
Thandor likely has the most accurate record of these things, but at the same time the cards there generally are bare cards so they are not shown with retail boxes or other things, so we don't have the exact name that would have been on the BOX for the card when it was sold. Still, he's very logical and reasonable about how he catalogs the cards by the date of manufacture and what the manufacturer was calling them at that time. Like this one for example, which is basically identical to your card as well:
https://thandor.net/object/413
The Radeon 64MB DDR has been produced until summer of 2001 and after the release of the Radeon 8500 the cards were renamed to Radeon 7200. Because this card is dated 14th week of 2001 I named it Radeon 7200 DDR as well. I have similar cards (Engineering samples; i.e. Rage 6, Radeon 256, Radeon 32MB DDR) with different names but technical they are pretty much identical.
So... I guess technically you could go by the manufacture date of the card itself, if you're that much of stickler, but that's really splitting hairs when absolutely everything on the card is identical to the pre-release model.
The fact of the matter seems to be that ATi produced Radeons first of all with DDR SDRAM as shown, and then produced some with DDR SGRAM at some point a few months later. It's possible that they designed the second PCB for DDR SGRAM while designing the SDR model, because it was cheaper to produce these models in large enough quantities to fit demand (thandor mentions here how these models have fewer caps and components). They apparently kept making the DDR SDRAM models though, since they were made in 2001 as well.
One thing that seems to be hard to find well documented\dated pictures of is an original 32MB Radeon using DDR SDRAM. It seems most of the pictures of 32MB models are SGRAM models. It seems that ATi wanted reviewers to get the best example for such a critical release and did not send out many\any 32MB models for review. So even if people were buying them on release day with 32MB DDR SDRAM and no VIVO, there aren't really any pictures to show that.
This one is really funny. Someone is selling what are apparently original Radeon DDR 32MB cards in sealed boxes, and on the back of the box it shows the same picture as Anandtech's preview (with SDRAM), but the ebay seller jammed in a random picture of an SGRAM model since the box is sealed. 🤣 What is actually inside the box is, of course, a mystery.
Reply 57627 of 59867, by sunkindly
Thermalwrong wrote on 2025-10-16, 03:46:
Thanks! If it doesn't work off the bat I'll likely open it up as you did yours and poke around.
The SCSI card has a bunch of dip switches so hopefully I'll be able to find some documentation...I'll post a photo of the card later.
What year is that drive from?
Reply 57628 of 59867, by sunkindly
sunkindly wrote on 2025-10-16, 18:50:
Thanks! If it doesn't work off the bat I'll likely open it up as you did yours and poke around. […]
Here's the card, though there's several on eBay so I assume they were used for a number of different drives.
The attachment IMG_7447.jpg is no longer available
The attachment IMG_7448.jpg is no longer available
Reply 57629 of 59867, by pete8475
PcBytes wrote on 2025-10-16, 09:36:
- ASUS CUBX TOP
Ah I see, thank you for the clarification.
CUBX is a quite decent motherboard but I find the CMD controller is very sensitive to out of spec pci speed, I much prefer the CUBX-E variant. Another good option is to use a PCI ATA133 IDE controller and disable the CMD controller in bios.
aka pete4237.5
Reply 57630 of 59867, by Nexxen
A few Syquest 44MB disks.
Price is low, seller said he found a box with 15 more. Might take them all.
He has to test them first. He has a few units but not selling.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 57631 of 59867, by marxveix
marxveix wrote on 2025-10-11, 20:40:
Ozzuneoj wrote on 2025-10-11, 20:24:
Man, that is a tough one to track down. Must be a European exclusive? […]
marxveix wrote on 2025-10-11, 19:57:
What Compaq Presario model is this? Its got only 3xpci and 1xamr modem (no agp) and its intel old celeron. Can it be made useful […]
What Compaq Presario model is this? Its got only 3xpci and 1xamr modem (no agp) and its intel old celeron. Can it be made useful? 😀
Using a reverse image search I found a couple pages with pictures of it but no model listed. After much digging, these came up:
https://www.kleinanzeigen.de/s-anzeige/compaq … 623732-228-2761
https://www.amibay.com/threads/compaq-presari … -win98.2446205/
The specs on the second one don't match what you have, but the first may be a very similar model except with a P4 rather than a Celeron.
Problem is, the first link calls it a Presario EVO D310, which seems to be completely wrong since searching for that comes up with completely different computers which are all silver or black.
The second link calls theirs a Presario W0313 / CYMT-5FR103A-IT , but since it has a Duron and an AGP slot, the model number is probably very different from yours.
As for if you could do anything with it... it depends if the motherboard is in usable condition (bad caps, etc.), and if you have any use for a low end Intel box from that time period. I wouldn't expect to be able to play any 3D games made after 2000-2001 on it, even with a decent PCI video card. PCI bandwidth pretty much ensures that game performance will be bad no matter what GPU you put in it. It would probably be a solid system for 1997-2000 games though.
If the motherboard is no good, the caps could be replaced or the case could be used with a different motherboard.
Of course the PSU is probably not worth using either. If it is a standard size, it could be replaced. If it isn't, well.... yeah. It gets tougher. Judging from this page, it looks like it uses a standard sized ATX PSU... https://ogris.de/casehack/
Thank you for searching, quick google did not come up with similar cases. It was 11 euro, its probably fits regular atx psu and the system should be working, just psu is broken.
Not yet in my hand, i will make it work and if this is more rare compaq presario model, then even better.
Now its in my hands, but i still dont know the model of this compaq presario. Its small case and regular atx fits if i remove cd/dvd or use laptop dvd. Regular atx and regular dvd it would not fit or very close call. I definetly will change the psu for standard one and i look shorter cd drive. I like small cases, it takes matx motherboards.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 57632 of 59867, by Ozzuneoj
marxveix wrote on 2025-10-17, 20:45:
Interesting! Are there any Compaq labels, stickers or codes on the bottom, back or inside the case anywhere?
Reply 57633 of 59867, by marxveix
Ozzuneoj wrote on 2025-10-18, 02:38:
Yes there are, in the bottom of the case. Later yesterday i found the label.
Model: Compaq CYMT-5FR105A-EE
P/N: 229889-B21
S/N: 5F0B5105V315
Model: W0309
Assembled in The Netherlands
Is there place where i can look by serial number and why two model names? What is the compaq model name then, shorter or longer?
I looked up it takes CPU-s from Celeron 333 up to Tualatin Celeron 1.4GHz and some pentium 3 in between, but not P3 at 133Mhz.
Motherboard GA-6WMMC7 Rev 4.0
https://www.gigabyte.com/Motherboard/GA-6WMMC7-rev-4x
Quick search did not come up many results, is there possibility to find bit more info about this compaq, maybe manual?
Reply 57634 of 59867, by mj3-0
Salient wrote on 2025-10-12, 09:55:
Was looking for these for quite a while and suddenly not even 2 weeks apart I was able to get them both for a real good price
The Roland/Edirol Studio Canvas SD-80 and SD-90!
Wow, how much did these cost!
Reply 57635 of 59867, by Major Jackyl
Woah, woah, WOAH, now!! What is this?!? A total score, that's what!! This will be the slowest computer in my collection if it works/I can get it working.
The attachment 20251018_132714.jpg is no longer available
The attachment 20251018_132749.jpg is no longer available
The attachment 20251018_132805.jpg is no longer available
The attachment 20251018_132834.jpg is no longer available
The attachment 20251018_132823.jpg is no longer available
Rocking a NEC V20 with a Intel C8087-2 co-processor; I haven't looked too much into it yet, just opened the top and was amazed that it was LOADED. So excited to have such a fossil in my collection!
The empty DOES indeed fit baby-AT boards, so I should be able to craft some type of computer into it fairly easily.
I got some other stuff, too.
Gah, I can't even remember what those boards are (forgot them in the car), but I got a (appears to be a 478 board) with SDRAM! What?! Never seen that. And the other is an ASUS 775 board (both have VERY blown caps). I'll be looking at those later. I finished recapping a K7S5A last night and need to test it first.
Finally, I picked up a Boston BA-7800 set, this will be a nice upgrade from the BA-790 I currently use. Hoping they work (untested thrift store junk).
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 57636 of 59867, by AndrettiGTO
Major Jackyl wrote on 2025-10-18, 19:05:
Oh. A thing of beauty, the insides of this thing. Completely 8-bit
Not quite true, internally that V20-8088 works at Sixteen Sweet Bits.
It's all fun and games 'till someone loses an eyeball
Reply 57637 of 59867, by Major Jackyl
AndrettiGTO wrote on 2025-10-18, 19:45:
Ho, HO! I got me some reading to do! I was looking at the 8-bit row of ISAs and assuming it wasn't capable of the extra bits. When I clear-out my desk, I'll disassemble it and read more about! I don't have much experience with PCs this old. This is my first computer with a DIP CPU. Pretty excited for it.
Daily Units:
Reply 57638 of 59867, by PcBytes
Not much, but something, still.
- Athlon 650 Thunderbird - figured out from core, it's got nothing else on it besides the cooler 🤣
- Acorp 6VIA81P - nice 693A board, probably the fastest besides ABIT's VL6.
- XFX GF2 MX400
- Sparkle FX5500 - interesting cooler
- half dead PCI-E GF6200 Turbocache
- DEAD 7300GS from Gigabyte
Reply 57639 of 59867, by Thermalwrong
I really have no idea, somehow the top of the drive's casing is missing so its production label isn't present. The drive was in production from 1990 but looking at all the pictures I took, from the date codes on the ICs this drive was manufactured in late 1990 or early 1991. Your drive from 1988 is a real outlier, I thought CD-ROM drives from pre 1990 were all huge external drives.
I got hold of a Geforce 3 Ti 200 card which had a bad fan, fan MOSFET and bad capacitors - Inno 3D are such cheapskates! All the 1000uF caps were 10v but most of the voltages were 5v, 3.3v or the GPU Vcore which was ~1.5v - all the bad caps were replaced with nice ones and the vcore ones got some 2.5v polymer capacitors, the card works great now 😀
The attachment IMG_7617 (Custom).JPG is no longer available
The attachment IMG_7616 (Custom).JPG is no longer available
The attachment IMG_7618 (Custom).JPG is no longer available
The fan was made to work by simply removing the faulty n-channel MOSFET and briding the Ground pin to the fan's ground, now the fan runs 100% which it would've done anyway since I've never seen FAN control work from the card's BIOS in the GF3 series.
