TheAbandonwareGuy wrote on 2025-10-16, 02:57:
acl wrote on 2025-10-12, 21:30:Are you really sure about your information ?
I have the same card as nfraser01 and reviews from summer 2000 show pictures of the […]
TheAbandonwareGuy wrote on 2025-10-11, 23:05:Nope, what you have thereis a Rage Theater Gen 1.5 […]
THIS is a full clock speed, first gen ATI "R6" Radeon DDR aka the launch model.
They are quite a rare beast indeed. I actually have one in my possession but its missing a tiny transistor that is beyond my powers to solder currently.
I have the same card as nfraser01 and reviews from summer 2000 show pictures of the very same card.
The 64 and 32 MB DDR were apparently available at the same time with the 64MB version having VIVO built-in.
- Anandtech review (via archive.org) : https://web.archive.org/web/20040114065255/ht … html?i=1281&p=6
- IXBT Labs (scroll halfway through the article for a picture) : http://ixbtlabs.com/articles/radeon/index.html
AnandTech: ATI Radeon 64MB DDR (July 17th, 2000)
The attachment Capture d’écran du 2025-10-12 23-27-41.png is no longer available
Edit : Mine is an OEM one. The one from nfraser01 looks like an OEM version too. With cheaper 6NS memory instead of the 5.5 found on retail ones. But still available around the same time. Review Radeon DDR 64MB OEM with Rage Theater from Nov 2000 : http://www.dansdata.com/radeon.htm
No, I am not sure about anything. I really can't explain to you the rabbit hole you've stumbled upon by looking into the different variations of the original ATI Radeon.
That being said I've owned 200 GPUs, I've spent more time staring at GPUs than 99.9999 percent of computer enthusiast. I am reasonably positive the information I just relayed is correct.
Most people on this site are pretty knowledgeable in different areas, and many probably currently own or have owned significantly more than 200 GPUs (I, for one, haven't counted mine 😮)... if that was some kind of metric for knowledge... but it really isn't. It is always best to provide some kind of source to back up claims, especially in a community where any one member could be just as well versed in these things (or as willing to do research) as anyone else.
I am not an expert on Radeons because I didn't own one until the 9600 Pro came out and I haven't used them much since, but I am inclined to go with the original dated reviews from Anandtech and iXbitlabs from when the cards were released.
I also am not finding any records of a Radeon card being referred to as a Rage Theater Gen 1.5 aside from your post. Some ebay listings and other sites refer to these cards as ATI Rage Theater just because they read the name off of the chip, but... yeah, that's just a naming mistake.
Anyway... this thandor page has what looks like the exact same PCB layout (some caps are different) from nfraser01's post, except that the label on the back says that it is a "SAMPLE ONLY- NOT FOR QUALIFICATION", and it is dated March 31st, 2000, which is before the Radeon hit retail:
https://thandor.net/object/117
It also has the same designator printed on the PCB: PN 109-70700-00A
The number is higher than the SGRAM one you posted, likely because this is the top tier 64MB VIVO model. This would also explain why the reviewers got this model. Thandor's oldest SGRAM model is a sample from July of 2000.
Also note, this particular one doesn't have the Radeon logo printed on it because ATI had not yet even finalized or released the name Radeon (as opposed to Radeon 256, or something else) until after the first run of cards were made. The review samples in the Anandtech and iXbit reviews have the Radeon logo as well as the "Sample Only" label, but are otherwise basically identical.
This preview at Anandtech has an ATI stock photo that is also the same card, and no mention of SGRAM is made in the article as far as I can tell.
So, yeah... I would say that nfraser01's card is the original Radeon, particularly the top model, the "Radeon DDR 64MB VIVO". The SGRAM models came some time after the original release, unless there is a picture somewhere of an SGRAM model from before April of 2000.
EDIT: By the way, I was curious about this myself when I saw you guys discussing it. Doing this research was fun. 😀
