Reply 59200 of 60119, by Grem Five
- Oldbie
MattRocks wrote on 2026-06-07, 20:11:Grem Five wrote on 2026-06-07, 20:04:I'm confused with this 3.3 volt talk, the board PC@LIVE posted the manual states "ASRock Graphics Interface Slot (1.5V_AGP1) "
I don't know. I steered away from voltages - just saying the plastic slot itself should physically prevent users inserting cards that are electrically incompatible. I'm trying to focus on PCI/AGP bandwidth, when it matters, and when it doesn't.
I dont know I was just confused because in some posts there was being thrown out 3.3 volts and 33 mzh but being this board mentions 1.5 volt slot and if this AGI slot is based on the pci slots on the board which are spec 2.2 which can run at 66 mzh. <shrug> that sounds like at least AGP 4x and from what I remember back in the day most people couldnt notice a difference between 4x and 8x.
Edit: I took look at the TRW page for this board
Known issues […]
Known issues
Fake AGP slot
Any AGP cards inserted into this slot operate in PCI 33Mhz Fallback mode.
DO NOT use 1.5V exclusive AGP cards (rear notch away from IO side) in this board.
ONLY use true universal AGP cards with both slots, these support 1.5V and 3.3V operation.
This is a PCI bus connected to an AGP slot.
The PCI bus operates at 3.3V and may damage 1.5V exclusive cards.
AGP cards are backwards compatible with PCI signalling logic.
Performance is greatly reduced vs a true AGP bus.
Those know issues listed dont seem to be anything I gleam from looking at the manual but they seem to contradict what they decided to put in manual, I can see the voltage part but falling back to 33 Mzh doesnt really make sense unless a slower pci card is put in one of the other pci slots that is only a 33 mzh card. I mean even the agp slot is keyed for 1.5 volts. Guess ASRock was a bit shady back then as well.
