Pentium Overdrive 83 problem with performance
Reply 60 of 66, by Marcin1199
ux-3 wrote on 2024-08-19, 13:51:
Marcin1199 wrote on 2024-08-19, 13:46:
Do you know why when I set jumper on 40mhz FSB (trying to overclock POD83), any windows will not boot? How to do this in a right way?
You will have to change settings in bios, for ISA, wait states etc. for 40 MHz. Also on some cards.
Probably I do not have such option in my Bios 😒 moreover is it save for POD 83 to overclock it to 100 mhz on the stock radiator and on turbo mode?
Reply 61 of 66, by kixs
Try it at @100MHz. It will work or it will be unstable. Around 1 out of 10 works fine without any mods. Fan is OK as it is.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 62 of 66, by MikeSG
For 40Mhz, fastest BIOS settings, I think RAM needs to be 60ns, L2 cache 20ns or faster.
Or change DRAM Speed to slower settings
Reply 63 of 66, by Marcin1199
MikeSG wrote on 2024-08-20, 07:01:
Yes, I think that there is a problem with a RAM when I try to overclock POD83 to 100 mhz. When Windows is booting, I get information, that there is not enaugh memory to boot. I have tried to switch DRAM Speed to slower settings, but still it doesn't solve the problem. I have tried with auto settings too. I can't set precise parameters in BIOS, because there is no such option.
Reply 64 of 66, by kixs
If Windows doesn't load and you set all the BIOS options to slow, then the CPU isn't up to it. Just run it at 83MHz and all the BIOS settings to the fastest possible.
Reply 65 of 66, by maxtherabbit
kixs wrote on 2024-08-20, 10:06:
this
Reply 66 of 66, by zwrr
Are you using a GMB-486SPS or PKM-0033S motherboard? From the manual, it is known that this motherboard supports 4.0V processor voltage, so you can hack the processor to work at 4V, which will greatly increase the success rate of POD83 oc 100.
Should take a look at this. Modifying the POD83's voltage regulator for overclocking
By the way, with this method, you may need to install a heat sink with more blades and a more powerful fan to offset the extra heat caused by the increased voltage and operating frequency.
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
