Happy new year everyone
Been re-watching some of the videos posted by necroware on the testing (and repairs) of various socket 7 /super socket 7 mainboards
One of the features of this board is it supports 83MHz FSB. I was not planning to try this FSB setting but some threads on here and comments by necroware suggested that a lot of these TX boards can handle 83MHz FSB just fine, even though this gives a very overclocked PCI bus
I thought I would give this a try this morning with the Pentium 233 MMX. I’ve been running it for the past week or so at 75x3.5 and it’s been perfectly stable. I started off with 83x3 as I knew it could already handle that frequency. It posted straight away and all seemed just fine. I then tried 83x3.5 and this again posted fine initially but pretty quickly started to misbehave so I tried increasing the voltage to 2.9v and now all seems good again. I’ve got it running prime95 to see if any errors come up after some stress tests. There is barely any heat coming from the CPU. Seems like it’s a pretty good one!
Here are some benchmark results. The dos tests are with no memory managers installed, using the latest Phil’s dosbench pack. I’m not using univbe, the voodoo3 seems to give very good vbe support without any additional driver. Compared to the S3 virge with univbe installed, performance is increased on the voodoo by 2-3fps
Results in order of increasing FSB, then increasing clock. Most results at 83x3 are better than 75x3.5
233, 262.5, 250, 291.6
Quake 320x200
53.5, 59.9, 61.7, 66.5 fps
Doom, max settings
84.68, 94.19, 98.15, 103.59 fps
882, 793, 761, 721 realticks
Chris’s 3d benchmark (320x200)
165.5, 185.8, 189.8, 206.3 fps
275.8, 309.7, 316.4, 343.8 (score)
PCplayer 320x200
59.5, 66.8, 68.0, 74.2
Speedsys
L1: 425.89, 478.13, 460.29, 530.71 MB/s
L2: 185.05, 207.75, 230.81, 230.81 MB/s
Memory: 130.04, 146.30, 162.62, 162.53 MB/s
Processor benchmark score, 176.77, 198.42, 188.92, 220.40
3dmark99 (I didn’t run 83x3 in this test)
3D score, 1220, 1374, skipped, 1529
CPU score, 1660, 1861, skipped, 2082
These numbers seem pretty close to SS7 levels. It’ll be interesting to see how a k6-2/3/+ runs in this board. A 400MHz K6-2 arrived the other day but I’ve no cooler to test it yet. The one on the Pentium is glued to it, and I don’t fancy trying to remove it. Im sorry I didn’t buy a 500MHz one now as it looks like I need one, but I’ll wait for the right “+” CPU I think
System 1: K6-3+ 600MHz! MS-5158 (430TX), Voodoo3, AWE64
System 2: Athlon XP-M 2800+ SL-75KAV (KT133A) FX5200
System 3: 775i65g (work in progress) FX5900XT
System 4: i7-2600k, P8P67-M, GTX 460
