New VOPL3 release: https://github.com/sdz-mods/VOPL3/releases/tag/A06
Main highlights:
-added DOSBox DBOPL backend. The installer now offers three OPL3 emulators: Nuked OPL3, Nuked OPL3 fast and DOSBox's DBOPL.
-more VOPL3 FM/MPU-401 install granularity. VOPL3 can now be installed in FM, FM + MPU-401 bridge or MPU-401 bridge only modes. When installed in MPU-401 bridge only mode, VOPL3 won't trap the FM ports, and SBEMUL can either be left untouched or be patched and steered away from them.
-new idleclose=<seconds> setting in VOPL3.INI: releases the sound device after that many seconds of FM silence, instead of keeping it open and streaming silence. It is off by default.
-new rate=<hz> setting in VOPL3.INI: the output sample rate: 11025, 16000, 22050, 32000, 44100 or 48000 (default).
-fixed notes left hanging after a game quits. A game that exits without silencing the chip could leave a note playing indefinitely. VOPL3 now releases such notes when the game's DOS box closes.
-MIDI synth kept open until the game's DOS box closes. Before, for DOS games it would close either when the DOS box was closed or after 30 seconds of silence.
-SBPATCH coexists with other SBEMUL patches: a stale PE checksum now gives a warning instead of stopping the install.
-control panel: now shows when the output is released, when FM is off (left to SBEMUL, or ports left free), which renderer is in use, and the sample rate in use.
