Reply 60 of 64, by Tiido
- l33t
Aluminizing the phosphors definitely helps but what actually solved the problem was pure materials that didn't offgas impurities during use. Better getters to absorb what did come out and much better vacuums help also.
There is one place where phoshpor burn-in actually is a big concern and it is projection stuff. My Barco Data 801s has only about 4k hours on it and doesn't yet have visible darkening of the phosphor area that glows, but I have seen photos of stuff some 15k hours old and those have very noticable burned in sections. At some point, recoating the phoshpors was a thing for these projection things, but from what I remember the last place that did it commercially shut down several years ago.
One thing that can help longer term is to just increase filament voltage slightly. My nice Nokia monitor has 30k hours on it and it took actually a long time for it to "warm up" so that it won't black crush anymore, roughly 30 minutes. Some months ago I upped the filament voltage from 6.3V to 6.5V and now it takes some 10 minutes to reach the warmup state where it stops black crushing, a dramatic improvement over before. Higher boost probably improves things even more but I fear the lifetime will be shortened too much. Brightness also improved and I could slightly improve focus over earlier state, so this has been a big win overall. The monitor is nearing EOL and things like this become necessary to get more useful life out of these things...
Those companies definitely do something fun. It would be something I'd like to try out too, but doing this on a high end color monitor is not gonna be an easy task. Those guns are much more complex than the BW things often repaired this type of way. One company I know that does color stuff has a limited stock of guns to use for this task and sooner or later it'll run out... so ability to actually manufacture new stuff will become necessary eventually. Phosphors recoat for my projection tubes should be within reach though, as long as cathodes stay ok enough (they have much more robust cathodes, due to *much* higher beam currents)
